Dual monitor set up powered by a laptop?
Fifteen15
PostPosted: 21:41 - 14 May 2016    Post subject: Dual monitor set up powered by a laptop? Reply with quote
I am just using a laptop and have done for the last year or so. As I work online, and my university workload is increasing, I'm planning on replacing my laptop with a proper mouse, a full-sized keyboard, and dual monitors.
Could I get away with just hooking up my laptop to the dual monitors? Or would I need to buy a desktop PC as well? I don't do any gaming, the most I have open is a YouTube video, 10 tabs and a Skype video call.
Just thought if I could get away with using my laptop instead of buying a desktop PC, I'd save £200 odd Very Happy
"Pain is weakness leaving the body, and blood makes the grass grow faster...but I'll wear my gear anyway"
dydey90
PostPosted: 21:50 - 14 May 2016    Post subject: Reply with quote
Yes, I'd have thought most modern laptops would be easily capable of this. At the very least you can use a single monitor and set it to use that and the onboard screen.
Top tip: ctrl + alt + arrow key to flick a program from one screen to the other.
Fifteen15
PostPosted: 22:28 - 14 May 2016    Post subject: Reply with quote
Should I expect any lag? My laptop is pretty basic, but like I say I won't be gaming - most of what I do stays inside the browser.
My laptop specs (if it even matters) are:
1080p screen
AMD A10 5750M - 2.5 GHz
8GB RAM
120 GB SSD
AMD Radeon HD 8650/8750M Dual GPU Graphics Memory 2 GB
Windows 10
J.M.
PostPosted: 23:32 - 14 May 2016    Post subject: Reply with quote
Would be fine for general use.
This is exactly what I'm going to be doing when I move next. Two screens, then hide laptop neatly on the desk. No point buying a new computer when I have a perfectly good laptop - I'm just after the screen space.
2004 R1 & 2018 XSR900
CaNsA
PostPosted: 23:41 - 14 May 2016    Post subject: Reply with quote
Make and model of laptop?
DRZ4Hunned
PostPosted: 00:00 - 15 May 2016    Post subject: Reply with quote
That's my work set up. Although I've got a laptop dock which has two ports (VGA and DVI?) which I use, not sure if you can do it without.
DRZ400-SM
FZS600
PostPosted: 00:44 - 15 May 2016    Post subject: Reply with quote
When I was in my office in London we had a docking station for our laptops each with two screens. No one had desktops.
The laptops were pretty archaic as well so unless the docking stations had specialist hardware I can't see a problem with what you want.
Triumph Trophy Launch Edition
Jayy
Mr. Ponzi
PostPosted: 01:00 - 15 May 2016    Post subject: Reply with quote
Unless you have the correct ports on the laptop to run two monitors, you can look at pluggables. You can run monitors via USB, as many as you want as you buy the adapter and they all hook in. Friend of mine did it who only had HDMI out and nothing else, worked a treat for what he used it for, which is the same as you've mentioned.
Fifteen15
PostPosted: 06:26 - 15 May 2016    Post subject: Reply with quote
HP Envy 15-J151sa
CaNsA
PostPosted: 11:32 - 15 May 2016    Post subject: Reply with quote
You can use an ext monitor via the HDMI port Thumbs Up
If you want all the monitors, then you will need to use something like this.
https://www.amazon.co.uk/ClimaxDigital-supports-Videocard-converter-Mavericks/dp/B004E7B8D8/ref=pd_cp_147_2?ie=UTF8&refRID=NBA4K1P339ZVNTAB5W9R
PostPosted: 14:09 - 15 May 2016    Post subject: Reply with quote
I use my iPad as a second monitor when the need arises.
https://itunes.apple.com/gb/app/twomonusb-usb-monitor-dual/id796922580?mt=8
UncleFester
PostPosted: 16:04 - 15 May 2016    Post subject: Reply with quote
Pick up a Matrox Dual head / Triplehead2Go on Ebay for not a lot of coin Smile
2017 Z1000SX
The last post was made 10 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 72.43 Kb
