Honda cbr 600f clutch stuck
djmarcopolo
PostPosted: 11:15 - 16 Apr 2016    Post subject: Honda cbr 600f clutch stuck Reply with quote
Hi all, so I'm progressing up in the world and hopefully when all the local schools can be bothered to reply or return calls I can finally take my direct access tests but thats proving more difficult than learning to repair bikes
I have 2 125s that I maintain myself for myself and my wife and to get ready for a bigger bike I found a 1987 Honda cbr600f hurricane as a first full size bike that has been kept in dry storage for many years
I've cleaned fuel and tank out and serviced her, new chain and sprocket and got it running spot on but now I've found the clutch is stuck
I can repair cars and outboard engines OK but I'm delving into new territory opening bike casings, looking for a decent how too or YouTube video to finish her ready for an mot soon or maybe someone here can give me a basic run down on what to do so I can get her ready for passing my test
Thanks in advance
haroman666
PostPosted: 12:17 - 16 Apr 2016    Post subject: Reply with quote
Have you managed to get it unstuck?
Stick it in gear and rock the bike back and forth with the clutch pulled in.
It may break free.
Or start it, bang it into gear and it may also break free.
OR
Take the side casing off (A number of bolts and disengage the clutch cable) and remove the 4 or 5 bolts holding the clutch plates in and prise them apart and reassemble.
Likelihood is though, that it will continue to stick. Leaving it overnight or for a couple of days may see it stuck again, but not to the same degree.
So see how it goes, and if it keeps on sticking then it's time for some new plates.
monkeybiker
PostPosted: 12:34 - 16 Apr 2016    Post subject: Reply with quote
Get a haynes manual. I've changed a clutch on the f2 cbr600f and think your bike is similar. It's pretty easy. If you do have to change the plates then do the springs at the same time. You''ll need to order a new locking clutch bolt as well as it has a little tab that you hammer to lock it in position.
There good bikes the jelly mold cbr's. They are quite nippy and you can chuck them about down the country roads.
djmarcopolo
PostPosted: 12:58 - 16 Apr 2016    Post subject: Reply with quote
It may break free.
OR
So basically a new set of clutch plates then would be best
Thanks for your help
djmarcopolo
PostPosted: 13:02 - 16 Apr 2016    Post subject: Reply with quote
It may break free.
OR
Forgot to say I got it running nicely then found it wouldn't go in gear when running then it clunked in and stalled and it took ages to get it out again by rocking it and now I struggle to get it into gear to try rocking it so I'll have to strip it
monkeybiker
PostPosted: 12:53 - 17 Apr 2016    Post subject: Reply with quote
I don't mean to insult you but before you strip the clutch have you got the clutch cable set correctly? How much free play in the clutch lever?
bikenut
PostPosted: 13:58 - 21 Apr 2016    Post subject: Reply with quote
would you do this with your car???
as you have found out this is bad advise.
other than stripping etc, which is the best way,( the steel plates "corrode" where the friction plates have stuck ( post some pics )), start engine and leave till it reaches operating temp and stop engine.
Arrange bike so the rear wheel is off the deck ( make sure the bike cannot fall so the rear wheel is on the deck ) and the front brakes work.
Place in gear, a high gear being better than a low gear, and start the engine. Pull clutch in and blip the throttle. This transmission shock will "free" the clutch plates.
simply smashing the bike into gear will damage the gears etc etc etc .
would you do that to your car?????
nuts about bikes
PostPosted: 14:06 - 21 Apr 2016    Post subject: Reply with quote
I would try to loosen it by pushing the bike and getting it up to speed the banging it into gear with the clutch held in.
Baffler186
PostPosted: 14:19 - 21 Apr 2016    Post subject: Reply with quote
^^ This worked for me, but it was on a 125. I got up to 10mph then knocked it into 2nd, then just kept riding until it unstuck. I wouldn't advise that on public roads though. It unstuck when I started going up a steep hill and never stuck again. Worth a try before you buy new parts?
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
Meatybeaty
PostPosted: 14:47 - 21 Apr 2016    Post subject: Reply with quote
Hi Keith, have you got a Workshop manual Thumbs Up
The last post was made 9 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.69 - MySQL Queries: 13 - Page Size: 65.75 Kb
