ECU Reflashing
Quote Me Happy
PostPosted: 22:08 - 19 May 2016    Post subject: ECU Reflashing Reply with quote
After doing some reading on t'internet there seems to be some pretty bold claims from people offering to flash the ECUs of bikes.
There's also an army or satisfied customers claiming more power, better power delivery, smoothness etc.
Some people are claiming to have up to 30% higher BHP and torque figures after having their bikes set up on the dyno. I know the Euro 3 regs strangle bikes to some degree but 30% increases? Is this possible or can a dyno operator inflate the results?
I'd be interested to hear the opinions of those in the know.
CaNsA
PostPosted: 22:10 - 19 May 2016    Post subject: Reply with quote
Yes it is possible to retune an engine.
Quote Me Happy
PostPosted: 22:13 - 19 May 2016    Post subject: Reply with quote
I know that fuckface but are the claims of 30% increases in power/torque realistic or just sales guff?
CaNsA
PostPosted: 22:16 - 19 May 2016    Post subject: Reply with quote
https://i.imgur.com/MnxmW0N.jpg
PostPosted: 22:17 - 19 May 2016    Post subject: Reply with quote
I've had my Street Triple custom mapped, and the gain is not mainly at the top end. I did get about 10bhp on a 100bhp bike, but really the main thing is that the power delivery is so precise with no hesitation and creamily smooth. The bottom end is fatter and you can ride the bike at low RPM without jerking along.
I do have a full Arrow system on my bike too, so remapping alone probably won't do much, but with a decent exhaust a custom map can remarkably improve the rideability of the bike.
30% though? No way. You'd barely get that on a turbo car, let alone a NA bike.
temeluchus
https://www.youtube.com/watch?v=95YdE89nTgI
PostPosted: 22:46 - 19 May 2016    Post subject: Reply with quote
With no other changes I would suspect 3% would be closer to the level of gains.
Dynos can be fiddled in various ways, but whether any particular dyno can be is another question. Tyre pressures can be fiddled with, rear brake dragged, or just not using full throttle for the before run. Some even have a manually entered correction factor.
Katy
Cosmik de Bris
PostPosted: 22:52 - 19 May 2016    Post subject: Reply with quote
In many cases the maximum power will not increase that much as the engines are fairly high spec to start with, this all depends on make and model of course. Often what remapping does is make the bike more ridable by taking out the lean spots that are there to meet emissions regulations.
What you need to be aware of is that in many countries you may be breaking the law by tampering with the fuelling. That is why many ECUs display "race" on the dash after re-mapping.
See Volkswagen for details.
Quote Me Happy
PostPosted: 23:03 - 19 May 2016    Post subject: Reply with quote
Katy
I'm no expert but my bike feels slightly asthmatic - there's a slight vibration at approx 4k - I've just got a niggling uneducated feeling that the fuelling could be tweaked for the better. When doing some research I've found you can get a custom ECU set up for the price of an exhaust end can so am considering it. It's just that I can't believe some of the claims and some of the den print outs that I've seen.
Albigularis
PostPosted: 23:49 - 19 May 2016    Post subject: Reply with quote
What bike do you have, OP?
Gains are massively dependant on the bike you have. On something like an S1000RR, I expect you'd see very little peak power gain, but a lot throughout the rev range. Due to emissions though, two cylinder engines (looking at you Ducati) often run like crap from the factory. Realistically, a stock Multistrada 1200 will get 120 at the wheel. Good reflash and decat, you're looking at 135-140. Including removing flat-spots, that's a damn good deal. On your average sportsbike, the 5-6k rpm flat spot will be gone, that's usually where the biggest power difference is.
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
Quote Me Happy
PostPosted: 07:58 - 20 May 2016    Post subject: Reply with quote
Kawasaki 1400GTR, apparently The bloke I spoke to said he also advances the timing as well as fiddling with the fuelling, I see people claiming +20lb/ft and +20BHP after having theirs done plus much smoother throttle.
PostPosted: 08:25 - 20 May 2016    Post subject: Reply with quote
Can you name five?
Quote Me Happy
PostPosted: 08:55 - 20 May 2016    Post subject: Reply with quote
Can you name five?
North Korea
Central African Republic
Guinea-Bissau
Nicaragua
Turkmenistan
Kris
PostPosted: 09:10 - 20 May 2016    Post subject: Reply with quote
It's all about unlocking the ECU code isn't it? Thinking
Rather than installing a Power Commander fuelling unit, if you can 're-flash' the existing ECU then they effectively remap the fuelling to remove any nasty EU dips due to emissions regs.
I know when my GSXR was done they could only raise or lower the fuelling map, not adjust the map profile itself. Mine was done because with an open exhaust and no SET valve I was worried about lean running..
Bleugh, sorry. May have this all wrong. Neutral
www.prisonplanet.com
Quote Me Happy
PostPosted: 09:23 - 20 May 2016    Post subject: Reply with quote
No Kris, I think you have it spot on. Once the ECU is unlocked someone with the right know how can change all sorts of parameters such as fuelling, ignition advance, remove speed limiters, increase/decrease engine braking, opening secondary butterflies at different times....
Back in my day, it was a case of fitting a power commander and piggy backing the ECU, it seems things have moved on.
Doovy
PostPosted: 09:36 - 20 May 2016    Post subject: Reply with quote
Titot has done it on his R1, and Connor (who was at the RWYB last week) had it done on his MT-09. He said it made it feel like a different bike, with it having adjusted the power delivery and not so snatchy at lower speeds.
The Tot
PostPosted: 10:01 - 20 May 2016    Post subject: Reply with quote
Joe,
What bike is it firstly? I know yamaha bikes post 2007 have had their ECU parameters adjusted to comply with Euro 3; noise and emissions. Coincidentally, I had my flatspot between 3-5k rpm.
I believe since most of these bikes run closed loop fuelling based on the lambda sensor, I didn't really "bother" taking it to a dyno to refine the base map once the ECU was remapped.
Parameters they adjusted were
Arrow Removal of ignition timing retardation
Arrow Removal of fly by wire throttle restriction in the first 3 gears - Basically, WOT would not necessarily translate to a 100% demand at the fuel injectors. So on that basis, a 2004 model R1 would pull much stronger than my 07 model. It was a way of making the bike feel it had a top end rush. When that was removed, it drove a lot harder in the first 3 gears.
Arrow Base mapping - in conjunction with the above, it plugged in the midrange hole.
Arrow EXUP delete - my exup valve is wired open. Flashtune has a setting to compensate for a non-functioning or total removal of exhaust butterfly valves.
Arrow Engine braking adjust - I left that as stock
Arrow Secondary air injection disabled - no more pops or bangs on the overrun. Again, this is an emissions thing which stifles pickup. All that lurchiness on throttle transients were removed.
Arrow Fan temperature adjust - got my fan to kick in at 100 degC instead of 110.
All in all, the seat of my pants dyno would suggest I gained a respectable amount in the midrange. Power delivery feels more linear and the bike is more liable to crest its front wheel in the first 2-3 gears when giving it some... especially on track.
If you can find a dyno that does flashtune (it's a darn sight chaeaper than a PCIII/PCV) and actually refine the map, it's well worth it.
Flash tune claims that it offers 80% of the adjustment as a YEC ECU with the benefits of not requiring a total race kit. I paid £130 for mine. For base settings, it more than met my satisfaction. Thumbs Up Karma
Never argue with autism
chickenstrip
PostPosted: 10:05 - 20 May 2016    Post subject: Reply with quote
LOL!!
Ahem. Sorry, as you were Laughing
Groove
PostPosted: 10:14 - 20 May 2016    Post subject: Reply with quote
Watching this thread.
Since removing the exhaust butterfly's and fitting the (non road legal) micron my fueling is lumpy especially down low. It also doesn't seem to power up as easily in 3rd Laughing
£130 seems reasonable although I would like to see before and after dyno charts.
Anyone know if the 2005/2006 gsxr 1000 ecu's allow this?
The Tot
PostPosted: 10:32 - 20 May 2016    Post subject: Reply with quote
Guys, FYI
See if Velox Racing offers flash tune for your bike - you send your ECU off to Mark and he'll send it back within 3 days
The Tot
PostPosted: 10:34 - 20 May 2016    Post subject: Reply with quote
Adam,
https://www.veloxracing.com/wp/product-category/suzuki/gsxr1000-05-06-k5-k6/
Give him an email - it seems it does have it for your bike - £130 mail in service. Just tell him what your symptoms are regarding power delivery and what it is you expect.
PostPosted: 10:50 - 20 May 2016    Post subject: Reply with quote
Smoothing things out and removing flat spots is to be expected. Big differences in power through the rev range is pretty unlikely.
Katy
woo
PostPosted: 10:56 - 20 May 2016    Post subject: Reply with quote
i had a 2007 R1 (4C8 model)
I bought the flash tune kit and uploaded a custom map into my ecu.
I lowered the temp for when the fans kick in and also used the speedo healer function.
to be honest i did notice a difference mainly top end wise otherwise i though the whole thing was MEH!!!!!!!!!!!!!!!!!!!!!!
it cost me around £430 for the DIY whole kit and i didnt think it was worth the time and money i spent doing it, as it didnt do what i actually wanted it to do which was improve torque in the lower RPM range.
if your racing on the track then yes its great as every little thing makes a difference
its good if you wanna make changes and is great you can load a custom map into the ECU
if i could have done it all again i would have stayed with my power commander and saved a lot of time and money meh............
(bearing in mind PC cost me £150, custom map cost me £165, then flashtune kit cost me £430, but before that trips to and from norfolk cost me £40 in petrol plus the £120 for the first flash before i decided to buy the DIY kit)
Steve Jordan motorcycles can flash ECUs so can Track Electronics in Norfolk,
Type flash tune into ebay as i think theres more people that do
Ive gone back to a 01 Yamaha R1 which has all the torque i could ever want in the lower rpm and have my honda msx 125 when i wanna doodle about
And yep the internet has very very bold claims as my 07 R1 did not feel like a different bike with oozzes of torque............that pissed me off cos thats what i was expecting.
I proper researched and learnt how to use the flash tune software and what does what to find out in the end that those bold claims were nothing but bold claims or simply placebo effects.
There is a difference but not a big huge difference.
i dont know how this is on other bikes as i have only experienced this with the 07 R1
try it see how it is for
Elen sila lummen omentielvo!
The Tot
PostPosted: 11:52 - 20 May 2016    Post subject: Reply with quote
Woo,
Did you have a boggy pick-up at low end? And was your exhaust largely stock (bar end cans).
Only reason why I used the flash tune was it was cheaper than a PCIII for the mail order. I didn't know what I was doing, so I have it to chap who did. It seemed spot on to me.
Saying that, my fuelling was all over the shop. <2k in 1st the bike would cut out. Sometimes going on slow speed corners with the clutch in. All manner of things were causing me to not enjoy the bike.
But it ironed out the creases, so for me, it did its job. Definitely able to exploit the bike a lot more. In terms of all out power? Well, I don't spend my time on WOT on the road so I wouldn't know or care. The difference good fuelling makes is like night and day, so I'm not too fussed about bhp here or there!
Oh, i raised my idle by 250rpm too!
bikertomm
PostPosted: 12:10 - 20 May 2016    Post subject: Reply with quote
I must admit, I'm kind of toying with the idea of getting my car mapped (330 dirty D)
And often wonder if it's pure sales guff that it can improve the economy, I can understand why it would, but not to the figures they suggest (15% etc) I'm already getting 650-700 miles a tank rinsing the MPG, I genuinely can't see it going up, guess I'll find out!
The last post was made 10 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 142.06 Kb
