| kmcbr1000fm |
 kmcbr1000fm L Plate Warrior
| MCN |
 MCN Super Spammer
| BTTD |
 BTTD World Chat Champion
| doggone |
 doggone World Chat Champion
| Matt B |
 Matt B World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 13:55 - 29 May 2016 Post subject: |
And
99.999% of water in fuel problems are the cause of water in the fuel.
If it has been sitting with a half tank/less than full the repeated condensation cycles could have allowed 'substantial' water to collect/pool in the bottom of the tank and that may have been drawn into the carbs when started.
(The parts of the tank not submerged 'in fuel' condense water vapour in the atmosphere as the tank 'breathes'. Overtime the droplets will 'drop' into the fuel where it is now trapped and cannot re-evaporate to atmosphere again.
It's why it is best to start a 'stood bike' on fresh fuel.
Not necessarily because the fuel 'goes off' but because half full tanks collect moisture. (Unless sealed). ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Ichy |
 Ichy World Chat Champion
| kmcbr1000fm |
| temeluchus |
| Robby |
 Robby Dirty Old Man
| kmcbr1000fm |
| Minty |
 Minty World Chat Champion
 Posted: 11:44 - 30 May 2016 Post subject: |
I don't know why but my cbr plugs loosen slightly when laid up and then obviously misfires, runs rough etc.
Make sure they are tight. Simple things first.  ____________________ My fingers smell of your mum. |
| kmcbr1000fm |
| BTTD |
 Posted: 13:27 - 30 May 2016 Post subject: |
I've used a spark plug test lead with a funny light thing before. You can also get an arc to the engine block from the unplugged lead. Youtube is your friend for basic tests.  |
| temeluchus |
| davebike |
 davebike World Chat Champion
 Posted: 08:33 - 31 May 2016 Post subject: |
Remove and clean carbs modern fuel has short shelf life so fresh fuel as well ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| kmcbr1000fm |
| Ichy |
 Posted: 12:58 - 31 May 2016 Post subject: |
Swap the plugs around and see if the problem moves then swap the plug leads around for the shared coil, so swap 1 for 4 and 2 for three ( Im guessing but hopefully you understand what I mean). That should confirm if it is electrical or not.
Next suggestion would be a carb clean. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| kmcbr1000fm |
| Robby |
 Robby Dirty Old Man
| kmcbr1000fm |
| Robby |
 Robby Dirty Old Man
| davebike |
 Posted: 07:29 - 01 Jun 2016 Post subject: |
Blocked idle jets
Remove and clean the carbs
Fresh fuel ____________________ Dave
[email protected] |
The last post was made 10 years, 117 days ago. Instead of replying here, would creating a new thread be more useful? |
