Help with changing down gears
ginguar
PostPosted: 18:25 - 19 Feb 2005    Post subject: Help with changing down gears Reply with quote
Hello all. I am going to sound stupid here but I am having trouble with changing down gears and am too embarassed to ask my motorcycle instructor Dad. My problem is that I am unsure what to do when coming to a stop. If this already has a thread for it please point me in the right direction.
The problem I have is that I am unsure what to do when coming to a stop at for example traffic lights. I am going along in 4th gear and see that the lights have changed. I have a tendancy to ease off the throttle, start braking then get to a stop. At that point I bloke change down to 1st gear. I am pretty sure (although correct me if I am wrong) that I shouldn't be doing this as it doesn't feel right.
Should I be changing down to third then riding in third for a few seconds then down to second riding in second for a short while and so on until I stop. This seems like a lot to be doing in the time it takes to stop.
Anyways any helps would be much appreciated. I know I may sound stupid but I would rather ask than ride like idiot for the rest of my days.
carvell
Scuttler
PostPosted: 18:28 - 19 Feb 2005    Post subject: Reply with quote
You should always have the gear you are in match your speed.
So yes, when you are slowing down for traffic lights you should gradually change down as you get slower and slower - this also helps you slow down because of engine braking.
Bear in mind that you should only change down to second, change to first when you are at a standstill.
Yamaha TDM 850
ginguar
PostPosted: 18:31 - 19 Feb 2005    Post subject: Reply with quote
Thanks very much for your help, it's nice to clear that up. I guess I will have to go out there and practice.
JonB
Afraid of Mileage
PostPosted: 18:39 - 19 Feb 2005    Post subject: Reply with quote
I have a query about gears, when at traffic lights is it best to be stopped in first gear or put back into neutral? Smile
carvell
Scuttler
PostPosted: 18:43 - 19 Feb 2005    Post subject: Reply with quote
If you know you're going to wait ages then I'd stick it in neutral so I can free up my hands for a bit.
Usually I'll just sit there with the clutch in though.
Yamaha TDM 850
White Noise
Mr Dudwee
PostPosted: 10:23 - 20 Feb 2005    Post subject: Reply with quote
i used to the same when i was learning for my test! soon got out of the habit after a couple of times after making the rear skid due to the extreme engine braking. hopefully i am completely out of the habit but still learning everyday
This is a very simple concept and one i didn't keep to.
WN
Barker-CBR 600
PostPosted: 11:40 - 20 Feb 2005    Post subject: Reply with quote
Matching gear to speed is the most important thing, long as you got that right then you dont gotta think about what gear your in.
It depends on your bike somewhat as well, on larger bikes with a wider range of speeds for gears then changing straight down doesnt matter hugely long as the speeds right.
What you gotta avoid is the
'change down'
*Buzz engine braking making you uncomfortably pushed forward*
Wait for it to stop
'change down'
Which is common if you not going slow enough for the change down.
As for first gear, on alot of bikes (125's especially) its far too jumpy/harsh to use except when pulling off. Changing down into it and you get harsh amounts of engine braking. Trying to drive along in it and you end up 'jumping' forward and back trying to keep a low speed. 2nd can handle pretty much all low speeds (and pulling off if it really must) on 125's so it is the best 'town gear'.
Sitting at the lights it makes little difference whether your in neutral or with clutch in.
However remember its preferred that you have your LEFT foot on the ground (whether people agree is another matter, the CBT teaches that). So if you leave it in first with the clutch in you can avoid the 'hop' as you change feet shift from neutral to first then switch feet.
So unless your waiting ages or really need both hands, leave clutch in.
Previous - Gilera DNA50 / XVS125 Dragstar/Honda CBR 600F/GSF 650 Bandit
Current - 2013 Suzuki VZ800 Intruder
'Is this a rhetorical question?'
ginguar
PostPosted: 14:17 - 20 Feb 2005    Post subject: Reply with quote
Excellent cheers for the help.
Craggles
PostPosted: 20:44 - 20 Feb 2005    Post subject: Reply with quote
Think ahead - throttle off, change down, release clutch. Change down again once you've shaved off the speed. Most of your stopping power can come from the engine as opposed to the brakes.
There's no point in speeding upto a red light and slamming your brakes on - may as well slow down earlier, not as if you'll get there any quicker!
Try blipping the throttle as you pull the clutch in. I find it leads to far smoother gear changes.
If I've filtered to the front, I'll hold it on the clutch as I want to get away ahead of the car next to me.
Otherwise I make a point of changing into neutral. Far more comfortable on the left hand and reduces wear on the clutch.
Craig
If this signature is blue, you're riding too fast
Krs
PostPosted: 00:48 - 21 Feb 2005    Post subject: Reply with quote
Is is this in the test training:up:
The last post was made 21 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 66.49 Kb
