oil plug rounded - any ideas?
rubyhorse2
PostPosted: 13:19 - 16 May 2016    Post subject: oil plug rounded - any ideas? Reply with quote
why is it the simplest of jobs become utter nitemares.
Went to change the oil this weekend and guess what...oil plug is totally mullered. Why do people do this? to make matters worse access to the plug is a total nitemare, with the exhaust system being about 15mm below the plug, cant even get a socket on it.
I've ordered a new plug just need to somehow get this one off, any ideas?
tried molegrips, cant get in to weld anything to it or cut a groove.
The thought of removing the whole exhaust system just to get to this is not a pleasant one.
WD Forte
PostPosted: 13:29 - 16 May 2016    Post subject: Reply with quote
The reason the plug head is chewed is probably due to it being a sod to get at.
Chinese bike?
Typical
bloody typical
Shoulda got a jap one, people never have probs with jap bikes
bikers smell of wee
PostPosted: 13:35 - 16 May 2016    Post subject: Reply with quote
Suck it out with a syringe, refill. use the filler hole.
PostPosted: 13:37 - 16 May 2016    Post subject: Reply with quote
Use a pump to suck out the old oil, hand pumps are under £10 from eBay. If you can get the tube to the bottom of the sump you should get most of the oil out.
tom_e
PostPosted: 13:41 - 16 May 2016    Post subject: Reply with quote
https://thumbs3.ebaystatic.com/d/l225/m/maUXaNrtp0FLSTpycbGvicg.jpg something like them? Should be able to get a decent grip and you've got some leverage.
J4mes
PostPosted: 14:31 - 16 May 2016    Post subject: Reply with quote
No.
These
https://www.tooled-up.com/product/faithfull-leader-pipe-wrench-8/3504/#prettyPhoto[gallery1]/0/
Or file some flats on it and get a spanner on.
Don't forget to buy a new one first.
rubyhorse2
PostPosted: 14:55 - 16 May 2016    Post subject: Reply with quote
sorry its a ktm superduke
think i am going to give up and take to a garage and see if they can get to it. no doubt £££ in labour time if they have to remove exhaust system etc.
new one is ordered already.
want to get it sorted for next time, but cheers for the ideas on sucking the oil out, possibility i suppose.
PostPosted: 14:58 - 16 May 2016    Post subject: Reply with quote
Stilsons are pretty magical, but I doubt OP has access without taking the exhaust off (then inB4 "how remove snapped stud?").
Suck, suck, suck. I hear that there are cars out there that don't even have drain plugs any more.
J4mes
PostPosted: 15:13 - 16 May 2016    Post subject: Reply with quote
Yes it does seem to be the way forward!
PostPosted: 15:39 - 16 May 2016    Post subject: Reply with quote
https://toolmonger.com/wp-content/uploads/2009/09/super-wrench-4-piece-set.jpg
MCN
PostPosted: 17:10 - 16 May 2016    Post subject: Reply with quote
You could take it to a welder and weld a nut on.
Put the bike upside down on it's seat and bars. Easy job to get at the drain plug in that position too. Smile
Drain plugs are put on tight because, 'if the oil comes out it is serious'. Rolling Eyes
They are put on too tight by the sort of folk who should be refused free access to tools.
Unless it's a hacksaw to cut their tamperfering fingers off with.
PostPosted: 18:25 - 16 May 2016    Post subject: Reply with quote
Just bought one of these, £6.66, much success emptying gearbox of oil.
https://www.amazon.co.uk/Streetwize-SWSP-Multi-Purpose-Syphon/dp/B003G2E0ZA
MCN
PostPosted: 19:23 - 16 May 2016    Post subject: Reply with quote
This set-up looks easier to use and possibly cheaper.
PostPosted: 20:22 - 16 May 2016    Post subject: Reply with quote
What about
https://g03.a.alicdn.com/kf/HTB1kEk9JpXXXXayXFXXq6xXFXXXK/3pcs-1set-ETC-200MO-Universal-Grip-Socket-Wrench-Spanner-Power-Drill-Adapter-Hand-Tool-TV-Products.jpg
I have had joy with these when the nut/stud is pretty fucked.
https://www.amazon.co.uk/dp/B003AMXVKG/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=569136327&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B002GZFGGU&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=KD5W42BD9C1EG0FASGEN
Snowdonia Rider
PostPosted: 21:09 - 16 May 2016    Post subject: Reply with quote
Bet your missus loves you Thumbs Up
BTTD
PostPosted: 21:32 - 16 May 2016    Post subject: Reply with quote
I'm agreeing with the pump it out suggestions.
You'll get the oil changed, which is all the drain plug is doing for you anyway, and save yourself the massive ball ache of possibly fucking your sump up.
Failing that God.i suggestion might be worth a punt.
Edit: Screwfix do an Erbuaer brand version, reviews suggest it'll work.
https://www.screwfix.com/p/erbauer-bolt-nut-remover-set-6-pieces/6083D?kpid=6083D&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20tracking%20url&cm_mmc=Google-_-Shopping%20-%20Tools-_-Shopping%20-%20Tools&gclid=CL-hk4K738wCFfAy0wodNoUGIA
anthony_r6
PostPosted: 22:17 - 16 May 2016    Post subject: Reply with quote
I've had a lot of success with Beta damaged nuts sockets.
https://www.teng.co.uk/014280008-014280027-beta-pullers-for-damaged-nuts-with-square-drive.html
recman
PostPosted: 23:23 - 16 May 2016    Post subject: Reply with quote
Googling images of the superduke's oil drain plug suggests there indeed may not be enough room to use a socket on a ratchet but have you considered using one of the abovementioned rounded socket removal solutions with an extension bar?
Hong Kong Phooey
PostPosted: 23:56 - 16 May 2016    Post subject: Reply with quote
Irwin bolt grips never let me down, even refitted chewed up sump nut before now coz I know it's coming off again with these bad boys
Jmh600
PostPosted: 00:06 - 17 May 2016    Post subject: Reply with quote
Those Irwin sockets (or turbo sockets as we call them) are fantastic..... I use mine with an impact gun all the time. Saved my ass
Jmhmotorcycles
Hong Kong Phooey
PostPosted: 00:30 - 17 May 2016    Post subject: Reply with quote
The Irwin bolt grips you can get a spanner over the end, that is if you can get the socket on without a ratchet getting in the way.
rubyhorse2
PostPosted: 10:57 - 17 May 2016    Post subject: Reply with quote
going to call in to the local bike garage and see what he says, i'd much rather get it off and put the new one on, but if it aint looking good then its the pump option.
i hate plebs who **** bolt heads up...arhghgh
fatjames
PostPosted: 11:23 - 17 May 2016    Post subject: Reply with quote
Shame. There is some really good advice on this page. Buy one of those socket and it'll last you a lifetime. Even if it only lasted long enough to do this job, it would be cheaper and easier than paying someone.
Islander
PostPosted: 12:04 - 17 May 2016    Post subject: Reply with quote
+1 for the Irwin extractors. They've worked for me a number of times. Thumbs Up
The last post was made 10 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 127.02 Kb
