Rounded out stanchion bolt.
R1stu
Shrek!
PostPosted: 08:17 - 09 May 2016    Post subject: Rounded out stanchion bolt. Reply with quote
So the mot is due today on the pan. I had the fork seals replaced a couple of weeks ago, but one blew on the way home from the garage.
I have now brought a genuine Honda seal and went to fit it yesterday. It looks however that they rounded the head on thevallen bolt that holds the stanchion into the lowers, as it had a splined pattern on it from where they jammed an oversized bit in there.
Low and behold, everything I tried resulted in the bits just turning out. So as this is resessed, what is going to be the best way to get it out, so I can replace the seal?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
PostPosted: 08:17 - 09 May 2016    Post subject: Reply with quote
Who replaced the seals initially.
Return to mender.
R1stu
Shrek!
PostPosted: 08:26 - 09 May 2016    Post subject: Reply with quote
Return to mender.
Don't think there fault. I supplied the parts and they were cheap aftermarket seals. I thought about taking it back, but would prob have to pay again.
Raffles
PostPosted: 08:29 - 09 May 2016    Post subject: Reply with quote
Get drilling.
Old Git Racing
PostPosted: 08:46 - 09 May 2016    Post subject: Reply with quote
Try banging an oversize torx bit in, shouldn't be that tight if its in the yoke.
OGR
bugeye_bob
PostPosted: 08:47 - 09 May 2016    Post subject: Reply with quote
typically you can hammer a Torq bit in to remove,
If this has been done you could pop a nut over the top of the bolt and tack weld inside the nut to the bolt and remove with a spanner/socket.
hth
Snowdonia Rider
PostPosted: 09:03 - 09 May 2016    Post subject: Reply with quote
If the garage has rounded the head I'd take it back and tell them to sort it. A garage cross threaded my tank bracket before and tried to hide it. They should just be honest and say "sorry mate we've fucked up ______. We'll put it right for you", instead of trying to cover things up.
PostPosted: 12:09 - 09 May 2016    Post subject: Reply with quote
+1 on hammering a torx bit in, it has never failed for me.
PostPosted: 12:14 - 09 May 2016    Post subject: Reply with quote
If the torx bit doesn't work, drill the head off.
I've rounded out plenty before myself (before I bought an impact wrench). They drill out very easily and the stump that's left unscrews with fingers. Especially if it's been out recently.
Remember to order a new one.
If the seal blew that quickly, it was either torn as it went in, you have pitting on the stanchion or you have exessive play on the bushings. So check those bushings.
Islander
PostPosted: 13:07 - 09 May 2016    Post subject: Reply with quote
Spline bits are often more effective than torx bits as they come in a wider range of sizes. Thumbs Up
R1stu
Shrek!
PostPosted: 13:54 - 09 May 2016    Post subject: Reply with quote
There is some pitting, however he advised it was above the seal line. I am going to order some new bushings too.
ITs passed the MOT now, so I will do towards the end of the month when I have another few days off.
PostPosted: 15:57 - 09 May 2016    Post subject: Reply with quote
Aye, but how did they get the seals in place?
If they rounded the bolt head then put it back in anyway, I bet they also shoved the new seal down over the pitted area.
Cover the pitted area in clingfilm and cover the "lip" at the top with PVC tape before you fit the new ones.
Do check those bushings though. My mates ZX9R is constantly blowing fork seals (USD forks too so messy) and he won't have it that worn bushings are the problem. He's done the seals 3 times in the last 12 months.
kramdra
PostPosted: 23:15 - 09 May 2016    Post subject: Reply with quote
If the seal is just leaking, I suggest a couple of things that have always worked for me. I have replaced several sets of fork seals. I used genuine parts. They *never* seal perfectly first time so I always do the following.
Seal mate tool. Its a cheap thin piece of plastic that you slide under the seal, but there are free alternatives. It resets the seal lips
Apply a small amount of grease around the seal, under the dust seal and stanchion. It doesnt need much.
Pull brake and pump the forks. It will be sealed perfectly in 10-20 bounces.
My stanchions are perfect and my cbr6 is still on original seals at 70k miles.
This will avoid needing to drill the bolt.
The last post was made 10 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 79.36 Kb
