Carb Jets
Draco87
PostPosted: 12:55 - 27 May 2016    Post subject: Carb Jets Reply with quote
Hey guys hopefully someone can help,
First off ill give you the symptoms; I have a 2000 R6, which has aftermarket exhaust and air filter(K&N) carbs have been balanced correct. But the I cant the idle to regulate properly; at 1500 rpm it oscillates (needle in tach going up and down) and pulling off is slightly hesitant. After research I found I could have the wrong pilot jets installed which was my assumption. After further research I found the carb to be a Keihin CVRD37 (apparently). So set about trying to find jets I can only find jets for different models I.e FCR, NCR424. Can anyone explain to me what jets I need exactly and what would fit? I will be buying one size up and one size down to see which works best.
Thanks
Craig
1992 Yamaha SR125, 2005 Honda XR125, 1998 Yamaha XJ600S, 2000, 2004 Yamaha R6, 2002 Yamaha Fazer, 2004 Honda CBR
Meatybeaty
PostPosted: 14:37 - 27 May 2016    Post subject: Reply with quote
Hi , you will find the jet sizes in your Workshop Manual, specifications page Thumbs Up
https://www.bikechatforums.com/viewtopic.php?t=21133&view=next
https://www.jetsrus.com/a_jet_kit_street/yamaha_600_YZF-R6.htm
Draco87
PostPosted: 17:12 - 27 May 2016    Post subject: Reply with quote
Meatybeaty wrote:
Most helpful dude 😊 thank you ill have a look in my manual and strip out current carbs to determine which size are in now
Ariel Badger
PostPosted: 21:26 - 27 May 2016    Post subject: Reply with quote
I wonder why California has different settings., emission laws?
Draco87
PostPosted: 22:22 - 27 May 2016    Post subject: Reply with quote
From doing all the research its something to do with atmospheric pressure, what with all the hills and all Laughing. But hey i might just be talking out my arse!
Ariel Badger
PostPosted: 22:34 - 27 May 2016    Post subject: Reply with quote
A friend of mine rode a Royal Enfield through the Himalayas and they had to re-jet because of altitude.
Draco87
PostPosted: 22:41 - 27 May 2016    Post subject: Reply with quote
Would make sense as lack of air the higher you get (poor poor bikes)
jjdugen
PostPosted: 23:53 - 27 May 2016    Post subject: Reply with quote
California runs everything lean for emissions. Most Jap bikes run at least one size down from ideal.
The last post was made 10 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 58.14 Kb
