Stuck valve cover *now not stuck*
Yorkshire Geek
PostPosted: 15:56 - 04 May 2016    Post subject: Stuck valve cover *now not stuck* Reply with quote
I'm trying to check the valve clearances on my XJ600S Diversion but the valve cover is stubbornly refusing to move. I've taken the bolts out and hit the edges with a mallet but the bloody thing won't shift. Looking at the bolts and surrounding area I suspect it's never been off in it's entire 20 year life.
With my fists of ham I could almost certainly bray it harder and probably break it but I'm hoping the BCF denizens can suggest a less destructive route.
iooi
PostPosted: 16:29 - 04 May 2016    Post subject: Reply with quote
Something slim under the edge (into gasket) to break the seal. Thin knife might do it.
Unless of course some previous owner has not used a gasket and used gasket seal to lock it down Rolling Eyes Twisted Evil
PostPosted: 16:48 - 04 May 2016    Post subject: Reply with quote
Be careful I wouldn't use anything metal unless there are any specific point designed to be prised. I'd try using plastic car trim removal tools.
MCN
PostPosted: 17:23 - 04 May 2016    Post subject: Reply with quote
Hair drier to heat up the joint. (Not the 20s Speak-Easy sort of Joint.)
Constant gentle leverage over a wide area will persuade the goo to give it up.
You need to be careful of 'point loading' the cover or head in case you bend or crack them.
Check the parts book to see how many screws/nut hold it down. Count how many bolts/nuts in your hand. Embarassed
Yorkshire Geek
PostPosted: 17:43 - 04 May 2016    Post subject: Reply with quote
8 listed, 8 in foil tray.
Will get the hair dryer out later and have a go with that.
Yorkshire Geek
PostPosted: 19:25 - 04 May 2016    Post subject: Reply with quote
To clarify - if I do use a prying implement do I want to be prying the gasket and valve cover up away from the engine or the valve cover away from the gasket?
ADSrox0r
PostPosted: 19:28 - 04 May 2016    Post subject: Reply with quote
Probably won't matter if you pry it open with pointyness, the gasket will need replacing.
PostPosted: 19:29 - 04 May 2016    Post subject: Reply with quote
I use a rubber mallet for jobs like this.
Yorkshire Geek
PostPosted: 20:07 - 04 May 2016    Post subject: Reply with quote
So did I but I failed, care to give any pointers on use of said mallet? "Twat it" is about all I know on this one.
jaffa90
PostPosted: 22:33 - 04 May 2016    Post subject: Reply with quote
A seal is a seal,
I agree with MCN.
Fizzer Thou
PostPosted: 11:01 - 05 May 2016    Post subject: Reply with quote
This.
I also use a dead blow mallet for those that are particularly stubborn,like that on the FJ1200 I am working on atm.
Always have a 'Plan B'
Yorkshire Geek
PostPosted: 11:05 - 05 May 2016    Post subject: Reply with quote
Hair dryer and mallet combo did it, unfortunately there's not enough clearance to get the fucker off so now I need to drop the oil and remove the radiator. That's bloody irritating.
Yorkshire Geek
PostPosted: 13:14 - 05 May 2016    Post subject: Reply with quote
To get the valve cover off I ended up removing the following...
Seat
Fuel tank
Air box
Carburettors
Windshield
Indicators
Fairing
Oil drain and remove oil filter.
Radiator
When I finally got inside I found 6 of the 8 clearances out of tolerance, not sure how happy I am about that on the one hand it means I have more to do before I can re-assemble it, on the other hand it means this wasn't a total waste of time.
Now to work out how to get these shims out...
Yorkshire Geek
PostPosted: 12:30 - 07 May 2016    Post subject: Reply with quote
Got the buggers out using the method in this thread and some eyebrow tweezers (she'll never notice).
Used Pete's calculator to work out which ones I want and with some shuffling that leaves me with two shims to buy so now waiting on the internet.
Much as this is a pain in the arse i know my bike a lot better now and i haven't put £125 into someone else's pocket.
The last post was made 10 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 81.43 Kb
