Unfortunate coincidence or dodgy dealer?
wuuaf
PostPosted: 18:51 - 25 Apr 2016    Post subject: Unfortunate coincidence or dodgy dealer? Reply with quote
Evening BCF'ers - just wanted some others opinions on the following.
I dropped my BMW f650gs (twin) in for a big 24,000miles Service on Friday with my local BMW garage, they called mid afternoon saying the air-box was damaged, and needed to be replaced, I agreed & they kept the bike till Saturday.
On my way over to collect the bike on Saturday I received another phone call saying they'd road tested the bike & it was only firing on one cylinder....as I was on my way I wanted to see the problem, apparently it is the coils & they both need replacing.
Now the bike was running 100% ok before the service, and I only wanted to get it done as it will go over 24,000miles during a trip to Europe next month.
The service was £320, air box £130 & coils £190....I managed to get them down to £550 for the parts & service in total.
But my question is, is it just an unfortunate coincidence the coils went whilst it was in for a service, or is it something they could have broken?
Unfortunately the bikes out of warranty so either way I'm shafted & have to pay...thoughts much appreciated!
Off to collect the bike on Tuesday evening after waiting for the parts...
Cheers;
Previous Bikes: Honda CG125 / Suzuki Gladius Current Bikes: BMW F650GS Twin / Suzuki 110 Twatped
BTTD
PostPosted: 19:09 - 25 Apr 2016    Post subject: Reply with quote
Not being overly familiar with your bike, how on earth does an air box get damaged?
SIG1981
PostPosted: 19:27 - 25 Apr 2016    Post subject: Reply with quote
from experience the airbox can be damaged if not removed / fitted properly ( there are 2 small black panels on the frame ( 1 either side of the frame) with vacuum pipes from throttle bodies to air box.) if the pipes are pulled off incorrectly ( air box lifted too high at back ) the plastic pipes on airbox snap off - same when fitting if not straight force can snap them off - both ways are the garage fault as they don't " just break off " ( I assume this what happened? )
coils can fail - but as it was running ok, I would suggest poor connection to coils ( panels and airbox come back off to check / replace ).
Having a look at old coils they normally rust and split if the black type.
why were both replaced if running on 1 cylinder?
sounds like you been shafted for a poor diagnosis with the coils
af1
PostPosted: 19:28 - 25 Apr 2016    Post subject: Reply with quote
Bmw dealers doing the 'kwikfit' scam,
Kwickfit offload dampers to 'stupid ' people saying dampers need replacing on their car.
Bmw doing the same to bikeists , they do it to cars , now creeping in to the bike side ? I bet they had the spares sitting there just waiting to be used.
wuuaf
PostPosted: 19:31 - 25 Apr 2016    Post subject: Reply with quote
With regard to the air box, having looked at it I think the previous owner may have broken it - it's the T piece which is moulded into the whole box which is broken on one side. The break looks quite old with dirt / dust in it.
It's the coils I am more concerned about though Sad
PostPosted: 20:23 - 25 Apr 2016    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=274403
Nope.
PostPosted: 20:40 - 25 Apr 2016    Post subject: Reply with quote
A friend of mine had the coils fail when she was servicing her F650 twin. No real reason for it, they were removed, new plugs put in, went back on, bike was re-assembled and one of them failed. Had to fit new ones. Seems like a fairly common failure point on these.
BTTD
PostPosted: 20:44 - 25 Apr 2016    Post subject: Reply with quote
If it is that, then there's nothing new about it. Back in the 80's my dad knew a guy who'd worked in an Essex BMW dealer. It was allegedly Wink common practice for the mechanics to replace parts on their personal bikes with parts off bikes in for a service, and the service manager was the worst for it. All allegedly.
Coils do go, and it may be that being disturbed for the plug change was the kiss of death, but if it's out of warranty, isn't there a decent independent you could take it to rather than a main dealer?
Nope.
PostPosted: 20:47 - 25 Apr 2016    Post subject: Reply with quote
This is a very good point. Why are you taking it to a BMW main dealer for servicing now its out of warranty? Find a good independent or do it yourself. Would have saved you a chunk on the coils if you'd got them used from motorwerks.
PostPosted: 21:48 - 25 Apr 2016    Post subject: Reply with quote
Because 24,000 is both a valve check service and also plug replacement, which isn't trivial. There's a magical BMW coil remover tool which is meant to get them out without damage, although a fat lot of good that seems to have done.
On the valves, an indie would have to actually whip the cover off and go in with gauges, cold. BMW just plug it into the Machine That Goes Ping. If it detects that their service department has some spare capacity and your credit rating is good, then it goes Ping, you'll bleed copiously from your wallet, and your valve cover will leak forever more. As an incidental consequence some of your shims may get changed although I wouldn't bet on it.
In this case, well, if a coil failed, it failed, and presumably Friend Computer says to replace them as a pair because mumble balance the tesla field jumble warp core breach.
On the airbox, Poundland does 8 (eight) tubes of superglue for a 1 x Pound Coin.
The coil failure is concerning. I was poised to to do my plugs at 18,000 and for once I've splashed out a massive £12 on the coil remover tool to get at them. However, if they do run good to 24K and the coils are fragile, I reckon I'll sod it off until then - thanks for the warning. Thumbs Up
As it may appear, I'm not exactly enamoured of the idea of giving one penny of my hard earned to Motorrad, having heard far too many of these tales about them. From keeping an eye on eBay and putting mine up speculatively, there's not a big demand for these bikes either, so it's not like you'll ever see that "FBMWSH" money back in resale.
Nope.
PostPosted: 00:12 - 26 Apr 2016    Post subject: Reply with quote
Can buy a tool from Motorwerks for £3, and I would trust my feeler gauges (ooh er) more then any computer BMW's got. I've had fun with their sensors in the past!
Agreed, except I'd go with some plastic welding strips and a cheap soldering iron Thumbs Up
Meh, I'd change them. It's a risk but a used coil isn't mega money and I'd rather have it fail in my garage then when I'm halfway to the eurotunnel at the start of a 5000 mile trip.
Yeah, they're unfortunately not in high demand. Shame too as they're not as unpleasant to ride as I thought they would be. Not terrible off road either, surprisingly (And given the right tyres!). Friend has been trying to sell her (very well maintained with a lot of extras) 50k mile bike for a few months now for low money without so much as a sniff.
mentalboy
PostPosted: 01:37 - 26 Apr 2016    Post subject: Reply with quote
This obviously supersedes the original kwikfit scam which was to slash a customer's tyres and then say 'duh, you need new tyres, mate'
Oldie
PostPosted: 06:49 - 26 Apr 2016    Post subject: Reply with quote
I do wonder whether it is actually worth performing major servicing on these bikes.
One guy on the F800 forum has just turned 100,000 miles on his F800GT and never once checked the valves. Here's his summary....
L&R grip switchgear
Faulty indicator
Head races
Fork seals
Exhaust link pipe weld slightly blowing (not enough weld filler material) - sealed with Loctite 5920
Seized rear floating calliper - captive boss end sawn off to free up stud
Paint flaking off mirror stalks, crankcase & sump, bar-ends
I might scare some of you with this but I have never had any intention of having the valves checked; have never changed the air filter (I tap the largest debris out once a year) and have changed the plugs once. I believe I am on the 4th belt
PostPosted: 10:53 - 26 Apr 2016    Post subject: Reply with quote
It's almost certainly not worth paying BMW to do it, unless it's the 12,000 mile service and you're planning to sell it fairly shortly afterwards to someone who thinks FBMWSH isn't pronounced "£80 an hour for Trainee Terry to shine a torch on it". That said, I was quoted £210 inclusive for the 12,000 mile, which isn't that bad, given that a Suzuki dealer rinsed my workmate double that for a major on his Bandit 650. I just had no faith in the local Motorrad to actually do the work.
As you say, demand for "high" mileage bikes is low, given the number of garage queens out there, particularly on these also-ran models. Dealers were already sucking their teeth at the whopping 13,000 miles on mine when I was touting it as a trade-in, and I had no interest at all from eBay or Gumtree ads, not even agencies or scammers. I've been keeping an eye on the few that come up for sale and it's 0 bids, 0 bids, no sale, 0 bids... Crying or Very sad
The chaps who do check their clearances at 30,000+ miles on these 800s tend to report them as being within tolerances, but they seem to change a few shims anyway just on principle because they're already in there. I holla.
wuuaf
PostPosted: 15:12 - 26 Apr 2016    Post subject: Reply with quote
The only reason it went to BMW was because they were only £40 more than the local independent who'd never worked on a f650gs before Crying or Very sad
I'd have done the service myself normally, however didn't want to mess with the valve clearances.
Just had a call from them they fitted the new coils & didn't resolve the problem, computer is telling them it's all ok - they're keeping it till tomorrow now.
Very frustrating when the bike was fine when dropped off Thumbs Down
PostPosted: 23:22 - 26 Apr 2016    Post subject: Reply with quote
Jesus wept, peace of mind, eh? Sorry to hear it. Hopefully it's just a bad plug rather than... well, let's see what they say.
At this point, I think I'd be saying "I dropped off a fully working bike, now I don't have one. How are you going to make that right?"
Allegedly, when my local Motorrad realise that they've mullered something, they take it round to the local indie dealer and say "Fix it, misters". Shhh!
BTTD
PostPosted: 09:16 - 27 Apr 2016    Post subject: Reply with quote
That is disappointing. It annoys me that garages will blindly follow the computer without testing components. Are they saying that the coils were bad and there's coincidentally another issue? Or are they just throwing parts (at your expense) at the bike until it's fixed?
Sadly I think it may be the latter, and it's not uncommon.
DrSnoosnoo
PostPosted: 10:30 - 27 Apr 2016    Post subject: Reply with quote
I get annoyed reading workshop posts when people tell us they are just putting new things on "and still can't solve the problem". There is no diagnosis in this method so whatever "fixes it" may not have truly been the issue.
When you read of dealers and other mechanics doing the same it is even more frustrating. You're paying somebody just to charge you for bits that they can't even decide are broken.
BMW. Laughing
To OP. I'd follow Borg's advice. You took it in for a rather simple service and they've ended up replacing things after it broke in their possession. And then when they've replaced it, it still isn't fixed. And you're still using taxis to get to work because it's taken them much longer than the day they anticipated ...
wuuaf
PostPosted: 11:32 - 27 Apr 2016    Post subject: Reply with quote
I have just had a phone call from them, the bike is ready for collection & guess what was wrong....a faulty spark plug!!
The first this I asked was whether the spark plug gaps had been set correctly & they assured me they had & been tested fine.
6 Days to work this out.....
Seriously unimpressed, but pleased it's something so simple.
Thanks for all your comments & feedback, will let you know how I get on with them later.
lihp
PostPosted: 11:36 - 27 Apr 2016    Post subject: Reply with quote
Have you asked about who is covering the cost of the coils that were not necessary?
PostPosted: 12:56 - 27 Apr 2016    Post subject: Reply with quote
3... 2...
Qualified good news, especially as it implies that they did actually change them. Out of interest, are iridium plugs standard, or were you asked if you wanted them?
I also trust that there will be no mention of coils on the bill.
R1stu
Shrek!
PostPosted: 13:46 - 27 Apr 2016    Post subject: Reply with quote
Rogerborg wrote:
3... 2...
Or the extra labour charges? Evil or Very Mad
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Marmalade
PostPosted: 15:08 - 27 Apr 2016    Post subject: Reply with quote
That does piss me off when diagnosis is formed after the repair.
Misfires, so, replace plugs, replace coils, replace crank sensor and oh! local auto elec traced it to a broken wire, so, a new sub loom.
That'll be £650 thank you ta.
wuuaf
PostPosted: 19:32 - 27 Apr 2016    Post subject: Reply with quote
To be fair to the dealer all ended well, £400 all in for the service & the air box, the service should've been £320 & £130 for the air box.
Not impressed though & won't be using them to service the bike again!
Just to top the whole saga off, the bike toppled on the trailer on a particularly bumpy road on the way home, thankfully the crash bars saved the bike & there's only a light scuff on the body which will polish out. Struggled my tits off trying to get it upright & back in the wheel run on the trailer, none of the 3 vans behind me who all had smart comments whilst driving past offered any help!
Such is life, I believe the bike wasn't rolled into the front chock properly as I let the dealer roll it on, but after I strapped it down the second time it was solid all the way home.
Thank god it wasn't 5 minutes later on the M5 & under an artic - very lucky with the minimal damage!
Thanks for all your input guys Thumbs Up
PostPosted: 21:36 - 27 Apr 2016    Post subject: Reply with quote
Result, although it does sort of sound like your bike wants to die. Thinking
The last post was made 10 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 141.2 Kb
