Bike won't travel straight
DevonDtr
PostPosted: 01:51 - 05 May 2016    Post subject: Bike won't travel straight Reply with quote
Hi, have an 04 yam dtre 125, had a new front wheel bearing and tyres, new pads in a hope to cure this problem! Basically when I let go of bars the bike leans to right, and when I use front brake it goes left!! Where else mechanical wise can I look..
Tamsin
PostPosted: 02:11 - 05 May 2016    Post subject: Reply with quote
Twisted subframe and slack chain Laughing
How severe is the "dive" and is the rear wheel properly aligned and secured? Have the wheel bearings been done properly and are they in good condition on the rear wheel? When moving the handlebars side to side is it nice and smooth or is there any notchyness or rough feeling?
DevonDtr
PostPosted: 09:32 - 05 May 2016    Post subject: Reply with quote
Everything's tight and as should be, was told rear bearings are fine. Its that bad that I have to sit off the bike to the left. Handlebar movement does feel rough
jaffa90
PostPosted: 09:44 - 05 May 2016    Post subject: Reply with quote
Have somebody balance the bike until the wheels are vertical with a spirit level and then see / feel if the bike wants to topple over.
Tamsin
PostPosted: 12:03 - 05 May 2016    Post subject: Reply with quote
if handlebars feel rough then head bearings need changing, that's not going to help the situation
weasley
PostPosted: 12:28 - 05 May 2016    Post subject: Reply with quote
Is the rear wheel straight in the swing arm? And the swingarm straight on the frame?
I would also mention twisted front forks but if the wheel's been out for bearings I'd assume it wouldn't go back together with exactly the same wrongness as before.
DevonDtr
PostPosted: 13:11 - 05 May 2016    Post subject: Reply with quote
Well measuring things up, and excuse my lack of knowledge here, the bit where the bars clamp on is higher on left side so something bent up there : )
mudcow007
PostPosted: 16:14 - 05 May 2016    Post subject: Reply with quote
Are your arms the same length?
supZ
PostPosted: 16:20 - 05 May 2016    Post subject: Reply with quote
Perhaps his right arm is far more muscular than the left..
CBR954RR - Daily toy
CBR600RR - Trackbike
jaffa90
PostPosted: 16:35 - 05 May 2016    Post subject: Reply with quote
Well balance the bike and measure both bar ends to a level floor.
mrbox
Wonderwall
PostPosted: 16:54 - 05 May 2016    Post subject: Reply with quote
I thought I was the only one to run a different compound of renthal grip on the left and right Very Happy
Current bikes: RE Himalayan, Bandit 12, MZ250ES
Ariel Badger
PostPosted: 20:56 - 05 May 2016    Post subject: Reply with quote
To what side does Sir dress? Is Sir a larger gentleman?
PostPosted: 21:05 - 05 May 2016    Post subject: Reply with quote
The new wheel bearings, tyre and brake pads; they were worn out and in need of replacing or they were replaced in the hope that they were responsible for your bike not running straight?
DevonDtr
PostPosted: 00:20 - 09 May 2016    Post subject: Reply with quote
Wheel bearing replaced due to play in wheel play, pads and tyres because of wear.
zico
PostPosted: 00:25 - 09 May 2016    Post subject: Reply with quote
If your penis is large and hangs to the right then that's the problem. Try setting it straight on the tank.
Suzuki SV650S
jaffa90
PostPosted: 00:44 - 09 May 2016    Post subject: Reply with quote
You no answer first question, also get one wheel vertical and see if the other is as well.
The last post was made 10 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 85.17 Kb
