2 Stroke Running Lean
FlubbaBubba
PostPosted: 19:34 - 21 Apr 2016    Post subject: 2 Stroke Running Lean Reply with quote
Bought an Aprilia mx 125 an it had a pipercross pod filter fitted, ended up fitting the original air box but it had no snorkel and i had to bodge up the air to carb pipe as they butchered it to fit the pod filter an i had problems finding a new pipe.
The bike ran a bit rich after i re-jetted the carb but i fitted a new snorkel to it the other day and removed the melted electrical tape which i used to bodge up the pipe as the fuel had go to it.
The plug is now darkish grey and the revs hang a bit at idle.
Anybody know what to check bearing in mind i haven't check for air leaks yet.
Thanks
PostPosted: 20:12 - 21 Apr 2016    Post subject: Reply with quote
If you are aiming to get it back to standard then I would do that before playing too much. Snorkel should be easy enough, although the intake pipe might be a pain to get hold of.
With air leaks, check both the intake rubber (between the carb and the engine) and also the main bearing seals.
Katy
FlubbaBubba
PostPosted: 21:19 - 21 Apr 2016    Post subject: Reply with quote
Will check that and if there isnt a problem there then i will have to do a leak down test.
Thanks.
The last post was made 10 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 36.71 Kb
