Opening Throttle lacking power slightly
grant3779
PostPosted: 11:24 - 18 May 2016    Post subject: Opening Throttle lacking power slightly Reply with quote
First post...easy... Cool
I have a Ducati 1098 and when accelerating in lower gears it seems to be less powerful than it used to be. Noticeable when taking off from a stop too. No longer get that "front wheel up" feeling. Once I get on the open road, and above a certain speed, it seems better, but it's just getting to these high speeds is now taking longer than it should and feels like it is being held back ever so slightly.
I changed the plugs and also run some fuel system cleaner through it but doesn't seem to have made a difference. Apart from this, bike is running fine. It's all original, with termi slip on, correct ECU. Nothing else done to it.
I read about possible vacuum leak could be a cause, but not to sure how I could test/look to see if this is the case. Nearest dealer is a good couple of hundred miles away so would like to try/test all I can before I go down that route. Would a clogged fuel filter cause this or would that cause other issues? It's NOT spluttering/backfiring/popping. There is just something holding it back from that all initial burst of speed when I open it up and I know it wasn't like that when I first got it.
Any Input appreciated Thumbs Up
CaNsA
PostPosted: 11:26 - 18 May 2016    Post subject: Re: Opening Throttle lacking power slightly Reply with quote
Lying bastard.
Cronik
PostPosted: 11:35 - 18 May 2016    Post subject: Reply with quote
Check valve clearances.
*A Vacuous Vacancy*
grant3779
PostPosted: 11:39 - 18 May 2016    Post subject: Re: Opening Throttle lacking power slightly Reply with quote
CaNsA wrote:
Lying bastard.
Fk so I am. Been that long I thought this was a first. Thanks for correcting me you miserable git.
P.
PostPosted: 11:44 - 18 May 2016    Post subject: Re: Opening Throttle lacking power slightly Reply with quote
Purchase a new litre sports?
The last post was made 9 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 45.16 Kb
