| asta1 |
This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
 asta1 Scooby Slapper
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 17:38 - 29 May 2016 Post subject: |
It's a 1.2 Polo. If you aged mother wants more go, then buy a bigger engine. (Did you turn off Eco mod? IME this makes a difference and a lot of cars default into this on start up). ____________________ My Flickr |
| M.C |
 M.C Super Spammer
 Posted: 17:44 - 29 May 2016 Post subject: |
Probably random banter. Just posted this video in another topic, apparently what euro 6 regs did to the 1.2 500.
Modding a 1.2 Polo? I would have thought you'd have to be careful with emission testing come MOT time, although that'll be a couple of years away for your mams polo.
With bikes it seems every model blames poor fueling on emissions, I dunno what the truth's.
Make sure you don't get carried away and end up with this:
https://img10.deviantart.net/c10f/i/2010/240/7/0/volkswagen_polo_euro_style_by_phantondesign-d2xhttv.jpg |
| asta1 |
| Wafer_Thin_Ham |
| mrbox |
 mrbox Wonderwall
| stevo as b4 |
| asta1 |
| wristjob |
 wristjob World Chat Champion
| Commuter_Tim |
 Commuter_Tim World Chat Champion
| Ben90 |
 Ben90 Brolly Dolly
| stevo as b4 |
 Posted: 09:38 - 30 May 2016 Post subject: |
Will still have soggy poor drivability though, just more go eventually to make up for the Weight of the car.
Back in the 80's you had crap but light and cheap little hatch's, that did competitive mpg to today, but with far less efficient engines. Something like a Citroën AX with a simple cooking 1.4 litre engine went a long way, and you'd need your warm or sporty larger engined equivalents to go as well today.
If a hot hatch had 200bhp it would be totally ballistic, and yet you need nearer 300bhp in a family hatch now to get that kind of silly performance.
But back to the point is that if your making new vehicles now, you have to tailor them to get the best mpg possible for the type and size of engine, for sales performance. And you have to map engines to stay as clean and green as possible all the time, and just about allow it to make the power at the top end, while giving it as little fuel as possible.
You can't improve a modern petrol engine so that it's really noticeable to drive, while keeping to emissions limits. A new engine with no requirement for emissions or fuel efficiency or low NVH levels could be really snappy and responsive if the ECU was configured to power as the only compromise.
They even map race cars lean these days, so that you can get more laps out of every tank of fuel, so you can win races in the pits, not out on track.
Bikes are lucky that they lasted until much more recently with no catalysts fitted or emissions targets.
Back in the days of power commander's being fitted to most EFI bikes, they'd get mapped on the rolling road for the exhaust, induction and engine tuning changes, and all that would be needed was to fill in any holes, or lean areas on the map, and make the throttle response as instant as possible.
Sometimes peak bhp gains wernt massive but drivability was excellent. You can't get that with modern cars or bikes though while staying clean and legal. |
| techathy |
 techathy Traffic Copper
 Posted: 14:35 - 30 May 2016 Post subject: Re: Fix for Euro 6? |
| asta1 wrote: | I am not sure that this is in the right section, but it is relevant to bikes as well so...
Anyway, my mother has recently bought a 2015 VW Polo 1.2 petrol and upon having a play with it today I found it extremely gutless, even more so than my old 2004 1.2 corsa which should all else being equal be even worse. Now a lot of this might be due to me being used to a slightly less crappy car and the additional weight of the newer model, but I suspect the Euro 6 Regs are also a major contributing factor.
So, my question is, how much can an aftermarket remap or ECU address this issue? I don't care much about peak power, it is afterall my aged mothers car, but a bit more go below 3000rpm would make it much easier and more enjoyable to drive, especially with 4 of us in it. What would you guys recommend and how much of an improvement can I expect?
Cheers. |
Depends how cracked the ECU is. If it's cracked enough you can get in and you can get really nice functional gains not by gaining power but more by smoothing things out. If they are using black boxes or using tables for a purpose other than intended you’ve not got much hope.
On my car I kept the stock open loop maps, however the closed loop AFR targets where made richer, this means it's possible to gently & smoothly control the speed of the car right down to 5mph with the throttle. The drivability gains above 1300 rpm are down to flat mapping the throttle and significantly reducing the intervention of stability control. However the ECU suit in my car has been about for 8 years & has been well and cracked wide open. |
| stevo as b4 |
| techathy |
| techathy |
The last post was made 10 years, 44 days ago. Instead of replying here, would creating a new thread be more useful? |
