No electric on xtr 125cc
 Topic moved: from Forum Feedback & Help to The Workshop by stinkwheel (2 Jun 2016 - 13:08)
Marius
PostPosted: 13:18 - 02 Jun 2016    Post subject: No electric on xtr 125cc Reply with quote
Hello guys need some help got a lexmoto 125cc and got no electric even if i put a new battery, can some one help me pls?
PostPosted: 13:59 - 02 Jun 2016    Post subject: Reply with quote
You've checked / replaced the fuse(s), right?
Follow the +ve wire from the battery, look for an inline fuse or a fusebox, replace as necessary.
If that's not it, then I'd strongly suggest that you buy a multimeter first before throwing money at it.
Marius
PostPosted: 14:21 - 02 Jun 2016    Post subject: Reply with quote
Thanks rogerborg !!!!!!!
there is a fuse and looks ok, got a multimeter but what else I need to check with it? someone is suggesting to change the ignition coil and cdi box??
PostPosted: 14:51 - 02 Jun 2016    Post subject: Reply with quote
It "looks" OK? Do you have continuity across it? Do you have 12V+ across the battery terminals? Do you have continuity between the battery -ve and the frame and engine?
Marius
PostPosted: 14:54 - 02 Jun 2016    Post subject: Reply with quote
i will have to check and let you know! thank you very much!!!!!!!
The last post was made 10 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.21 - MySQL Queries: 16 - Page Size: 42.92 Kb
