| sausagepartyb... |
 sausagepartyb... Derestricted Danger
| Jmh600 |
 Jmh600 Nova Slayer
| mysterious_rider |
 mysterious_rider World Chat Champion
| sausagepartyb... |
| cyberglass |
 cyberglass World Chat Champion
 Posted: 19:42 - 02 May 2016 Post subject: |
put it in gear get someone to hold the rear brake down get ratchet on it put a hollow bar over the ratchet handle and stand on it. thats what i do never had one beat me yet  ____________________ DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005 |
| dydey90 |
 dydey90 World Chat Champion
| Chuffin Nora |
 Chuffin Nora World Chat Champion
 Posted: 21:07 - 02 May 2016 Post subject: |
Yeah, fuckin ratchet, FFS.
And on a clutch centre nut, F-FUCKITYFUCK!!
10mil+ bolts and 6mil+ Allen bolts require a breaker bar, IMO.*
Using a ratchet thus is just tool abuse.
When I see Delboy break 12mil brake calliper bolts with a ratchet I seriously want to break his face, the cnut.
*Inb4...
Yes, obviously a short bar, for small stuff . . .
Other [cheapshit] brands available. ____________________ There's a fine line between integrity |
| skatefreak |
 Posted: 10:37 - 03 May 2016 Post subject: |
Wouldn't a hammer on a ratchet provide the 'impact' to crack it?
I usually bounce a hammer off it a few times before resorting to breaker bars  |
| chris-red |
| chris-red |
| skatefreak |
 Posted: 14:23 - 03 May 2016 Post subject: |
Halfords advanced.
No quibble replacement ratchets
Do it all the time an not broken one personally though.
But yes, have a 90 degree widget if things get primal.... |
| arry |
 arry Super Spammer
 Posted: 14:30 - 03 May 2016 Post subject: |
| skatefreak wrote: | Halfords advanced.
Ratchet mechanism not covered
The metal in the Halfords professional tools has a lifetime guarantee. The moving parts of the tools (EG Rachets) are not covered by the lifetime warranty.
All products covered by the guarantee must be supported by a valid reciept as proof of purchase if any claim for replacement is required. |
| Polarbear |
 Polarbear Super Spammer
| bikenut |
 bikenut World Chat Champion
 Posted: 15:42 - 03 May 2016 Post subject: |
Once you've used an impact wrench to do this job, you wouldn't bother doing anything else.
Of course what you're SUPPOSED to do is to use a couple of special tools to lock the clutch mechanism. It's apparently an easy job if you do this too.
The stuck bit of bolt would probably have come out using a strong magnet to turn it or even by tapping it round with a fine punch. Definately with an extractor. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
 Posted: 17:23 - 03 May 2016 Post subject: |
Also according to your first picture...you have the last friction plate in wrong, the last one should be in the other set of slots to the rest of the stack.
manual here
https://support.bazzaz.net/service_manuals/ZX600J8F.pdf ____________________ 2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900 |
| sausagepartyb... |
 Posted: 07:40 - 04 May 2016 Post subject: |
Thanks! this will be very handy.
So I bought whole clutch assembly from 1998 reg. same as mine, but casing itself is a bit longer, friction metal plates thicker and that arm in the middle, one that clutch cable is pushing in and out is shorter. Is it still compatible? How can same year models have different size clutches? |
| Suntan Sid |
 Posted: 10:25 - 04 May 2016 Post subject: |
Assuming you don't have an impact driver, rattle gun or specialist tool, (that Stinkwheel mentioned), to remove the centre nut.
Part of the reason that you can't undo the center nut is that without the springs being bolted in place the clutch is not engaged and will always want to turn/slip.
When I reassembled mine I had the same problem.
I put the end plate back on and tightened the springs down.
Unfortunately this meant that I couldn't get the socket through the end plate, to get it on the center nut.
I removed the springs and end plate, put the sockect on the center nut and put the springs and end plate back on over the socket, the thinner neck of the socket fitted through hole in the end plate.
If you can get the socket in place like this, do what you've been doing, put the bike in gear, lock the back wheel and apply the rear break, (if you've got a willing helper).
Try and use a breaker bar, not a ratchet, as already stated.
This was done on a different engine to yours so it might not work, it depends on the clearances around the socket! ____________________ "Everybody needs money, that's why they call it money!"  |
| sausagepartyb... |
The last post was made 10 years, 122 days ago. Instead of replying here, would creating a new thread be more useful? |
