Suzuki GS650 Shaft oil check
killa
Won't Shut Up
PostPosted: 11:23 - 05 May 2016    Post subject: Suzuki GS650 Shaft oil check Reply with quote
Could someone tell me the best way to check the oil level for my shaft drive on an '86 Suzuki GS650?
Which type of oil would I use to top up or change? Thumbs Up
PostPosted: 11:26 - 05 May 2016    Post subject: Reply with quote
I think they have a level plug. I.e. undo the plug and fill it till it comes out.
killa
Won't Shut Up
PostPosted: 11:27 - 05 May 2016    Post subject: Reply with quote
Right, so with the bike absolutely upright, that's the level...
How would you change it completely?
davebike
PostPosted: 11:34 - 05 May 2016    Post subject: Reply with quote
Pull drain plug at bottom leave draining a little to flush replace drain plug over fill and allow to drain to level (bike upright )
Used to be 90 oil these days 75/90 a better choice
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 11:37 - 05 May 2016    Post subject: Reply with quote
I assume there is a drain plug. Dunno if this is the same bike.
https://www.fowlersparts.co.uk/parts/5286416/gs650gt-d-1983/propeller-shaft---final-drive-gear
I'd say 29 is the drain plug and 27 is the fill level. Check this though I ain't certain, I have not worked on one of these. Can't see where you would fill it though...
davebike
PostPosted: 11:43 - 05 May 2016    Post subject: Reply with quote
27 is fill level
29 drain
Dave Suzuki trained mechanic done Hundreds
Dave
[email protected]
killa
Won't Shut Up
PostPosted: 12:25 - 05 May 2016    Post subject: Reply with quote
davebike wrote:
27 is fill level
29 drain
Thanks bud. What oil and how much will I need for a full change?
Is there an online reference I can view in future for my bike?
Thanks Thumbs Up
davebike
PostPosted: 12:34 - 05 May 2016    Post subject: Reply with quote
A couple of hundred CC never worried how much over fill allow to drain to level
The on line DB I use Is pro and paid for
I expect the on line free stuff for a bike this old google is you friend but takes time
Dave
[email protected]
killa
Won't Shut Up
PostPosted: 12:41 - 05 May 2016    Post subject: Reply with quote
Ok, and is it just standard gearbox oil..?
davebike
PostPosted: 12:42 - 05 May 2016    Post subject: Reply with quote
Yes Hypoid (SP) 80 in winter 90 in summer just use 90 or better still modern 75/90
Dave
[email protected]
The last post was made 10 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 67.14 Kb
