Brake Light Brighter when Using Rear Brake
guile
PostPosted: 11:02 - 29 May 2016    Post subject: Brake Light Brighter when Using Rear Brake Reply with quote
So my tail light illuminates brighter when using the rear brake than it does using the front brake. Front brake seems to work but light is much duller.
What's going on there? Had a new switch fitted to the front brake a while back because it wasn't illuminating the tail light at all (but there was no difference in brightness after this was fixed).
Obviously got some issues with my electrics. Where to start?
smegballs
PostPosted: 11:05 - 29 May 2016    Post subject: Reply with quote
Likely to be more old wiring and shitty corroded connector blocks in the path from front brake switch to lamp as opposed to rear brake switch to lamp.
Use a multimeter to measure resistance of said paths and compare. Alternatively, measure the voltage across the bulb when operating the rear/front switches and compare. Most likely cleaning the connector blocks will sort it.
As long as it is "bright enough" though.... is it really an issue?
The last post was made 10 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 31.44 Kb
