| MC900 |
 MC900 Nitrous Nuisance
| pepperami |
 pepperami Super Spammer
| Rogerborg |
 Rogerborg nimbA
 Posted: 22:22 - 05 May 2016 Post subject: |
Sable put 42,000 miles on his Chinese Sinnis Trackstar before the engine cracked, the oil escaped and it seized, I believe after being dropped. ____________________ Biking is 1/20th as dangerous as horse riding.
| Hong Kong Phooey |
| Guest |
 Guest
| Dave70 |
 Dave70 World Chat Champion
 Posted: 01:11 - 06 May 2016 Post subject: |
My R125, which I believe (could be wrong though) has the same engine as the YBR, only got to 30,000 miles before somehow (unbeknown to me) losing its oil in less than 300 miles one day. This lead to a very unhappy engine that didn't want to work anymore and tried to take me out in the process.
That bike had been very well looked after. It had a few more services than recommended and regular oil changes, more often than not, before the recommended 1,800 miles too.
However, there's a lot to be said for checking you oil level before every ride. as I'd have noticed there was an issue before it was too late. Instead I got complacent in knowing it would only need a small top up between 800-1000 miles.
I should probably add that it had been ridden pretty hard too over most of those miles.
Not sure if any of that helps actually, as I seem to have gone off on a bit of a ramble there.
is Tefs disease contagious?  ____________________ There ain't no devil, there's just god when he's drunk.
2012: R125 killed by white van. 2016 R125 killed by 30,000 miles of redline. Current: 2016 Kawasaki ER6f. |
| Guest |
 Guest
| temeluchus |
| mentalboy |
 mentalboy World Chat Champion
| Dave70 |
 Posted: 01:39 - 06 May 2016 Post subject: |
I'll get me coat.  ____________________ There ain't no devil, there's just god when he's drunk.
| Sable |
 Sable World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:42 - 06 May 2016 Post subject: |
| Sable wrote: | The good part of the Trackstar was, up to that point, the bike was mostly trouble free. |
And even parted, scrapped or just left in a ditch, the cost-per-mile would have worked out well.
I'd bet on a Chinese Jianshe-Yamaha "YBR 125" lasting longer than an Indian HMSI Stunner "CBF125". But I'm perhaps just being selectively racist. ____________________ Biking is 1/20th as dangerous as horse riding.
| B5234FT |
 B5234FT Brolly Dolly
| mentalboy |
| woo |
 woo World Chat Champion
| B5234FT |
 Posted: 13:19 - 06 May 2016 Post subject: |
| mentalboy wrote: | | B5234FT wrote: |
I bought my current car when it was 'dead' at 110k miles. It's done 190 now, but then I've replaced things like wheel bearings, dampers and bushes, which most nimbys regard as lifetime components. |
This isn't a car thread, so I'll apologise for being off topic!
Modern cars are barely run in by 100K (IMHO) I'd be pissed if my tiddly UK motors weren't capable of 250K - which is what I managed to get out of my crappy Citroen before selling it on.
My stepson's Ford SUV is over 400K and still running....
Look after your motors and they should last longer than if you don't. With the availability of spares for small 125's it should be possible to get big miles out of them, even if that means replacing everything except the frame over it's lifetime. Whether you can justify the costs against running a machine into the ground is another matter! |
This is my point, most people do the bare minimum oil changes and then when the car gets to 100k it needs springs, dampers, bushes, joints, bearings and so on all at once.
If you maintain things properly (preventitively) then they last almost forever. My bora is on 190k and tbh it will probably do the same again, but I'm bored of it after 100k so it's going to be someone elses soon.
So back to bikes:
If you buy a cheap 125 and do the bare minimum it will die eventually. If you buy it and look after it properly and replace things before they fail catastrophically then the same applies. People are suggesting 36k out of the engine? I'd expect to get that out of the chain..... |
| spottedtango |
 spottedtango Trackday Trickster
| B5234FT |
| Teflon-Mike |
 Posted: 17:11 - 06 May 2016 Post subject: Re: Life expectancy |
| MC900 wrote: | How many miles should we expect a well maintained 125 like a ybr last for? |
Maintenance = 'Maintaining the Functional Condition of the Machine'
Maintenance isn't just changing the oil and adjusting the chain and tappets... it would include doing re-bores when required, replacing cam-chains, renewing bearings, valve guides, or even when the copper has oxidised too much and the insulation gone so hard wires start breaking, completely re-wiring the electrics.
So, if you apply the strict definition of 'maintenance', a machine that is properly, well or even just sufficiently 'maintained' ought to last indefinitely.
In the real world, though, few if any vehicles let alone motorcycles, let alone 'budget' commuters ever are, when economics comes into play.
A bike is 'Beyond Economical Repair' when it is cheaper to buy another one, than fix any faults it has to 'maintain' it's functionality.
Labour cost of tearing down an engine to over-haul and re-condition it, in the UK even on a 'cheap' and simple engine like an air-cooled push-rod single like a CG125 motor, would usually be guaranteed to render a bike BER; you are talking maybe 10 hours of £30 per hour labour, plus maybe as much again in 'parts' depending on how much you need to replace. But £30-40 for a re-bore and as much again for a new piston & rings; add gaskets, possibly a ew cylinder head if it's cheaper than milling out ad replacing valve guides, and you could be looking at a £500 bill for that bit of 'maintenance' on an old bike probably not worth that much to start with.. so it can only be 'economically' maintained if you don't cost the labour ad DIY the job, or cut corners and put in a better 2nd hand engine or whatever.
Manufacturer's typical 'service life expectancy' of a 4-Stroke 125 commuter, is about 7 years, and perhaps 50,ooo miles.
They don't expect it to be assiduously 'well maintained'; they expect it to be 'economically' maintained, and it will only probably get eve that for the first year or two of the warranty period, or if lucky the first 3 years until the first MOT is due, and the bike likely to retain half its show-room sticker value. In that time, its likely to only cover 30,000 miles or so, and the odds that it will run reliably and not develop an expensive fault are in its favour. After that? Well, they probably don't care very much! But owner use ad maintenance will be far more significant as to how likely a 'problem' is to develop.
Buy a bike brand new; treat t well. Don't thrash it, be reasonably diligent in maintenance, and good chance you can avoid major or expensve issues for perhaps, 30 or 40 thousand miles or more, before you reach the point where more expensive 'maintenance' is probably required.
If thrashed, trashed or crashed? Its any-ones guess how long it might last.
A little air-cooled 125 in daily city commuter service, is likely to be pretty hard used. It will be accelerated hard (relatively) up and down the gear-box, changing speed between junctions and traffic lights and round-abouts, the suspension hammered by heavy braking dodging the SMIDSY's or weaving between queues of cars.. ad the rider on board, is likely to not be the most sympathetic; a learner who isn't too smooth or delicate to start with, and/or a commuter, who is more concerned with getting to work on time, than riding 'finesse'.
Under that sort of 'stress', a little 125 4T single, is likely to be doing pretty well to clock more than 40K miles before it's getting rather tired, and cumulative 'maintenance' threatening it's chances of staying out of BER, even if it is better looked after. Engine might not be so close to ding a full overhaul at that sort of miles, but brakes and suspension and transmission, are likely to do for it instead.
It's a piece of string question, to which there is no answer, really.
BUT, bought new, and well cared for, the rider applying more than typical mechanical sympathy both n riding and maintenance, I could say a YBR could reasonably be expected to last ten years, 50K miles or so.....
I have seen or heard of very few 125's or any sort that have ever managed to clock anything in that region though, that haven't had at least one major amateur over-haul, and 125's that are still running and capable of passing an MOT without, are doing well to get past 30K miles.
Most long lived I have ever come across was a 1983 Yamaha SR125; owned by an instructor from new. He bought it for his missus to learn on, and she only rode it for about three moths, and only to do her rider training, before she got her licence and abandoned it in the shed, where the instructor found it one morning, when pondering how to get to work when his own bike was in the dealer's for service.. and after a week, he 'adopted' it a his daily rider cos of the economy, and boosted the miles over that, using it to instruct on, pointing out that following newbs about on other 125' it was perfectly adequate ad he wasn't wearing out expensive big-bike tyres in the process! That bike had gone through 80K miles I think, ten years ago, and the other instructors were taking bets on whether it would go round the clock (99,999miles) before it broke on him. I don't know whether it made it, but I wouldn't be surprised.. but that is the 1 in a million odds beater to set the end-stops of what might be achieved, everything being stacked in that particular bikes favour from day 1, a better conscientious rider, with high standards of maintenance and diligence.
Believe its essentially the same engine in the YBR.. which suggests it has the potential for plenty of longevity, but still, anything over 50K is going to be doing well, and more reasonably, 30-40K is more likely service-life-expectancy. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| gbrand42 |
 gbrand42 Could Be A Chat Bot
| M.C |
 M.C Super Spammer
 Posted: 22:51 - 06 May 2016 Post subject: |
Wouldn't be that concerned with the engine (properly serviced) lasting to 60k, its all the other bits.
Just a general impression, but I see 30k for a bike as equivalent to 100k for a car, the sort of mileage where (depending on the model) you're somewhat going beyond what was expected for the bike.
Yes a CBR600F might get to 200k, but most bikes won't. I don't recall seeing 60, 100, 200k service intervals  |
| Dave70 |
| Robby |
 Robby Dirty Old Man
| M.C |
 M.C Super Spammer
| -Matt- |
 -Matt- World Chat Champion
The last post was made 10 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
