Dead battery, not so dead alarm.
Troglet
PostPosted: 08:51 - 04 May 2016    Post subject: Dead battery, not so dead alarm. Reply with quote
So I left the keys in my Daelim Daystar 125 and drained the battery, no big deal, I have a charger and have done this before.
However It wasn't completely dead as this time, unlike before, once I removed the battery the alarm started going off and couldn't be stopped, the key fob just stopped it for 30 seconds and it started right back up again.
Reconnecting the battery did nothing as, I'd imagine, it didn't have enough power to do anything.
Long story short after an hour the alarm tone changed from a series of chirps to a different, slower series of chirps to finally a single chirp per second, we put it inside and let the alarm drain its backup battery overnight while the battery trickle charged.
Come this morning, go to hook it all back up again and soon as the battery gets connected, alarm goes off continuously and without being able to turn it off again with the key fob at all, had to remove battery and let it drain itself again, thankfully it didn't take long.
Now before I removed the battery again this morning I tried to start the bike up however no electrical response what so ever came from the bike other than the alarm starting back up again, no lights no nothing.
All that changed when the key was turned was the tone of the alarm from the 1 per seconond chirp to a more alarm-y series of chirps. Not sure what this means.
Things of note:
Bike: Daelim Daystar 125 2011 reg "Black Plus" (note, no kickstarter on this bike)
Alarm: DataTool S4 or S4C, I believe it's the "red" model, I wasn't the owner of the bike when it was installed.
I'm really very poor and very unable to pay the £100 minimum it'd cost to get this thing dragged to a garage and fixed, even assuming nothing needs replacing.
How can I reset the alarm, or indeed remove it entirely, without killing the bike?
Is the bike already dead?
Edit~ also of note, my general skill/knowledge level is for bikes is pretty low however I do know a lot about computers so if someone out there has a dead PC and wants to trade knowledge/time I can probably work out what's wrong with your PC.
For whatever that's worth.
Nash GT
PostPosted: 09:10 - 04 May 2016    Post subject: Reply with quote
The alarm has a built in backup battery, designed to keep the alarm going should the perps attempt to override it by disconnecting the main battery.
Here is the manual for your alarm, hope it helps
https://www.datatool.co.uk/PDF/S4C1-User-Guide.pdf
Suzuki GSF600N
Troglet
PostPosted: 09:17 - 04 May 2016    Post subject: Reply with quote
indeed it does, and I can tell you from first hand experience that it lasts approximately three hours and is really quite loud.
thank you I will read through it.
arry
PostPosted: 09:27 - 04 May 2016    Post subject: Re: Dead battery, not so dead alarm. Reply with quote
I'm chuckling at the concept of an S4 alarm that's probably worth more than the bike being the thing giving you problems Laughing.
Anyway - I can confirm that there's no bloody way of making the siren shut the hell up until you've got the battery back on there and charged so that the system can operate. In all honesty, I ripped my S4 out as it fried its own electrics unexpectedly one day and left me stranded at a mate's house. I'd not chance that happening again so it'd be in the bin if it was mine.
Troglet
PostPosted: 09:39 - 04 May 2016    Post subject: Re: Dead battery, not so dead alarm. Reply with quote
I can physically see it, and it is indeed the S4C, and according to the service history last guy paid £380 for it, I pay less than that in insurance lol. You're telling me I can just grab something sharp and cut that fucker out? because that was literally my first thought when the damn thing broke.
I'm not going to do it right away, because it seems drastic but you know.
arry
PostPosted: 09:45 - 04 May 2016    Post subject: Reply with quote
Afraid it wouldn't be that simple. On the Triumph it was factory fit so it had a factory fit harness on it, which plugged into the loom. Once it was removed, I needed a bridging plug to re-make the connections for the starter as the loom was now 'open ended'.
As it turned out, that bridging plug only connected two pins, so in essence the alarm was as effective as a thief knowing which pins to bridge - would have taken them all of a couple of minutes to work out, at best.
If you cut the alarm out, you'll need to rejoin the wires as they were originally connected; otherwise you'll have no power to the starter.
Troglet
PostPosted: 09:57 - 04 May 2016    Post subject: Reply with quote
Oh if only. It would have felt good to do. This thing is, predictably, tucked up nice and snug under the fuel thank towards the front of the seat. I'm going to look through the bikes manual and see about removing the seat to get a better look at it.
Removing this thing the long way seems tedious, I'm going to also look up how to just bypass the dumb thing. These things can't be perfect, lockpickers, hackers and general miscreants should have figured this out.
monkeybiker
PostPosted: 10:25 - 04 May 2016    Post subject: Reply with quote
I couldn't be arsed to research how to remove the alarm so paid a garage £50 to remove it. Worth every penny, should have done it years ago.
Only reason to have an alarm is if you have to park outside.
Snowdonia Rider
PostPosted: 11:04 - 04 May 2016    Post subject: Reply with quote
Ah one of the many reasons I would never ever have an alarm and/or an immobiliser on a bike Smile You never hear anything but trouble with them.
Troglet
PostPosted: 12:35 - 04 May 2016    Post subject: Re: Dead battery, not so dead alarm. Reply with quote
I tried that this morning and I got nothing but another earful. Although the battery had only been on charge 5 or 6 hours and had yet to fill, perhaps not enough? left it on charge all day so far today too when it fills up will give another try. Hopefully that'll fix it.
Troglet
PostPosted: 09:25 - 06 May 2016    Post subject: Reply with quote
Tried twice more, first time it just set off the alarm and the key fob did nothing but flash a red light when I press the button, did the whole remove battery let it die thing again, then maybe 30minutes later tried again, this time no electrical response what so ever, not even alarm.
is it dead?
I really need help here guys this is my only form of transport and without transport my job opportunities are very limited, I was banking on getting some work before this thing died on me.
basically all of the improving my employment prospects I've done in the last year are useless if this thing dies on me.
monkeybiker
PostPosted: 16:40 - 06 May 2016    Post subject: Reply with quote
I know you say you are skint but if you need the bike for work then pay to get it removed. Maybe have a look on gumtree, you might find some Polish guy who will do it cheap.
It's not a big job for someone that's knows what they are doing. Your looking at about £50.
arry
PostPosted: 18:52 - 06 May 2016    Post subject: Reply with quote
Get it all apart. You'll probably find it needs all of 3 wires redoing to remove it.
Troglet
PostPosted: 04:32 - 07 May 2016    Post subject: Reply with quote
I don't have £50. you know how you hear about people living below the poverty line in the uk? I'm one of those. Not a penny to my name. it'll take a good month or two to get the extra funds to pay to get it fixed. Also it's £50 for the hours labor and another £50 for pickup, unless I push it a couple miles to the garage.
Looks like this isn't something that can be diagnosed over the internet. Thanks anyway though.
arry
PostPosted: 07:53 - 07 May 2016    Post subject: Reply with quote
Just get it all apart so that we can see the wiring. If a monkey has fitted it it'll be as obvious as hell which wires you'll have to reconnect.
Couple of hours max with very basic tools mate. Give it a go yourself. Nothing to lose.
arry
PostPosted: 08:04 - 07 May 2016    Post subject: Reply with quote
Have you read the manual yet? I've just scanned it and there's a number of possibilities including it being in sleep mode which needs a different sequence of button presses to reactivate it properly with the remote.
Troglet
PostPosted: 09:12 - 07 May 2016    Post subject: Reply with quote
I have read it yeah, if it was in sleep mode when I turn the key it should start beeping, at which point I'd have to press the keyfob to stop the alarm going off, but right now it doesn't do anything when I put the key in and turn, no response from fob, no lights no nothing.
I've also tried a bunch of the button press sequences from the manual and gotten no response. I think the alarm is bricked and in turn bricked the bike.
I'll take the seat(s) off and whatever else to get a better look at the wiring tomorrow morning, it's too hot and I'm still quite angry at it for the moment. plus I live above a pub and cant have bike parts strewn about the beer garden when customers show up.
but you're right, I am going to give it ago myself. Nothing to lose.
I'm on the hook for the insurance money if the bike functions or not.
monkeybiker
PostPosted: 10:11 - 07 May 2016    Post subject: Reply with quote
Just a guess but you say the battery went flat and the alarm has a back up battery that went flat. Would the back up battery need to be replaced for the alarm to work correctly?
Troglet
PostPosted: 10:37 - 07 May 2016    Post subject: Reply with quote
sounds reasonable, however the first time reconnecting the battery woke the alarm back up for a good half hour, and with only being connected for maybe a minute which would lead me to believe it was draining the main battery to recharge the backup.
Perhaps it only has so many recharges in it before it's done and I've reached that limit. Not sure.
As I say, Tomorrow morning I'm going to take it all apart and get a good look at the wiring, post a picture or two etc. Best I can see right now the alarm itself seems to have come loose from the glue/tape that was holding it in place beneath the fuel tank, maybe a wire wiggled out.
Hopefully it's a simple fix.
I'm just angry at it really.
Troglet
PostPosted: 18:39 - 07 May 2016    Post subject: Reply with quote
WOO. I got lucky, random punter in the pub happened to be bike nut, fixed it in 15minutes, bought him a pint, problem solved.
He reset the alarm and also fixed a wiring issue with it.
Thank you all for the help.
Dave70
PostPosted: 22:34 - 07 May 2016    Post subject: Reply with quote
Made up for you mate. Thumbs Up
The last post was made 10 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 115.1 Kb
