Anyone use and recommend Redex?
fuzz
PostPosted: 20:34 - 18 Feb 2005    Post subject: Anyone use and recommend Redex? Reply with quote
I've been trying it out recently when I fill up, and I think it's made a slight difference. After about three visits to the petrol station, the power delivery feels a little smoother, and the engine seems to warm a little quicker.
Are these common after using it or is just a placebo? Confused
jcbiker
PostPosted: 20:42 - 18 Feb 2005    Post subject: Reply with quote
my mum had to use it for a car we had once. boosted the performance like a new can. very good.
i'm only 14, but need to learn before i get on bike!!!
simon1221
PostPosted: 20:57 - 18 Feb 2005    Post subject: Reply with quote
It isnt an increse in performance, just less of a los of performance caused by blocked jets etc.
I recommend it as i use it all the time. But dont put the diesel version in like some fool did a while back.
jcbiker
PostPosted: 21:11 - 18 Feb 2005    Post subject: Reply with quote
ok, it gave us the cars full performance by taking away the loss of performance. happy?
octane
PostPosted: 21:16 - 18 Feb 2005    Post subject: Reply with quote
Used it a while back; slight difference I thought.
Flip
PostPosted: 21:17 - 18 Feb 2005    Post subject: Reply with quote
Yeah. Use it and love it. 2 - strokes love it too. It basically just keeps the jets clean, helping the engine run properly.
mattsmith95
PostPosted: 22:26 - 18 Feb 2005    Post subject: Reply with quote
I am using Redex in my Honda Rebel, the bike wasn't running all that well but after a dose it's running properly.
Also using shell unleaded which seems to suit all of my Honda's. I've been using Redex for over 15 years, I only
use it when I need to which isn't often. The latest bottle has been in the garage for 5 years.
DarrenJ
PostPosted: 23:36 - 18 Feb 2005    Post subject: Reply with quote
Is it possible to put a few drops into the carb behind the airfilter?
Wave2k
G's Stalker
PostPosted: 23:50 - 18 Feb 2005    Post subject: Reply with quote
How does Redex work and where do u put it ?
Ducati 1299 Panigale
2009 Corvette C6 z51
PostPosted: 23:52 - 18 Feb 2005    Post subject: Reply with quote
Why?
That would help clean the carb as it would miss the jets.
I use it when needed and it does make a difference is performance is noticably low.
Scotsman37
PostPosted: 23:53 - 18 Feb 2005    Post subject: Reply with quote
You mix redex in with a full tank of fuel after filling up but I only use it once a while to get rid of any possible build of crap in the fuel system.
Jrod
Page 3 Girl
PostPosted: 01:01 - 19 Feb 2005    Post subject: Reply with quote
I use it just to be on the safe side, stops any crap building up etc. I think you might notice a differnece on an older bike and if you did a proper clean. (e.g. drip it into the plugs)
fuzz
PostPosted: 04:59 - 19 Feb 2005    Post subject: Reply with quote
Stick 1ml in for every litre of petrol. I just give a quick squirt for my usual 6.5 litre fill up Cool I think it basically keeps everything clean and removes any deposits.
tony532
PostPosted: 13:31 - 19 Feb 2005    Post subject: Reply with quote
thats reminded me to buy some more
as the bike is bogging down a bit at the mo
and redex sorted that out last time
cheers
mr.z
PostPosted: 13:50 - 19 Feb 2005    Post subject: Reply with quote
It has many magical poperties ( if you look on the back it does say them all)
In the tank - keeps the fuel system clean
In the air box - cleans the carbs and air intake(?)
In the bores - cleans carbon deposits on piston rings allowing them to work properly = compression back to normal + lots of smoke for a few minutes, coke will do the same thing if left in there for a week (dont blame me if you try it and it doesn't though Razz + dont forget to empty either out before puting the plugs back in too!)...
On the cx it made quite a difference, on the ta its noticable but not allot, i'm sure its just as good as useing optimax or similar...
I get the impression that the older and more simple the engine the more benefit you will get from it, modern bkies will see very little difference afaik.
fuzz - i know somebody who puts a bottle in every other 17litre tank full, does no harm (you can use quite allot more than it says with no problems)
numark1
Scared of girls
PostPosted: 13:59 - 19 Feb 2005    Post subject: Reply with quote
That would have been me Embarassed
mattsmith95
PostPosted: 14:10 - 19 Feb 2005    Post subject: Reply with quote
remove plugs, drip some in, replace plugs, start bike, RUN AWAY FAST! (make sure your wife has NO washing on the line!!!)
The last post was made 21 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.4 - MySQL Queries: 13 - Page Size: 92.5 Kb
