pre diversion XJ 600, anythng known?
jjdugen
PostPosted: 16:39 - 14 Apr 2016    Post subject: pre diversion XJ 600, anythng known? Reply with quote
Hi all.
The local garage owner has offered me this one, too much hassle for him to sort. Its an arrangement I have with him.
So, its registered as a '91, so the last of the breed. Mono shocked looks to be all there, alloy a bit dingy, carbs need cleaning.
Strange thing I've noticed as I've looked it over is that it has the housing for the field coil alternator behind the engine, but has a permanent magnet one fitted in the L/H side crank-case. All looks factory too.
Stranger things have happened I suppose in a models run.
So, anything known about them, I know its long in the tooth but it seems honest enough.
Diggs
PostPosted: 20:18 - 14 Apr 2016    Post subject: Reply with quote
A mate had one years ago. Good, solid bike from what I remember. Only thing we had to sort was rear wheel bearings (twice if I recall)...
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
Shaft
PostPosted: 22:47 - 14 Apr 2016    Post subject: Re: pre diversion XJ 600, anythng known? Reply with quote
jjdugen wrote:
Hi all.
One of the things Yamaha were keen to publicise, was the narrowness of the XJ series of engines, achieved by moving the generator from the end of the crank, to behind the cylinder block.
What should be behind the left hand crank cover, is the pick up coil.
If you feel the need to balance the carbs, to get it right you will need to make, or otherwise acquire a YICS tool, without it you will get false readings.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:46 - 14 Apr 2016    Post subject: Reply with quote
Expect the exhuasts to be rust.
Triumph Sprint ST 1050
jjdugen
PostPosted: 06:59 - 15 Apr 2016    Post subject: Reply with quote
Hi and thanks for the feedback.
Given it a good dose of looking at. Carbs off and cleaned, started right up. I see what you mean about the YICS gubbins, its nothing more than linking the carb inlets together via the balancing outlets. A bit of research says it makes a bit more power with them blanked off!
Anyway, balanced up fine, smooth and quiet especially for an air-cooled engine
Still a bit puzzled by the two alternator mounts and cant find any info on it, it should have the field coil unit behind the engine, the layshaft is in there as is the drive gear off the clutch housing Would make a perfect take off point for a supercharger..... Hmmm.....
I'll clean and polish, stick an MOT on her and cross my fingers that it will be worth £500, otherwise I've wasted a couple of weeks works
weasley
PostPosted: 07:09 - 15 Apr 2016    Post subject: Reply with quote
I had one for a year. Was a solid bike. Most of the instruments and idiot lights didn't work (well, the rev counter worked in heavy rain) but the speedo did so meh. The exhaust rusted through at the collector and one of the down pipe collars rusted away but I managed to get three of the four down pipes out of the collector and bodge it all back together with paste and good intentions (and new header collars). The only other thing I had to do was regular freeing/cleaning of the front brakes and I had to drill the headlight mounting screws out to change the bulb. Other than that it had over 54,000 miles on it and ran as sweet as anything.
Moo.
PostPosted: 12:30 - 15 Apr 2016    Post subject: Reply with quote
Don't get your hopes up too much, you can get the Diversion 600 for not much more then that...
A2 Passed 18/6/10
WULFSTAN
PostPosted: 22:05 - 16 Apr 2016    Post subject: Reply with quote
I'll give you 450.
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
evoboy
PostPosted: 22:11 - 16 Apr 2016    Post subject: Reply with quote
The 'pre divi' is quite popular in a certain race series at the moment. FZ600's are also used as its in effect, the same engine.
I had one. Learnt to get my knee down on track with it. Would have another over a Diversion any day.
APT Motorcycles
sjc
PostPosted: 22:54 - 16 Apr 2016    Post subject: Reply with quote
I have one currently, its alright just feels a bit heavy and sluggish at the bottom end. And yeah brakes need cleaning overtime it looks at water.
The last post was made 10 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 67.87 Kb
