Sprint 1050 ST valve cover bolts over-tightened
SteveSmith
PostPosted: 08:43 - 01 Jun 2016    Post subject: Sprint 1050 ST valve cover bolts over-tightened Reply with quote
Hi, I checked my valve clearances last night but when I put the valve cover back on I trusted my torque wrench too much and over-tightened them (my head was saying "that feels like more than 14Nm", but no click so I kept going). I'm now left with one sheared off in the cylinder head, and one with a partially stripped thread.
The cover feels like it's on firmly, and the seal looks OK, but I assume there are six bolts in there for a reason, and now only four of them are doing anything. The two dodgy ones are in opposite corners.
How big a problem do I have?
Thanks,
Steve.
Meatybeaty
PostPosted: 09:51 - 01 Jun 2016    Post subject: Reply with quote
Possibly the least you will get is an oil leak, did you put on a new gasket and have you got a service manual Thumbs Up
SteveSmith
PostPosted: 10:28 - 01 Jun 2016    Post subject: Reply with quote
It uses a rubber seal. The service manual recommends changing it only if it is worn or damaged, which it isn't so I've re-used it.
Steve.
PostPosted: 10:38 - 01 Jun 2016    Post subject: Reply with quote
14 mm is just 10 foot pounds which you can achieve with a normal spanner and 2 fingers. The snapped fastener should come out easily enough, the torn threads will need an insert.
SteveSmith
PostPosted: 11:20 - 01 Jun 2016    Post subject: Reply with quote
Thanks, I'm nervous about drilling / tapping on the edge of the cylinder head to repair the thread or get the broken bolt out though because of the amount of crap that could fall into the engine. Am I likely to do more harm that way, or by leaving them where they are and living with 4 bolts?
Steve.
Meatybeaty
PostPosted: 11:27 - 01 Jun 2016    Post subject: Reply with quote
Hi Steve , you could try putting sealer around where the bolts are missing and see if the other bolts will hold the cover down and seal the cover, but that's only a bodge fix, the broken bolts really need extracting to make a good job , and the torque should have been 10nm not 14nm, but really like Pete says a good nip up with the spanner is a better feel Thumbs Up
The last post was made 10 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.87 - MySQL Queries: 13 - Page Size: 48.81 Kb
