rear wheel movement issue
Val
PostPosted: 13:01 - 28 Apr 2016    Post subject: rear wheel movement issue Reply with quote
Hi All,
yesterday I was gonna lubricate my chain on my FZS 600. And the rear wheel has not turning freely.
On center stand and in neutral the wheel turns free and fine just a little say 4 inches and than suddenly stucks and stops to the point you can't move it with hand, two hands or foot at all. Happens in both directions.
I have removed the rear brake caliper - same problem it stucks.
I have tried the same with clutch pulled in - same problem. When in 1st gear with clucth pulled in the rear wheel does not moves at all eceb an inch. In neutral moves few inches.
The bike rides and feels fine when riding. Clutch seems to engage and disengage the same way it always was before that issue.
Can't lubricate my chain though.
Any ideas what may be the problem?
Thank you in advance.
cheers
Val
Minty
PostPosted: 13:04 - 28 Apr 2016    Post subject: Reply with quote
Bearings.
My fingers smell of your mum.
jaffa90
PostPosted: 13:06 - 28 Apr 2016    Post subject: Reply with quote
Have you any chain slack when the wheel stops?
Val
PostPosted: 13:10 - 28 Apr 2016    Post subject: Reply with quote
Yes the chain slack is there.
jaffa90
PostPosted: 13:26 - 28 Apr 2016    Post subject: Reply with quote
Oh dear, is there any top & bottom wheel play (rocking)
doggone
PostPosted: 13:33 - 28 Apr 2016    Post subject: Reply with quote
Hard to see the bearings could be that bad without making alarming noises when ridden.
Brakes seem ruled out so could the chain be on it's last legs?
Again it should be getting very noisy before getting to the stage where it can hardly be forced round the sprocket.
If you slacken the adjustment enough to lift the chain off you could rule it out.
sickpup
Old Timer
PostPosted: 14:47 - 28 Apr 2016    Post subject: Reply with quote
More than likely a stiff link or 5 in the chain.
Matt B
PostPosted: 16:40 - 28 Apr 2016    Post subject: Reply with quote
Do this. Move the chain off the rear sprocket and off to one side then spin the wheel.
Val
PostPosted: 18:55 - 28 Apr 2016    Post subject: Reply with quote
Minty wrote:
Bearings.
Thank you all.
Ok that may be the case or something in the rear axle. I have ridden 20 minutes with low pace than have stopped at a garage. The guy has loosen the rear axle bolt a little and the wheel moves freely.
Either bearing or something else hapenning there. And the bolt and the axle were both very warm.
Left it with the mechanic it is too complicated for my skills. I know you will say its easy to change bearing, but I do not have the tools and prefer a mechanic to do that Very Happy
331X2
PostPosted: 22:16 - 28 Apr 2016    Post subject: Reply with quote
Missing bush/spacer?
Val
PostPosted: 08:49 - 29 Apr 2016    Post subject: Reply with quote
I hope not. Having said that I do have changed new tyres few weeks ago hope the tyre mechanic knows his job Very Happy
Matt B
PostPosted: 09:29 - 29 Apr 2016    Post subject: Reply with quote
It's amazing how many people have had problems like this after some partially trained monkey mechanic has impact gunned the rear end to death replaced a tyre.
This is why I remove and replace wheels myself for tyre fitting.
Val
PostPosted: 10:40 - 29 Apr 2016    Post subject: Reply with quote
Update: Just have called the mechanic - it was sprocket gearing fail. I have asked him to change the other two wheel bearings there too. Soon I will have almost new axle Very Happy
PostPosted: 10:42 - 29 Apr 2016    Post subject: Reply with quote
Eh?
jaffa90
PostPosted: 11:07 - 29 Apr 2016    Post subject: Reply with quote
chris-red wrote:
Eh?
Eh? as well.???????????????????
Val
PostPosted: 11:30 - 29 Apr 2016    Post subject: Reply with quote
chris-red wrote:
Val wrote:
Update: Just have called the mechanic - it was sprocket gbearing fail. I have asked him to change the other two wheel bearings there too. Soon I will have almost new axle Very Happy
Eh?
Eh indeed. Just a typo Laughing I meant sprocket bearing...
jaffa90
PostPosted: 16:31 - 29 Apr 2016    Post subject: Reply with quote
Did you ask the technician what caused it?
The last post was made 10 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 93.77 Kb
