Clutch switch issue Triumph Sprint ST 1050
BillyJ
PostPosted: 21:50 - 29 May 2016    Post subject: Clutch switch issue Triumph Sprint ST 1050 Reply with quote
Just put new levers on my triumph and now the clutch switch doesn't engage unless the levers are adjusted to position 5 or 6 (two furthest positions).
The new lever is obviously not engaging the switch unless it's pulled really far (like it is on the two furthest settings)
Is there a fix for this apart from bypassing the switch completely or keep it on setting 5 or 6?
Thanks Thumbs Up
Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser"
davebike
PostPosted: 08:39 - 31 May 2016    Post subject: Reply with quote
Put leavers on that fit !
We see this a lot in the workshop mostly crappy Chinese leavers
You may be able to glue a bit of plastic in the make the switch work
Or you down to bypassing the switch
Dave
NC750Xdct + others at work !
[email protected]
McJamweasel
BCF Junkie
PostPosted: 18:15 - 03 Jun 2016    Post subject: Reply with quote
Don't bypass the switch. The ECU uses it for much more than a starter lockout.
The last post was made 10 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 35.7 Kb
