FZS1000..........Naked Conversion.
dannymassive
PostPosted: 20:36 - 24 Apr 2016    Post subject: FZS1000..........Naked Conversion. Reply with quote
I bought a FZS1000 Fazer at the beginning of the year with the intention of converting it to a naked machine, just to be different! A bit unusal as although I believe they made a naked version of the 600cc Fazer, The thou only ever came out the factory with a fairing. It has taken a while as i've had to make a few brackets for various items - using only basic hand tools!
I just thought that I would share a few photos of the process.........
So, This is the bike when I first put it in my garage :
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/IMG-20160121-WA0000_zpsjpbn9dxn.jpg
I soon started stripping the fairing off :
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160201_192807_zpsnyyqyhhk.jpg
Note the Reg/Rec on the right hand side by the fuel tank, on the standard bracket it lived within the fairing. This was the first bracket that I had to make.
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160201_192802_zps0bz30k0b.jpg
I used a small piece of aluminium to make a small bracket to fit it close to the frame as you can see here:
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160322_200624_zpsaacxwkit.jpg
Next up was the speedo. Again, that originally lived within the fairing and this produced a bit more of a problem, as it was never intended to be mounted outside of the fairing. I got a template of the speedo and obtained a 4mm thick aluminium road sign to make the bracket.
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160312_111951_zpsjvkiqeej.jpg
With only hand tools, it took a while to cut out and file all edges, but the end result was this:
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160312_112124_zpslaxtkypo.jpg
Trail mock mount :
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160312_112449_zps0fupuitf.jpg
As you can see, the bracket is still straight and has not had the angle put on to it yet :
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160312_112459_zpsxhlmpy5h.jpg
Rubbed down all the road sign paint :
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160325_182057_zps3xwkzyr2.jpg
Into a vice and bent to the correct angle, then spray painted. I used some rubber inserts for the speedo bolt holes to reduce the vibration transferred to the speedo :
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160407_163105_zpsctxptywg.jpg
Mock fit of the speedo in the new bracket :
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160407_163258_zpsd3mixmml.jpg
Before putting it together, I wasn't happy with the brake pipes. Look at the one heading from the master cylinder to the left (right in the photo) caliper. Not only was it tight, but it was actually rubbing in the steer lock on the frame. Needless to say, I replaced these!
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160321_073307_zpseuym5brn.jpg
I bought a universal 7" round headlight, indicators, some headlight brackets, mirrors and then mounted the speedo on its new bracket. It took a bit of wiring, but got there! Also replaced fuel tank with a black one :
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160416_190424_zpspqvh4axa.jpg
Then made a new bracket for the horn. Getting there now! :
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160416_193448_zps7c33fbui.jpg
View from rear of the bike, speedo seems at the right angle. :
https://i1208.photobucket.com/albums/cc378/dannymassive/FZS1000/20160423_161441_zpsyrlv653a.jpg
The end result.........
https://i1208.photobucket.com/albums/cc378/dannymassive/20160424_174245_zpsjdpf6uhs_edit_1461521583979_zps16uggcyk.jpg
Previous Ride's - '01 Aprilia SR125 (Sold) '08 HONDA CBF600n (Sold) '96 CB500 (Sold) '01 FZS 1000 (Sold) '06 CB1300SA (Sold) '07 CB600F Hornet (Sold) - '93 Suzuki Savage LS400 (Sold) '98 Honda VTR1000 Firestorm (Sold) '05 CB600F Hornet (Sold) '01 FZS1000 Fazer (Sold) 2016 Harley Davidson Street Bob SE (Sold) '02 Kawasaki ZX9R (Sold) '98 CB600F Hornet (Sold) '04 Suzuki Bandit 1200s (Sold) '13 Yamaha FZ1-N
tommy748
PostPosted: 02:10 - 03 May 2016    Post subject: Reply with quote
Bit of ingenuity and some effort, top marks. I never liked the faired models.
dannymassive
PostPosted: 05:30 - 03 May 2016    Post subject: Reply with quote
Cheers Tommy Thumbs Up
Whilst it is not to everyone's taste, I do prefer a naked bike to a faired bike. I'm very pleased with how the bike looks now.
c_dug
PostPosted: 06:44 - 03 May 2016    Post subject: Reply with quote
I've recently got a 1st gen Fazer 600 and was toying with the idea of this, that does look tidy!
tommy748
PostPosted: 09:38 - 03 May 2016    Post subject: Reply with quote
Always preferred a traditional headlight on most bikes. Yours is cool and I like it more because not only was it self done it was done with basic tools and materials instead of spending a lot of money.
PostPosted: 11:53 - 03 May 2016    Post subject: Reply with quote
The pointy FZS1000 Fazer fairing is soughtafter by people with the square headlight fairing as a replacement, so be sure to stick it on Fleabay!
RhynoCZ
PostPosted: 18:00 - 03 May 2016    Post subject: Reply with quote
I'd fit a rectangular headlight, to get the 80's look. Razz
dannymassive
PostPosted: 21:48 - 03 May 2016    Post subject: Reply with quote
Do it! The cost of the conversion is absolute minimal. If you ever change your mind you can switch back within an hour or so.
Hahadumball
PostPosted: 01:40 - 04 May 2016    Post subject: Reply with quote
Looks pretty good tbh, miles better naked!
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
c_dug
PostPosted: 06:19 - 04 May 2016    Post subject: Reply with quote
Could you have done it in a day?
Snowdonia Rider
PostPosted: 06:51 - 04 May 2016    Post subject: Reply with quote
Fair play that's a good effort. Needs something at the back of the clocks though Thinking
weasley
PostPosted: 07:49 - 04 May 2016    Post subject: Reply with quote
I don't mind that - I might look at painting that forward-pointing spar of the frame (by the reg-rec) black as this clearly was never meant to be on show and might clean up the look from the side.
It is far better than many a 'street-fighter' though. Thumbs Up
grr666
PostPosted: 12:04 - 04 May 2016    Post subject: Reply with quote
I like that. Looks like a proper motorbike. Thumbs Up Excellent bodging Thumbs Up
dannymassive
PostPosted: 16:05 - 04 May 2016    Post subject: Reply with quote
That's another advantage of doing a naked conversion like this. I could very easily change the headlight to whatever I want, as and when I want. It's so easy to customize a naked.
Cheers Paul, glad you agree!
Yes, If I had spent a day on it I could have easily done it in one shot. Gathering materials and getting child-free spare time is what has taken this project so long. As said, I could swap back to faired within an hour or so now and now that I have made the brackets I could swap back to naked just as quick as and when I please.
These clocks were never meant to be mounted outside of the fairing, hence the wiring from behind. Going forward I may box the wiring in, but for now (since the photo was taken) I have used some flexible conduit to hide the wiring. Looks much neater now.
Thanks Weasley. I too think it looks better than most with some of these new "modern" universal lights that are available these days.
As Avid Merrion would say - It's proper bo, i'll tell thee!
The last post was made 10 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 91.3 Kb
