| Fladdem |
 Fladdem World Chat Champion
 Posted: 23:01 - 03 May 2016 Post subject: NC 31 Reg/Rec issue? |
Hi, I've heard about Honda reg/rec issues on nineties bikes and I was wondering what the symptoms were?
I've tried googling and apart from the obvious flat battery and not charging, I can't find much on it.
Since early October, I've had an intermittent fault with the Super Four. While going along, the power will just drop off and I'll end up crawling to a halt, feels like someone knocks the kill switch. I'll get off and wait for a bit, then it'll bump after about 15 minutes and I'll get to ride it for about 5 minutes before it dies again. As if something is cooling down.
I genuinely believe it's the reg/rec as the battery doesn't seem to charge itself while riding, it happens more when it's a warm day, and it doesn't seem to cut out when I have a fully charged battery.
Basically, I just want confirmation
Thanks.  ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
| Hong Kong Phooey |
| jaffa90 |
 jaffa90 World Chat Champion
 Posted: 00:44 - 04 May 2016 Post subject: |
| Fladdem |
 Posted: 23:01 - 19 Jun 2016 Post subject: |
After weeks of messing around and not doing anything with the bike, it would appear, I had a duff rectifier to begin with, after testing. I then ordered up a new rectifier and got a new battery for it.
Messing about again today, it's still not charging at the battery.
I'm looking at about 33-34V at the alternator, at about 3,000RPM, there's a strong earth everywhere, the new reg/rec tests fine, as far as I can tell.
I then had a thought that the one on the Varadero 125 might be the same, I don't think it's identical, it doesn't quite fit in the gap, but when the earth is bolted up and it's plugged in, the battery is charging at about 14.5 volts, as expected.
Is it possible to get a duff rectifier? Could the 34V from the alternator be too much for the regulator and it's fried it again?
Without the battery connected, it wouldn't rev at all, so at tick-over, with the new reg/rec, not the Varadero reg/rec, the voltage at the battery cable terminals was only about 9 volts, would that point towards a brand new duffer?
Thanks
I need to work on my electrical knowledge more, I think it should be fairly easy in theory. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| smallfrowne |
 smallfrowne Scooby Slapper
 Posted: 10:08 - 22 Jun 2016 Post subject: |
if the varadaraderio one works then aye, looks like a duffer to me
Look out for a MOSFET R/R on ebay. I managed to get one for about £20. They don't run so hot so live longer in the daft places that Honda liked to put them (lack of cooling).
Rectifiers on a lot of bikes are made by shindengen, probably almost exclusively. There's a code printed on the side, if it says FH020, FH012, or SH775 it will be a mosfet, but this is obviously not a definitive list, I just can't remember the full details - but there is an arse load of info on google, probably too much. You only have to type FH020AA to bore yourself senseless.
MOSFET R/R's were fitted to later R1/6's, kawasaki ninja things, you know, newish sports bikes, so there's a few about, and a few with spade connectors (what I managed to get), not the fancy (but pricey) waterproof blocks. I fitted mine to the NC30. ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
| smallfrowne |
| Fladdem |
 Posted: 07:20 - 23 Jun 2016 Post subject: |
The original was an SH609-12
The new one I got has SH603-12 on it, but it all plugs in and has fins, unlike the original, which was definitely fried.
The Varadero R/R no longer works, at 3000 RPM, I'm getting 12.8V, which is battery voltage, I may have ruined that one now.
I am beginning to suspect something else at fault. As far as I'm aware, the charging system is basic, generator to R/R to battery, with no relays or anything in the middle? I am certain I have good earths, I've cleaned them all up, I don't have any wire breakages, good continuity everywhere, I'm confused and scared now.  ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| Meatybeaty |
 Meatybeaty World Chat Champion
 Posted: 08:07 - 23 Jun 2016 Post subject: |
Have you got a Workshop manual  |
| Robby |
 Robby Dirty Old Man
| Matt B |
 Matt B World Chat Champion
The last post was made 10 years, 97 days ago. Instead of replying here, would creating a new thread be more useful? |
