Sprint 955 - reliable commuter?
c_dug
PostPosted: 08:47 - 17 Apr 2016    Post subject: Sprint 955 - reliable commuter? Reply with quote
Hi all,
Somebody came to view my vfr yesterday, he's got a 955 sprint for sale, around 35,000 miles, cosmetically on the poor side of average by the sounds of it. He reckons it's worth around a grand. He said he'd be interested in mine either way, but asked if I'd consider a part-ex.
I've been looking for a cheap commuter to tide me over until I have a bit more money available again, so I've had my eye out for a GPZ500 or anything NTV based.
Given the 955 is decidedly un-GPZ like, am I mad to be considering it?
Obviously it depends on consumables and what not, but in general is there much to be wary of with these? I can't say I know much about them.
Thanks
SIG1981
PostPosted: 11:35 - 17 Apr 2016    Post subject: Reply with quote
from experience working on them I wouldn't for the following reasons :
1- plastic fuel tank - the amount of ethnol in unleaded these days is known to melt the plastic tanks causing fuel leaks - meaning new tank required (especially morrisons fuel).
2- fuel pump plate bolts are known to pull metal inserts out of the plastic tank especially when fuel filter is replaced - meaning new tank required.
3- fuel level sensors stick - giving false / no reading on guage.
4- ecu fills with water - giving running issues - new ecu required and visit to triumph.
5- ignition coils corrode giving running issues - not the cheapest to replace
6- throttle body stepper motor siezes up - giving high or no revs at tickover.
7- chain adjuster seizes into swingarm quickly.
8- rubber seal between airbox and throttle stepper motor cracks and gives poor running.
9- vacuum hoses from stepper motor to throttle bodies crack and break quickly giving running issues.
10- they require expert servicing to run spot on - things go out of tolerance quickly especially valve clearances ( not uncommon to replace all 12 valve shims every 12000m). - its amazing how many garages / people think " its just an engine like any other " and make a mess of servicing resulting in visit to triumph specialist to sort , which normally results in a large bill from the effects of the previous " cheaper" service .
driving wise you either love or hate them as they are quite agricultural and not as refined compared to a vfr.
For £1000 I would be very cautious as its a potential costly can of worms.
noobRider
PostPosted: 13:32 - 17 Apr 2016    Post subject: Reply with quote
Sig makes them sound terrible but I don't think they're awful. I have one that's done about that mileage and had another before this. £1,000 is the most you'd pay for a ratty one. The chain adjusters seizing is a common issue, mine haven't yet. Sprag starters also can fail. My first one did have a duff fuel sensor and because of the shape of the tank my current one only starts to go down much when you're down to the last quarter of a tank. 200 miles on a tank of fuel. I've not had issues with mine apart from when I've dropped it and broken things. You can't work on anything without removing the fairings. which is a pain. Back brakes seem to eat pads, but that's probably me. Panniers are v useful but not huge so OK for filtering. It accelerates smoothly to licence-losing speeds and will do 140+. Standard exhaust is V quiet Sad. It's a very easy ride.
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
PostPosted: 13:38 - 17 Apr 2016    Post subject: Reply with quote
I had a 1998 Daytona 955i I bought in 2002. I sold it to a friend a few years later, and he's just sold it. It's done nearly £40k and he does no routine maintenance other than a dealer oil change every year. When you wash it it still comes up looking as good as the day I bought it, and it still rides amazingly well. If the Sprint is built half as well, and is anywhere near as understressed it should just go and go.
PostPosted: 17:22 - 17 Apr 2016    Post subject: Reply with quote
If going for it, I'd try and get them down to £800 maybe.
As a bargaining tool:
www.ebay.co.uk/itm/311557063725
The last post was made 10 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 46.62 Kb
