| neilus123 |
 neilus123 Derestricted Danger
| jaffa90 |
 jaffa90 World Chat Champion
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| neilus123 |
| neilus123 |
| stevo as b4 |
 Posted: 19:29 - 29 Apr 2016 Post subject: |
Whoever said carb heater, you made me spit out hot coffee all over the floor!
OP I'm wondering if you do a dry build, but just oil the lip of the seals when you fit them, and then try sealing up the carb and exhaust and doing a leak down pressure test, if it could help you identify which seal or gasket or casing is leaking?
You could have a pourus crankcase casting maybe?
If you get air escaping from.the gearbox oil filler hole or the ends of the crankshaft, it will at least give you an idea where the leak or crack is coming from? |
| jaffa90 |
 Posted: 23:04 - 29 Apr 2016 Post subject: |
| stinkwheel |
| bikenut |
 bikenut World Chat Champion
| neilus123 |
| neilus123 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:31 - 30 Apr 2016 Post subject: |
I'd start by eliminating the simple/obvious; & a 25:1 pre-mix is a bit bloomin thick'! I don't think even my strimmer runs that oil-rich! My old piston-ported Cota book says to run that at 33:1, but I mix at 40:1 on modern oils, and that's a low-speed motor that peaks at about 6K revs! Higher speed motors would tend to beg thinner mixes still, as they get more lube from more cycles.
Next up; I would be wary of runnig an auto-lubed motor on pre-mx, without other mods.
1/ remove, rather than disconnect the oil-pump. First they squirt so little oil into the motor, they can still be pumping exta oil in from what's in the pipes, doubling your oil ratio. Next, they are self lubricated by the oil they pump; let them run dry and it can wreck the pump, on some motors with dire consequences to the primary drive if they sieze.
2/ If you pre-mix; you need to up-jet the carb. Carb's jetted to deliver a set ratio of 'fuel' to air. If you add oil to the petrol, then the motor is likely to run 'weak', which usually ent good on a 2T motor; as your 'fuel' now contains less petrol per cc, some of it displaced by the two-stroke oil.
If you have 'compensated' on the mixture screw, though, you are now sucking the same quantity of petrol in to get the right (ish) petrol/air ratio, BUT, you probably need to thin out the pre-mix ratio even more, as the extra fuel is dragging even more oil with it.
For where you are at, I'd drain the tank, and put in clean fresh petrol; re-connect the auto-lube pump, and trust t, and try get the smoke to clear on a warmed up engine on the pump feed adjuster, to eliminate the added variables of trying to run petroil, before tearing the poor motor to bits again looking for anything more sinister! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| stinkwheel |
| neilus123 |
| neilus123 |
| stinkwheel |
 Posted: 20:34 - 30 Apr 2016 Post subject: |
You need to prime it by bleeding oil down to the pump from the tank then disconnecting the hose from the carb. With the bike idling, hold the pump control in the "full throttle" position until oil starts dripping out (usually a drip every 3 or 4 seconds). You'll see the pump pumping in and out. It sounds like you have more than enough oil lurking about in there to let it idle for a few minutes with the pump disconected.
Then kill the engine and reconnect the hose.
Most pumps have a couple of index marks that line up at closed and full throttle, check your manual.
If it's primed so you've seen oil comng out and the index lines match up, there's no reason to suspect the pump is doing anything other than working normally. They aren't a part of the bike that's prone to failure. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| bikenut |
| neilus123 |
The last post was made 10 years, 137 days ago. Instead of replying here, would creating a new thread be more useful? |
