Networking: Split an RJ45 connection
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
Bubbs
PostPosted: 11:18 - 04 May 2016    Post subject: Networking: Split an RJ45 connection Reply with quote
Good morning,
Hoping for some help. I work up on a windfarm site and our site cabins have only got 2 RJ45 connections providing internet access that are connected to a router/switch/hub (not sure which) from another cabin on site.
So we want more connections but want to avoid having to get new connections directly from the main router/switch/hub.
Is it possible to put one of our network cables into a switch/splitter and split it amongst more connections?
Thanks
CaNsA
PostPosted: 11:22 - 04 May 2016    Post subject: Re: Networking: Split an RJ45 connection Reply with quote
https://www.ebay.co.uk/itm/371580612295
or
https://www.ebay.co.uk/itm/272223475826
depending on how many you need.
Bubbs
PostPosted: 11:24 - 04 May 2016    Post subject: Re: Networking: Split an RJ45 connection Reply with quote
or
Thanks Thumbs Up
Bubbs
PostPosted: 11:29 - 04 May 2016    Post subject: Reply with quote
Does the switch allow all to use the same connection at the same time?
CaNsA
PostPosted: 11:32 - 04 May 2016    Post subject: Reply with quote
Yep, I use a similar bit of kit for my network here.
Bubbs
PostPosted: 11:34 - 04 May 2016    Post subject: Reply with quote
Perfect. Thanks.
(You coming to BBQ this year?)
CaNsA
PostPosted: 11:36 - 04 May 2016    Post subject: Reply with quote
Not sure, depends on funds and a few other factors.
PostPosted: 21:26 - 04 May 2016    Post subject: Reply with quote
CaNsA wrote:
Fuck yes.
Good man.
mudcow007
PostPosted: 11:59 - 06 May 2016    Post subject: Reply with quote
you can split a cable, but then you are limited to only 100mb (just use 2 pairs instead of the 4)
Im having to remove them from our factory though as we are now all gig except whey "they" are.
hope that helps?
Bubbs
PostPosted: 10:26 - 18 May 2016    Post subject: Reply with quote
Hardware purchased and all working. Just one more question - we have too network feeds, would plugging these into the netgear switch give more MB/Sec speed?
May be a stupid question but I have no idea.
PostPosted: 12:41 - 18 May 2016    Post subject: Reply with quote
No it won't.
I wouldn't want to be plugging 2 feeds in with no actual config either, likely its just a dumb switch currently so only bother plugging one in.
CaNsA
PostPosted: 12:43 - 18 May 2016    Post subject: Reply with quote
No it won't.
Tis true.
A load balancing router would do the job, but they can be a real ballache to setup correctly and TBH, I doubt you would even need the extra speed.
GBit lan is fast enough for 99% of all applications.
Bubbs
PostPosted: 14:33 - 18 May 2016    Post subject: Reply with quote
Thought it might be. Nice one, thanks.
/thread
Bubbs
PostPosted: 13:14 - 22 Jun 2016    Post subject: Reply with quote
THREAD REOPENED
So the netgear switch gives me 2 extra connections but any more cables connected wont give me internet access.
What could be the issue here?
I haven't currently installed the installation CD that came with the switch as it's a work computer which requires permissions for any installations.
HELP!?
CaNsA
PostPosted: 13:36 - 22 Jun 2016    Post subject: Reply with quote
Hopefully someone else can guide you through it, I'm out of the country atm.
There's no need to use the cd, open chrome and goto 192.168.0.1
Loui5D
PostPosted: 13:49 - 22 Jun 2016    Post subject: Reply with quote
Which switch did you get?
When cables are plugged in do any of the light's come on? If so which ones.
Bubbs
PostPosted: 15:13 - 22 Jun 2016    Post subject: Reply with quote
If a new cable is plugged in and connected to a laptop then the lights come on and flash green.
It's a Netgear ProSafe Plus Switch GS108E
192.168.0.1 doesn't seem to do anything.
PostPosted: 16:26 - 22 Jun 2016    Post subject: Reply with quote
I wonder if one of the other bits of hardware are on that same IP. It's a common default setting.
Also. have you tried turning it off hten on again? Laughing
Loui5D
PostPosted: 16:29 - 22 Jun 2016    Post subject: Reply with quote
According to Netgear's site it should be running on 192.168.0.239, try and access that.
TBH looking at the cd program thingy it looks pretty simple to setup.
https://www.downloads.netgear.com/files/ProSafe_Plus_Utility_3_0%20_UM_23Sept10.pdf
CaNsA
PostPosted: 16:46 - 22 Jun 2016    Post subject: Reply with quote
My bad. Sun, beach and beer made me think this was the thread that someone bought a wndr3700 router.
bigtin
PostPosted: 22:04 - 22 Jun 2016    Post subject: Reply with quote
Bubbs wrote:
THREAD REOPENED
HELP!?
Quite likely that someone has configured port security on the upstream switch to limit you to 3 MAC addresses connected at a time.
Also, never connect both of the ports from the other building to that one switch. If you have a poorly configured network, you'll really piss people off.
Bubbs
PostPosted: 09:18 - 23 Jun 2016    Post subject: Reply with quote
Any way around this?
Also didn't do anything. IT department won't allow me to install the CD that came with it as it's not official company authorised hardware I'm using... Bunch of pricks.
orac
PostPosted: 09:27 - 23 Jun 2016    Post subject: Reply with quote
are you sure its a managed switch. unmanaged wont have an accessible IP address.
Bubbs
PostPosted: 09:42 - 23 Jun 2016    Post subject: Reply with quote
How would I be able to find out if it's managed/unmanaged? I just bought it - have no clue about networking hardware.
Bubbs
PostPosted: 10:13 - 23 Jun 2016    Post subject: Reply with quote
If I'm limited to 3 mac addresses and have 2 feeds then I could get two switches which would give me a potential 4 connections, right?
1 feed in one switch, 1 in another switch with 2 outputs from each switch.
This would give me enough for my needs. Any flaws in this logic?
The last post was made 10 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 126.74 Kb
