Chain link unusualy worn?
 Topic moved: from General Bike Chat to The Workshop by stinkwheel (10 May 2016 - 10:18)
Groove This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
DRZ4Hunned
PostPosted: 21:07 - 09 May 2016    Post subject: Reply with quote
Chain too tight and/or lack of lubrication?
DRZ400-SM
FZS600
PostPosted: 21:11 - 09 May 2016    Post subject: Reply with quote
Split / rivet link and wasn't lubed when it was assembled would be my guess.
Katy
Groove
PostPosted: 07:48 - 10 May 2016    Post subject: Reply with quote
Katy
Sounds plausible. I did notice a good load of gunk on the new one when the chap put it on.
It was never ran dry (in my ownership) and the rest of the chain was fine with no tight spots.
Sprockets were good too (supersprox) felt a shame to replace them...
PostPosted: 11:16 - 10 May 2016    Post subject: Reply with quote
Yup, an O / X ring chain is supposed to have grease packed between the rings. The rivet link is no exception.
PostPosted: 19:11 - 10 May 2016    Post subject: Reply with quote
With an O / X ring chain virtually none of the lube you lob on the chain will get past the seals and into the inside of the links. So if not enough is put in place when the link is assembled then it will stay dry for the (somewhat abbreviated) life of the chain.
Katy
techathy
PostPosted: 19:31 - 10 May 2016    Post subject: Reply with quote
Katy
^^ This. That wear looks like a pedal cycle chain where the muppet has been using a 'professional' chain cleaner with a degreaser then using wet chain oil applied pre-ride rather than a dry wax lube applied post-ride.
The last post was made 10 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 16 - Page Size: 56.9 Kb
