Installing new grips
EazyDuz
PostPosted: 11:21 - 02 May 2016    Post subject: Installing new grips Reply with quote
I have some new handlebar grips. They're metal with rubber sections on them designed to cushion your fingers. These rubber bits go through to the underside of the grip itself.
Just wondering how best to install them so I can remove them without damage in the future. If I use super glue I run the risk of gluing the bottom of these rubber sections to the bar causing them to tear on removal.
Thought about wrapping a lot of electrical tape around the bars and jamming the grips on that way?
PostPosted: 13:13 - 02 May 2016    Post subject: Reply with quote
Rigid grips generally need gluing. Rubber ones that have to be stretched over the bar will stay put if you fit them with hairspray
Removal of grips is often a destructive process anyway.
Superglue is likely to break away clean. It not being all that super as glues go.
Ichy
PostPosted: 13:36 - 02 May 2016    Post subject: Reply with quote
If you do try hairspray then give the bars and insides of the grips a good clean with something solvent based. A bit of grease and it won't stick.
Hong Kong Phooey
PostPosted: 00:05 - 04 May 2016    Post subject: Reply with quote
A squirt of brake cleaner / isopropyl alcohol lubes it up for insertion Shocked
Then when you've done it evaporates - if the grips rubber is tight enough you may not need glue.
If you have hairspray but no IPA or brake cleaner to hand then have a word with yourself Laughing
The last post was made 10 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 39.75 Kb
