| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| Matt B |
 Matt B World Chat Champion
 Posted: 14:21 - 08 Dec 2015 Post subject: |
I did build one for not very many pounds. The thread is here https://www.bikechatforums.com/viewtopic.php?p=3465608
https://i1077.photobucket.com/albums/w462/MattB70/IMG_2216_zpseeb5a9b1.jpg
Mine used an unwanted PC that was donated and a cabinet that came from Gumtree. The cabinet had an old wiring loom, the monitor and speakers included which made it easier. Once MAME was up and running on the PC it was just a case of drilling holes for the joystick and buttons and wiring them into the encoder.
One thing I did add afterwards was an Act-Labs light gun for shooting games. An easy job with a box that plugs between the PC and the CRT monitor and a USB connection.
I sold it eventually. Being a full size cabinet it took up too much room and the construction under the plastic bezel meant that there was no room for dual controls. If I was going to do it again it would be a much smaller build. I did look at running it with a Pi but the PC was a freebie so I went with that. ____________________ stinkwheel: He had an animated .gif of a cat performing fellatio. It's not socially acceptable. It can have real life adverse effects on other people. |
| andym |
 andym World Chat Champion
| BumpingUglys |
 BumpingUglys Trackday Trickster
 Posted: 21:24 - 08 Dec 2015 Post subject: |
Not so much a build as a conversion. Still a work in progress but here's my efforts so far with an old 1978 Space Invaders II table I've had kicking about since the mid 90's.
https://i100.photobucket.com/albums/m6/Bumpinguglys/DSC_0267_zpsvcigbas2.jpg
Player 2 side. Sanwa microswitch joystick, 3-way button (same as the one on Matt's but painted with acrylic) and a single button 4.
https://i100.photobucket.com/albums/m6/Bumpinguglys/DSC_0268_zpsyrhmxwyh.jpg
Player 1 side: Ultimarc Ultrastik analogue joystick (based on Sanwa hardware), 2 full size buttons (red), 4 low profile (black). The fascia has been removed from this side to accommodate the buttons and everything mounted onto MDF.
https://i100.photobucket.com/albums/m6/Bumpinguglys/DSC_0269_zpsimzmjykv.jpg
Inside: Stripped 15" monitor screwed directly to the lid. Wooden batons supporting an old gutted PC. Rats nest wiring from the Sanwa joystick and some remaining original electronics (P1, P2, Coin) soldered to cannibalised PSX controller plugged into USB converter plugged into PC... PSU and speakers are in the base. Intake fan on the left hitting the CPU, Northbridge, memory and HDD, exhaust fan on the right.
https://i100.photobucket.com/albums/m6/Bumpinguglys/DSC_0270_zpsk3lm3gqx.jpg
Inside: Can really appreciate the difference between the Ultrastik and the Sanwa here. No fannying about with converters or creative wiring, the Ultrastik plugs directly into USB and has its own wiring loom supporting up to 8 buttons, with the 8th also acting as a 'shift' button, to give 15. It was expensive but I can't recommend it enough. Analogue too, so it's good to go for Outrun, Hang On etc.
Think the CPU is an Athlon 64x2 6000, graphics is a Geforce 560TI (not that it makes a difference in MAME), 4GB ram if memory serves. Performance is pretty good up until mid-90s polygon-athons or processor heavy roms; Ridge Racer and Gauntlet Legends spring to mind. The Front End I use is MALA; everything is controllable via joystick and buttons, just have it auto start from Windows.
The monitor is a bit small, but I wasn't prepared to mutilate the lid; you sit very close anyway so no biggie. Most two player games will run in cocktail mode, so horizontal split-screen with the 2P flipped and it works surprisingly well.
There's around 4000 games on there, and that's a pretty pared down list. Realistically 200 would be more than enough, there really is a lot of shit old games as well as the classics. ____________________ Ducati M695 |
| UnknownStuntm... |
 Posted: 12:26 - 28 Jan 2016 Post subject: |
Update!
Got buttons, controller, screen, speakers, tiny ic amp, Raspberry Pi running RetroPie etc, etc, etc.....
I love routers. They win woodwork. I also suck at woodwork.
https://i.imgur.com/sLCXSbh.jpg |
| BumpingUglys |
| UnknownStuntm... |
 Posted: 10:54 - 29 Jan 2016 Post subject: |
I hashed up the controls on a panel when they first arrived to make sure the interface worked. But not in it's present form, that's Saturday night's goal.
The screen I bought was a gem - it's got a powered USB hub and a 12v output for a sound bar type effort. Which is perfect for running the marquee light strip and the audio interface. Might even have enough oomph to run the Pi too, but I'm not expecting miracles.
Once I confirm all the electronics work, I need to rip it apart again, make some proper sides for it with 2mm deep slots for the panels to rebate into, then final assembly, fill, paint, fill, paint, fill, paint, vinyl wrap. |
| UnknownStuntm... |
 Posted: 18:05 - 15 Feb 2016 Post subject: |
Update time!
I've spoken to a couple of signwriting people about getting some pretties for the sides etc. I've got a Donkey Kong marquee in the post so far, I guess the theme is set now (I clearly remember Donkey Kong was the first Atari 2600 game I played on Christmas day in ... er ... 1982?)
I need to put an IEC socket for the power, with a small isolation box inside, and a back panel with magnets holding it together, but most of the work is done!
https://i.imgur.com/xuIlOTJ.jpg |
| Matt B |
 Posted: 20:07 - 15 Feb 2016 Post subject: |
Looking good so far. Like the fact it's small and tabletop.  ____________________ stinkwheel: He had an animated .gif of a cat performing fellatio. It's not socially acceptable. It can have real life adverse effects on other people. |
| UnknownStuntm... |
 Posted: 09:38 - 05 May 2016 Post subject: |
It's done!
I'm way happy with the results. It's amateur, but I never wanted it to look like it was bought from a shop. Things I've learned include: buy a high resolution laser printer and sticky background stock. It's far easier to do that than ask a company to print for you. I used 3 companies and each one managed to get the print wrong the first time, despite an exact spec being given.
Loads of people are asking if I'll do them one, and I can't help but want to do it again - so there might be another one in the wings some time!
For now though I'll be wrecking my wrists and driving the neighbours batty with the shouting and the 8 bit toons etc.
Anyway, here's a pic:
https://cdn.bcf.44bytes.net/files/img_20160504_201949.jpg |
| Minty |
 Minty World Chat Champion
| ride_to_die |
 ride_to_die Crazy Courier
| MarJay |
 MarJay But it's British!
| Matt B |
| UnknownStuntm... |
| UnknownStuntm... |
| Ichy |
 Ichy World Chat Champion
 Posted: 22:04 - 05 May 2016 Post subject: |
| UnknownStuntm... |
 Posted: 10:19 - 07 May 2016 Post subject: |
So I made the front page of Reddit yesterday! Lol. Build pics and some detail here:
https://m.imgur.com/a/0Y2aX |
| fatjames |
 fatjames World Chat Champion
 Posted: 12:30 - 09 May 2016 Post subject: |
Nice write up mate. I like what you've done and hope you enjoy playing with it.
Anything you would do differently if you started over? |
| UnknownStuntm... |
The last post was made 10 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
