How to make A2 restrictor on and off switch
ko5i
PostPosted: 10:44 - 26 Apr 2016    Post subject: How to make A2 restrictor on and off switch Reply with quote
Hi guys,
So i was at the test centre sorting out my certificate because he put me A instead A2 and i gave him license so waited 3 weeks for new and now he saying i didnt gave it to him what a cunt. But back to topic i was looking at bikes outside and there was bike with a "switch" a lock you put key inside turn and it was A or A2 so you could switch over derestric with just key quickly. It was on throttle area so something with throttle. Any idea how to make it?
Thanks!
Hahadumball
PostPosted: 11:30 - 26 Apr 2016    Post subject: Reply with quote
itll be a locking pin that goes into the throttle housing. the key just moves it across
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Meatybeaty
PostPosted: 11:40 - 26 Apr 2016    Post subject: Reply with quote
saw this Thumbs Up
https://www.bikechatforums.com/viewtopic.php?t=251451
ko5i
PostPosted: 15:12 - 26 Apr 2016    Post subject: Reply with quote
I read all of it and dont really get it, some say this some say this im confused now so basically a switch that a key you twist right to unrestrict and left to restrict is illegal. What if because i want to add my dad on my bike anyway cuz it gets cheaper by 300£ insurance because he has full license what if i say for example i ride restricted but ''my dad only have keys to unrestrict''
Meatybeaty
PostPosted: 15:21 - 26 Apr 2016    Post subject: Reply with quote
What is the bike you have ,does it have fuel injection Thumbs Up
ko5i
PostPosted: 15:38 - 26 Apr 2016    Post subject: Reply with quote
I'm interested in Yamaha XJ6 and yes it has fuel injection
Loui5D
PostPosted: 16:17 - 26 Apr 2016    Post subject: Reply with quote
Restricted via a different ECU, it's a 2 min job to swap.
ko5i
PostPosted: 16:26 - 26 Apr 2016    Post subject: Reply with quote
where do i get such ECU that makes 46.6 bhp ?
I have question i found this
https://www.ebay.co.uk/itm/Yamaha-XJ6-XJ-6-2009-on-Restrictor-Kit-35kW-46-46-6-46-9-47-bhp-DVSA-RSA-Approve-/321873792070?hash=item4af12c4c46:g:p1IAAOSwxH1UEtWc
So basically if i restrict it with this does it mean that i cant red line ? for example it goes up to 6000 and cant go any further ? or how does this works ?
Evil Hans
PostPosted: 18:07 - 26 Apr 2016    Post subject: Reply with quote
Easy ... you just need something like this ....
https://cdn.bcf.44bytes.net/files/restriction.png
dydey90
The engine will rev freely right to the red line with no load even if you only open the throttle a small amount.
According to the description, this kit restricts the bike by limiting the travel on the throttle linkage. This is a physical restriction, rather than electronic. I can't say I've ever seen a fully electronic restriction kit.
As for exactly how this kit works, I couldn't say as the description is rather vague. It does appear more to be the old style of exhaust manifold flow restrictors, but it does say that it does 25kW and 35kW so most of the parts in the picture may not be needed.
riejumike
PostPosted: 22:06 - 27 Apr 2016    Post subject: Reply with quote
It's just a piece of metal that stops the throttle turning all the way round, around 50%- similar to the picture below (I know it says "standard"- the Australian FZ6R is restricted to LAMS standard). The part is the top-left bracket in the eBay picture.
Having ridden a restricted XJ6, the bike doesn't really feel restricted, especially at lower speeds. It's only until 70+ that you start to want more power, but at legal speeds you will win the traffic light GP every time.
At lower speeds you can easily redline the bike, it does feel a litle breathless at higher RPMs but still quick. As the speeds get higher then you start to notice the loss of power more.
I've never seen such an ECU- every XJ6 I've seen restricted (on the 'net) and the one IRL one I've seen is by a throttle plate, similar to this:
https://i391.photobucket.com/albums/oo352/The_Bear_21/Bike%20-%20FZ6R/00331a29.jpg
A guy in Australia does this exactly and creates a "switchable" restrictor. In Aus. the FZ6Rs (a.k.a. rebranded XJ6F) come restricted from the factory so he is actually making a switchable de-restriction:
https://www.youtube.com/watch?v=AjRGg1mzR3g
IMO the solenoid is overkill, I'd rig up some sort of clip that you push in and out with a long screwdriver from the outside that would engage the restrictor.
Have you ridden the bike restricted? It won't be full power, but it won't be slow... Just leave the restrictor in and forget about it, no point putting your licence, insurance, safety, etc. at risk over a few bhp Thumbs Up
DJW992
PostPosted: 00:53 - 28 Apr 2016    Post subject: Reply with quote
i3arty wrote:
I can vouch for Kickstart on eBay, I think he's actually a member of this forum, got the restrictors for my old Bandit from him.
ko5i
PostPosted: 20:48 - 01 May 2016    Post subject: Reply with quote
Hi all, i bought XJ6 2013 with 10 000 miles on it but overall in good condition. He let me test ride it and it seems good except that when i turn slightly while riding it pulls me even more to the side im turning maybe something with bearing or tire because he said i need to change front tire, and back one i replace as well so they will be brand new fresh tires Very Happy.
I rode the bike around my streets unrestricted as im waiting for restrictor so i will later insure it and could ride anywhere but for now jsut rode up my street and damn that has pull, like when i full throttle i have to hold tight to steering or else it will push me off xD, its fun but dangerous as i might go crazy with it, so i will restrict it and see maybe it will still has some pull but be legal Very Happy
PostPosted: 21:51 - 01 May 2016    Post subject: Reply with quote
Not so much illegal, as quite likely doesn't render the bike restricted as it can still produce full power with no modifications.
Katy
PostPosted: 12:53 - 02 May 2016    Post subject: Reply with quote
It's a grey area, it's not countenanced in the legislation. There appears to be more Eurobollocks coming to prohibit the sale (note, sale) of restricted bikes, so I wouldn't expect the situation to get better.
Can your dad not ride a restricted bike then?
ko5i
PostPosted: 20:18 - 03 May 2016    Post subject: Reply with quote
I will go with the restriction and see how it works out if its still fun to ride , i rode a bit without [i know illegal and risky] but i tried down my streets and its damn powerful has really pull. My dad won't ride it anyway im just putting him on insurance because it goes lower by 300£
The last post was made 10 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 92.55 Kb
