First Bike Helemt
dranac23
PostPosted: 14:50 - 06 May 2016    Post subject: First Bike Helemt Reply with quote
Wondering what i should be spending on my 1st helemt. They go from £100 +. Guessing 2/300?
PostPosted: 15:10 - 06 May 2016    Post subject: Reply with quote
It depends on what your requirements are.
The first needs to be fit. If it doesn't fit, then it'll either pinch like hell, or roll off your head, or pinch like hell then roll off your head. So until you're sure what size and head shape you are, you'll need to go and actually try some on.
If it's safety you're after, then you don't need to spend anything like that much. Have a look on https://sharp.direct.gov.uk/ which independently tests helmets. Some of the cheapest lids score as well as the most expensive: cheap, thick, relatively soft thermoplastic shells do the job just fine, or even better, than expensive, thin, hard composites. 5-star lids can be had for around £50. The good news is that even the worst modern helmets are still pretty good, and the difference (to your chance of survival) between the best and worse is fairly minimal.
If it's features you want, that starts adding cost. The one that I value most is "pinlock ready". This means that the visor has posts fitted that allow you to fit a "pinlock" visor insert. This acts as double glazing for the visor and helps to stop it fogging up.
Next, I look for "micrometric buckle". This is a system that allows for quick buckling, with adjustment, and quick release. This has the best parts of a "seatbelt" style buckle which is quick but a pain to adjust, and a "double-D" buckle which is great for adjusting, but a bit fiddly to secure and release. Double-D is the most secure though, if that bothers you.
Then there's a plethora of vents, internal sun visors, breath guards, closed face vs flip, noise considerations, and weight. If you want a lighter helmet, you'll have to pay for glass or carbon fibre shell.
tl;dr version - one that fits well and has the features that you want. Budget shouldn't be a primary consideration. And don't sweat it, you're unlikely to make a bad choice.
BTTD
PostPosted: 15:15 - 06 May 2016    Post subject: Reply with quote
Rogerborg beat me to it. What he said.
bigdom86
PostPosted: 16:05 - 06 May 2016    Post subject: re Reply with quote
whatever one fits you best I would highly recommended a pinlock ready one, got my 1st one and don't know how I rode without it, well I do know how its annoying raising your visor at every stop to clear fog
pablodrugsmul...
PostPosted: 16:59 - 06 May 2016    Post subject: Reply with quote
As Roger said it needs to fit, the SHARP helmet link he provided is an interesting one, ive had a look before out of interest for my helmet. I'm still on my first helmet which is an AGV K3 SV, i've found it to be comfortable, it came with a pinlock which id never do without and an internal sun visor, the warranty can be extended another year if you register it and i haven't had any problems with wind noise. As a bonus it has the gold sticker that means it will allow you on a track day should you wish to do anything like that and it has the easy to fit and remove buckle so you aren't fumbling around. As its a fairly old model they can be had for as little as £110 and in terms of actual protection they are rated reasonably well, if you want a more appealing design though youll have to fork out for it like i did. Personally i went to a store in person for my first helmet so i could try various sizes so i was happy it was the correct fit and i could gauge how comfortable it would be.
https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/223883
https://sharp.direct.gov.uk/testsratings/agv-k3-sv
M.C
PostPosted: 21:40 - 06 May 2016    Post subject: Reply with quote
Don't rate pinlock personally, get a helmet with a decent visor, and it'll be as good as a flimsy/cheap visor with a pinlock insert. Also they're crap at night, and can cause your visor to slam down if you have it open.
Lots of helmet bargains, I got a Nitro Aikido new for £20 off eBay, also when Amazon were clearing out their stock of Bell helmets they were only £45. Even at full price an Aikido's only £60, you don't need to spend hundreds.
Try before you buy, helmet sizing's all over the place, an XS with one brand can be bigger than a Medium with another. Also helmets tend to become a bit looser overtime, so you want a snug fit, obviously not so tight that it hurts your head.
PostPosted: 22:00 - 06 May 2016    Post subject: Reply with quote
Neat idea, can you list every helmet available in order of visor quality?
M.C
PostPosted: 22:38 - 06 May 2016    Post subject: Reply with quote
Neutral You can tell just by looking at them, but generally the Bell's/AGV's are better quality than your Box/Nitro's. Just saying for me Pinlock's are overrated.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:41 - 06 May 2016    Post subject: Reply with quote
Pinlocks rock, as do internal sun visors.
For me, the style is everything though. There again, I use an exup for commuting and refuse to have anything to do with muffs unless I'm in bed even in the coldest weather...
Triumph Sprint ST 1050
BTTD
PostPosted: 22:58 - 06 May 2016    Post subject: Reply with quote
Genuinely never had either problem with pinlocks.
Had them in an X-lite, Arai, and currently in a Schuberth.
They are of softer plastic than the external visor, and if they get scratched up then you will have issues at night with more starring of lights etc.
Never had any problems with visors slamming shut.
I have used muc-off anti fog in a non-pinlock visor and found it to work well, but it needs reapplying and faffing about with. Found pinlock to be better.
M.C
PostPosted: 11:30 - 07 May 2016    Post subject: Reply with quote
I believe Pinlock themselves say its not for nighttime use. Visor slamming issue was probably helmet specific, just a cheaper mechanism, although as the helmet came pinlock ready you would have thought they'd test the visor with a pinlock in (as without there wasn't an issue).
The last post was made 10 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 70.47 Kb
