Help bike cut out and won't start
Conzar
PostPosted: 19:29 - 08 May 2016    Post subject: Help bike cut out and won't start Reply with quote
I'll keep it short, bike cut out at about 60 and won't start, with the ignition on the oil light is showing, when you hit the starter the FI light flashes, it turns over fine just doesn't start, tried bumping it but just bogs out, bike is a 2003 zx6r b1h, currently sat on it in a van Sad
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
temeluchus
PostPosted: 19:57 - 08 May 2016    Post subject: Reply with quote
Have you researched how to get at the fault code on that?
Presuming nothing went bang a quick guess would be a sensor has packed in.
Conzar
PostPosted: 10:15 - 09 May 2016    Post subject: Reply with quote
Left the bike in Sheffield at a mates, going to go up this week to see if I can sort it, I'm going to try and pull fault codes Yeah and also see if a fuse has blown somewhere as I had something similar happen on my cbr Thumbs Up
Conzar
PostPosted: 14:03 - 09 May 2016    Post subject: Reply with quote
Going to go up tomorrow to see if its something as simple as a blown fuse or tilt sensor, any other quick fix areas I could check, just to repeat, all the electrics work fine, it turns over just doesn't spark.
Conzar
PostPosted: 14:17 - 10 May 2016    Post subject: Reply with quote
Right managed to put it into dealer mode briefly and caught some flashes for the codes but not from the start, tried putting it into dealer mode again and it was having none of it, tried over 10 times but just wasn't flashing the codes again.
Meatybeaty
PostPosted: 15:36 - 10 May 2016    Post subject: Reply with quote
Hi , saw this which might be of some help, also sounds like a tipover sensor gone, but does not explain why it happened as you were travelling along
https://www.youtube.com/watch?v=eW7hnCLEA1M
Hope it helps, also check any tight wires from below the ignition Thumbs Up
Conzar
PostPosted: 15:40 - 10 May 2016    Post subject: Reply with quote
Cheers mate, disconnected the tip over sensor this morning and gave it a clean still wont start unless the actual sensor is fucked
The last post was made 10 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 52.63 Kb
