Removing front wheel from ZZR600 (Safely)
Peperami
PostPosted: 14:54 - 03 Jun 2016    Post subject: Removing front wheel from ZZR600 (Safely) Reply with quote
Hi folks,
My ZZR600 will (sooner or later) need the front wheel removing for repair or maintenance. Can anyone reccomend any of the sub £100 gadgets on ebay designed for aiding wheel removal and do they actualy work?
While I fully understand how to remove the wheel bolts and calipers etc I am not clear on how to raise the front wheel high enough in order to get it clear of the ground for removal or the bike nose-diving into the ground after the wheel is taken out.
Someone told me to "just put blocks of wood under the exhaust pipes on the underside of the engine and use an old car-jack" but this seems to me to be an easy way to damage the exhaust system.
Question.
Can anyone point me in the direcetion of any kit on ebay that might help to safely support the bike and assist in removal of the front wheel please.
Regards,
Peperami.
CaNsA
PostPosted: 14:57 - 03 Jun 2016    Post subject: Reply with quote
Something like this is ideal.
https://www.ebay.co.uk/itm/Motorcycle-HEADSTOCK-Head-Lift-Paddock-Motorbike-bike-STAND-Track-/231611772539?hash=item35ed232e7b:m:mLdzWqSQ7dObYekEjFXgFCg
PostPosted: 15:22 - 03 Jun 2016    Post subject: Reply with quote
Do you have a center stand?
If so you don't need anything, if you don't by and abba stand
As people have told you blocks under the engine/exhaust is fine it won't damage anything, unless you are thick.
I have also in the past raised the front by loading the top box up with heavy shit.
The stand cansa as links will be shit IMO, it will get in the way and be flimsy.
Get a mate to push on the back of the bike and wedge a lump of wood under then exhaust. Trust me the exhaust is very strong and you won't damage anything. This way the support is out of the way and you don't need to work round it.
CaNsA
PostPosted: 15:30 - 03 Jun 2016    Post subject: Reply with quote
I've used them several times in the past on a zxr400 and didn't find it shit, flimsy or did it get in the way.
wr6133
PostPosted: 15:36 - 03 Jun 2016    Post subject: Reply with quote
Centre stand, block of wood and carjack works fine.
Just do it on nice level ground to avoid this
https://i1249.photobucket.com/albums/hh504/wr6133/IMG_20140716_105432_zpsaac4042b.jpg
Nobby the Bastard
Harley Gaydar
PostPosted: 16:07 - 03 Jun 2016    Post subject: Reply with quote
I have one remarkably like the one CaNsA suggested. The only problems I've come across is 1) you need to use it with a centre stand or rear paddock stand 2) You may need to remove the top fairing to get sufficient access and 3) a divvy is so tall that I had to put suitable lengths of wood under the wheels to rise the stand sufficuently.
Triumph Sprint ST 1050
Itchy
PostPosted: 16:23 - 03 Jun 2016    Post subject: Reply with quote
How cheap do you want to do it?
Super cheap? Put a milk crate/sand bags under the engine.
Slightly more expensive? Rope around the headstock and hang it fron rafters. If you have no rafters you can hang it from two windows at 90 degrees to each other. Somebody on BCF did this.
More money? Turn the foot pegs upside down then put car jacks under them and heavy stuff on the pillion seat.
You can also tie something to the pillion rail right up against a wall therefore preventing the front from rotating downwards then putting some bricks under the front forks.
The problem with front stands is if you ever need to remove the forks.
Itchy
PostPosted: 16:24 - 03 Jun 2016    Post subject: Reply with quote
wr6133 wrote:
Funny you should post that. As I've seen people change clutches (on a Fazer) by putting the bike on the side.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:26 - 03 Jun 2016    Post subject: Reply with quote
Itchy wrote:
On an exup, you don't even need to do that. Only a dribble comes out when it's on it's side stand.
dydey90
PostPosted: 20:13 - 03 Jun 2016    Post subject: Reply with quote
I dismantled most of the front end to do fork seals on mine, just used a car jack rested the side stand on spare piece of wood.
Just be careful because the axle bolt will be very tight and if the bike is balanced in this manner, then it will fall on any oaf stupid enough to not watch the bloody thing while attempting to undo said bolt. Then you'd be finding out if you could bench press nearly 200kg of Kawasaki, like aforementioned oaf.
Raffles
PostPosted: 20:27 - 03 Jun 2016    Post subject: Reply with quote
I use a number of 1/2'' extensions and a 14mm socket placed under the headstock to support the bike whenever I have to remove the front wheel on my ZZR. I'd post pics but I'm not at home ATM.
Alex A
PostPosted: 21:28 - 03 Jun 2016    Post subject: Reply with quote
A jack might be all you need. Preferably a hydraulic trolley jack.
Put the bike on the sidestand, use the jack to lift the exhaust headers, as close to the front of the bike as you can get. It will probably help to remove the lower fairing.
The bike should then balance on the three points of the rear wheel, side stand, and jack point, and the front wheel will be loose off the ground. It helps to loosen the wheel nut, caliper bolts and fork pinch bolts before you raise the wheel
But it's an easy method. I've used it with various bikes to remove wheels for tyre changes.
Top Tip: Don't raise the jack too far, and make sure the bike isn't disturbed whilst it's jacked up.
Suntan Sid
PostPosted: 09:04 - 04 Jun 2016    Post subject: Reply with quote
I bought a similar stand to this, for my FZ1:-
https://cdnll.discountramps.com/images/xl/front-motorcycle-stand__5.jpg
Never had any problems with it, although As I have no center stand I use it in conjunction with a paddock stand at the back!
J4mes
PostPosted: 09:15 - 04 Jun 2016    Post subject: Reply with quote
Suspend mine from the rafters in the garage with a fibre sling and a pull lift, but pretty sure someone on here did the same with a tall step ladder.
You could probably make a tripod out of about £10's worth of pine from the builders merchants and suspend your bike from that?
skiptalker
PostPosted: 09:17 - 04 Jun 2016    Post subject: Reply with quote
i used 2 wheelie bins either side of bike..wood between bins crossing handlebars rope from bars to wood worked a treat
jimspeed
PostPosted: 10:25 - 04 Jun 2016    Post subject: Reply with quote
I just used to put my zzr on its centre stand and hang a couple of 5 ltr cans of water off the grab handle on a bit of rope.
Hanging it from rafters etc works well if you have 2 ratchet straps too.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
RhynoCZ
PostPosted: 14:10 - 04 Jun 2016    Post subject: Reply with quote
THIS!!!
I once took the front wheel off the ZX7R, just using a paddock stand on the front wheel. Well, lucky me the bike just rested on some very soft junk, that was in my garage at the moment. No damage, phew. Razz
andym
PostPosted: 17:00 - 04 Jun 2016    Post subject: Reply with quote
I've never once had a problem with using a trolley jack to prop the bike up:
https://img.photobucket.com/albums/v320/andy36586/GPz750/balanced2.jpg
https://img.photobucket.com/albums/v320/andy36586/VFR_zpsc12mwnct.jpg
https://img.photobucket.com/albums/v320/andy36586/forksremoved_zps635ade0e.jpg
To be honest I'm less inclined to trust paddock stands etc (although the abba stand does look a little more secure)
Alex A
PostPosted: 17:08 - 04 Jun 2016    Post subject: Reply with quote
Exactly the method I described earlier. As it happens, I needed do to it today with the SP-2 so that I could take the wheel to have a tyre fitted:
https://s33.postimg.org/wsq4hs1db/SP2_Tyre.jpg
The axle stand at the front was there as insurance just in case the jack lost pressure whilst I was out. It's not supporting the bike at all.
Simple, quick and stable. No messing about trying to invent Heath Robinson solutions. And no front paddock stand or headstock stand in the way of taking the wheel out. It has the added bonus of being able to raise or lower the forks to align exactly with the wheel, so no messing about trying to hold the wheel up and feed the axle in from the side.
c_dug
PostPosted: 22:52 - 04 Jun 2016    Post subject: Reply with quote
https://i235.photobucket.com/albums/ee81/paddy2007dug/461625_10150801478555540_1939144548_o_zpso6vsugxx.jpg
https://i235.photobucket.com/albums/ee81/paddy2007dug/467852_10150801479825540_1173412726_o_zpszrzhk5ki.jpg
Be creative Mr. Green
techathy
PostPosted: 09:58 - 05 Jun 2016    Post subject: Reply with quote
If you're leaving the bike supported for any length of time I wouldn't rely on a hydraulic jack of any description, regardless of the jacks weight rating unless it has some kind of mechanical lock.
mysterious_rider
PostPosted: 10:42 - 05 Jun 2016    Post subject: Reply with quote
jack and a bit of wood/towel under the exhaust will be fine.
another zzr on its side. clutch case gasket pissed about a litre of oil out in 30 mins. Emergency halfords insta gasket and im good to go.
https://i270.photobucket.com/albums/jj88/mysterious_rider/3402669616722095479_zpsdl54miyk.jpg~original
KAWASAKIIIII
andym
PostPosted: 06:26 - 06 Jun 2016    Post subject: Reply with quote
Why? When I was rebuilding the GPz it spent weeks on the jack in all sorts of weather Rolling Eyes
techathy
PostPosted: 08:35 - 06 Jun 2016    Post subject: Reply with quote
In theory they can hold something up indefinitely. However, their common failure modes are evident when supporting weight for long periods but have far less effect during the process of lifting.
Just saying, better to be safe that sorry. How long does it take to drop something onto a stack of bricks?
davebike
PostPosted: 09:21 - 06 Jun 2016    Post subject: Reply with quote
The sensable secure way or doing it
https://www.ebay.co.uk/itm/Abba-Pro-Stand-Motorcycle-Bike-Pit-Paddock-Garage-Workshop-Stand-Lift-/371573074457?hash=item56837b2a19:g:LMgAAOSwP~tW48UU
Also several used on ebay
make sure you sort adapters fro you bike
Dave
NC750Xdct + others at work !
[email protected]
The last post was made 10 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 131.18 Kb
