UPS issue
ScaredyCat
PostPosted: 23:18 - 30 Apr 2016    Post subject: UPS issue Reply with quote
I have a little UPS issue. First of all it's shut off the power ports so it isn't passing power through to equipment. However, it's also refusing to turn off. Currently running of its batteries only but I can't get the bugger to switch off. With no load it'll probably run for a week before it has no power.
It's a powerware 9120 with additional batteries. anyone got any ideas?
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Jewlio Rides Again LLB
PostPosted: 01:22 - 01 May 2016    Post subject: Reply with quote
Turn it off and back on again?
lols jk
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
bamt
PostPosted: 10:16 - 01 May 2016    Post subject: Reply with quote
As it's not passing power through I assume you are OK to pull it from the circuit?
I'd do that, then pull it apart and remove the batteries and put them back in again (hard reboot). But even if that sorts it out, I'd be wary of relying upon it. It's possible the controlling micro has crashed, but it may also be a hardware fault.
ScaredyCat
PostPosted: 20:05 - 01 May 2016    Post subject: Reply with quote
Yeah, it has no load and is isolated from any equipment.
Andy_Pagin
PostPosted: 10:07 - 02 May 2016    Post subject: Reply with quote
How old's the unit. In my experience these things don't last forever.
mudcow007
PostPosted: 12:36 - 06 May 2016    Post subject: Reply with quote
is there a breaker/ isolator on the back of the unit?
if so, could you safely pull that out without it giving you a belt?
ScaredyCat
PostPosted: 13:13 - 06 May 2016    Post subject: Reply with quote
It finally ran out of battery last night...
There is a breaker or sorts but
a) you need to fit the switch while the unit is off
b) you can do it while it's on batteries.
I'll open it up and have a look tonight...
The last post was made 10 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 51.34 Kb
