Padding for Regular Jacket?
Trackr
PostPosted: 09:56 - 13 Apr 2016    Post subject: Padding for Regular Jacket? Reply with quote
I have a pretty expensive jacket and don't want to buy a special motorcycle jacket to ride, but do want the protection it would offer.
Is there anything I can do to modify my current jacket by augmenting it with proper padding?
Thanks.
winz
PostPosted: 10:01 - 13 Apr 2016    Post subject: Reply with quote
I'd be hesitant about using an expensive jacket and getting padding to wear underneath. If you have a spill, which could be out of your control, do you want to ruin it?
Current Bikes: BMW K1200S
Previous: Honda CBR929RR, Honda CBR1100XX, Honda CB600F
BTTD
PostPosted: 10:22 - 13 Apr 2016    Post subject: Reply with quote
You could get an armoured shirt to wear underneath, if it'll fit.
Or, stich in Velcro and Velcro in some armour, again if it'll fit.
Good motorbike jackets also have reinforced seams so they shouldn't rip open if you take a tumble.
tom_e
PostPosted: 10:44 - 13 Apr 2016    Post subject: Reply with quote
You can get vests which hold armour that you could wear under the jacket but tarmac will go through a standard jacket like it didn't exist so you'll have no abrasion resistance which is arguably more important in a lot of crashes.
Trackr
PostPosted: 10:59 - 13 Apr 2016    Post subject: Reply with quote
I definitely want it to be over the jacket, both so I can take it off easily and so the jacket won't be ruined.
Any examples?
MCN
PostPosted: 11:10 - 13 Apr 2016    Post subject: Reply with quote
Padded or armoured clothing has wider fitting areas to accept padding/armour.
It is also not much use to you if it moves around too much.
Proper protective gear has compartments specifically designed into the garment for that purpose.
And as said above, you wouldn't want to go tearing the elbow/s out of a good jacket in an off. Smile
Val
PostPosted: 12:44 - 13 Apr 2016    Post subject: Reply with quote
Any examples?
Sure we have plenty examples:
https://1.bp.blogspot.com/-WJSvetwP2BI/Ts6fU1oS5HI/AAAAAAAAAHI/-KHXvZ0NWIo/s1600/KidWrappedInBubbleWrap.jpg
Seriously mate how do we call a protective piece of clothing that have the abrassion protective qualities and also have the armor needed for protection and also can be taken on and off easily? Yes we call that motorcycle jacket.
What you can do is leave your expensive non-motorcycle jacket at home or put it in the top box. Wear the motorcycle one. When arrived you can take it off easily and wear your other non-motorcycle jacket. Which may be expensive, but does not have any motorcycle protection qualities whatsoever. Problem solved Thumbs Up
NJD
PostPosted: 13:01 - 13 Apr 2016    Post subject: Re: Padding for Regular Jacket? Reply with quote
Riding with gear to good look rather than for protection, you're doing it wrong. Strike me as the type of person that looks around to see if anyone's watching while getting on and off the bike. Meh, helmet is the only compulsory piece of gear, only you that all get injured if you ever slide off, but hey.. at least you did it looking good, right?
PostPosted: 14:37 - 13 Apr 2016    Post subject: Reply with quote
Personally I keep my expensive* non-motorcycle jacket away from traffic grime, flies, exhaust fumes etc.
* expensive=paid about £45.
BTTD
PostPosted: 15:08 - 13 Apr 2016    Post subject: Reply with quote
Any examples?
Confused
A large armoured textile motorcycle jacket sounds like what you want. I'm pretty sure I've seen a whole textile suit that you unzip and climb into advertised or posted up somewhere with a chap suavely arriving at work and stepping out of the oversuit in pristine business attire and perfectly coifured hair.
Back in the real world, what are you trying to achieve?
Northern Monkey
PostPosted: 15:39 - 13 Apr 2016    Post subject: Re: Padding for Regular Jacket? Reply with quote
Your non-motorcycle jacket will achieve the same amount of protection as cling film, or slightly stronger than average cling film
Thanks.
Wear a proper textile bike jacket over the top of your expensive jacket
Tierbirdy
PostPosted: 17:18 - 13 Apr 2016    Post subject: Reply with quote
OP is a pikey chav riding a moped in a North Face puffa jacket to impress 14yr old slags in the ASDA carpark and I claim my £5. Laughing
rhys99
PostPosted: 20:40 - 13 Apr 2016    Post subject: Reply with quote
I've never understood people who wear normal coats on motorbikes. Just get a bike jacket.
NJD
PostPosted: 20:42 - 13 Apr 2016    Post subject: Reply with quote
When it's absolutely roasting on like one day in every ten years I can. Outside of that I wouldn't bother donating a single thought about it, ride with what you're comfortable with.
Trackr
PostPosted: 04:12 - 14 Apr 2016    Post subject: Reply with quote
I'm not British, but I think I can safely say that you lot are a bunch of fuckin' wankers.
Thanks for the help from across the pond Smile
talkToTheHat
PostPosted: 04:33 - 14 Apr 2016    Post subject: Reply with quote
Triple stitch all the seams with bonded nylon? Fashion jackets fall apart at the seams if you throw them down the road. They also likely wear through in the places that don't rip off.
Failing that, forcefield do a vest with all the armor in for such occaisons. Is quite expensive. I think my textile and waterproof rst jacket cost less. I think my fit for purpose leather jacket cost less than that too.
Bandit. does. everything.
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
andyscooter
PostPosted: 07:13 - 14 Apr 2016    Post subject: Reply with quote
doesn't matter where you are from it will still fall apart in an off
BTTD
PostPosted: 08:10 - 14 Apr 2016    Post subject: Reply with quote
Sad I was trying to be helpful, even though your query seems to amount to: I want a protective jacket to wear on my motorbike that isn't a motorbike jacket. Laughing
tom_e
PostPosted: 09:37 - 14 Apr 2016    Post subject: Reply with quote
If you want people to just agree with your shit idea go and post on a yank forum Middle Finger
PostPosted: 10:08 - 14 Apr 2016    Post subject: Reply with quote
Squid.
JoeDaStudd
PostPosted: 10:36 - 14 Apr 2016    Post subject: Reply with quote
It's like saying I have a nice expensive bucket I want to use as a helmet, how do I add protection.
It's not designed for it and even if you spend a lot of money adding protection (armour and anti-abrasion layer) it's still going to be worse then something designed to do the job in the first place plus it's probably going to look like Frankenstein's monster when its done.
It'll be cheaper and better to just spend the cash on a real motorcycle jacket and save your expensive fashion jacket for when your not riding.
Undinist
PostPosted: 15:14 - 14 Apr 2016    Post subject: Reply with quote
Seriously Trackr, Americans are tragically undereducated about protective bike gear. Either learn from the Europeans or just ride in street clothes and risk years of agonising skin grafts like most of your countrymen. To be blunt, your question is staggeringly dumb. If you don't want to hear what we're saying, get some advice from some of the few US firms who are clued up about safety. Here are three I have bought from - I recommend them all, their products are world class:
- Vanson Leathers https://www.vansonleathers.com/
- Aerostich https://www.aerostich.com/
- Icon One Thousand https://www.icon1000.com/
Here's a classic example of dangerous American ignorance - this guy owns a Vanson leather jacket, and he crashes in it and writes to Vanson to tell them how he had this huge accident and the jacket was undamaged: www.vansonleathers.com/customers/p19.html
The trousers/pants he was wearing were just thin cotton army pants. Check out his photo of what happened to them:
https://www.vansonleathers.com/images/CustomerPics/p19/Picture%20180.jpg
From his description of the accident he was probably only doping about 35 mph by the time his body started sliding along the road. But "they worked on me in the trauma center for 9 hours... couldn't walk for a couple months...still suffering several hours of pain daily from my healing wounds". He STILL refers to his pants as "safety equipment"! Please don't be as moronic as him. If you fall off, the friction burn you and your clothes get from the road surface is like someone using a belt sander on you. What do you think you should wear to defend yourself against a belt sander?
Fin
PostPosted: 15:22 - 14 Apr 2016    Post subject: Reply with quote
When It's raining I just wear a north ridge coat over a hoodie, don't want to soak my leather jacket and don't like textiles. I think it provides enough protection as I'll slide on the wet rather than skid as much.
Doovy
PostPosted: 15:24 - 14 Apr 2016    Post subject: Reply with quote
I don't even.
The last post was made 10 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 128.13 Kb
