Honda cg125 Mystery
sosborne
PostPosted: 12:45 - 06 Jun 2016    Post subject: Honda cg125 Mystery Reply with quote
Hi all, my CG has been in a garage for the best part of 4 months and they have still not been able to get it started so I thought I'd take it home and do my best. I'm now at a stage where she will start flawlessly, run for roughly 10 seconds (sounds good), however will then cut with no warning. Fuel has been drained and replaced, carb has been cleaned and checked, plug has been cleaned and is getting a strong spark, any ideas?
Two things I have noticed the garage has done since taking it out: What is this red nut (it seems like some kind of sensor), and is there any significance of the open hole gushing out air? Any help with either of these would be greatly appreciated.
Apologies for any naivety, this is a first for me. Thanks.
Mark65
PostPosted: 12:49 - 06 Jun 2016    Post subject: Reply with quote
Hole gushing air out-Crank case breather?
Red Fitting-Preheat on carb?
PostPosted: 12:55 - 06 Jun 2016    Post subject: Re: Honda cg125 Mystery Reply with quote
Are you starting it with or without choke?
What colour was / is the plug tip?
Is fuel flowing freely from the petcock into the carb?
If you shut off the petcock immediately when it stalls then drain the flow bowl, how much comes out?
Is that a remote choke cable? Is that original? Actually, is that carb original?
Red thingy, no idea. Looks unnecessary and over-complicated.
The cone filter won't be helping. Honda-san fitted an airbox for a reason.
sosborne
PostPosted: 13:13 - 06 Jun 2016    Post subject: Reply with quote
Thing is, since taking it back from the garage, I can no longer find the choke lever. I'm not entirely sure if I'm being very stupid or if the garage has done something there.
Plug was initially a dry, sooty black which I believe was causing it not to start. I cleaned it up yesterday and it now starts fine.
I checked fuel last night and it is indeed running freely.
I'll check the flow bowl later today if I can, thanks.
The carb is original as far as I'm aware.
With the crank case breather would it be acceptable to attach a hose to stop water and what not getting in and leave it or do I need to get my hands on a filter?
Meatybeaty
PostPosted: 13:43 - 06 Jun 2016    Post subject: Reply with quote
Hi what year is your cg, you could put a brand new carb on for £25-30, airbox off e-bay £10, a connecting pipe from crankcase to airbox or a small breather cap, at least with a new carb all seals are with it, but take advice from Rogerborg he knows his stuff on these Thumbs Up
sosborne
PostPosted: 14:03 - 06 Jun 2016    Post subject: Reply with quote
It's a 2001 I believe, I'll look into a breather cap now, cheers.
PostPosted: 14:09 - 06 Jun 2016    Post subject: Reply with quote
Put it back to standard, it'll run.
smallfrowne
PostPosted: 14:14 - 06 Jun 2016    Post subject: Reply with quote
On my cg there is a hose over the breather hole that just flops behind the engine.
The carb could well be original, there were a few fitted with an accelerator pump like that. Maybe the choke lever wasn't put back properly if they were just fettling with the carb, trying to get it to work - trace the cable, might have to take the tank off if it's hiding under there.
I'd go with Rogerborg's idea of checking the float bowl for fuel when it cuts out. Does it restart straight away? Might need the carb settings putting back to vaguely original settings if it's been fettled all out of whack.
In fact I'd start by checking the float bowl height which is easy with a bit of clear tube, like for fish tanks, and you don't have to take anything apart.
https://www.google.com/search?q=float+bowl+height+tube
(google link 'cause I'm too lazy)
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
PostPosted: 14:17 - 06 Jun 2016    Post subject: Reply with quote
No he doesn't, he rode one on his CBT that had a manual choke, and this copybike had a CG125 engine with a similar-but-distinct carb. Also manual choke, no funny red thing.
It looks to have been meddled with a bit, is my suspicion, but if it starts up then it can't be far off. Sight unseen I'd suspect that it's running rich and that the choke is fully on, or that the float height is too high.
4 months offroad though, urg. Original or copybike carbs can indeed be had for tens of pounds, I wouldn't be putting too much time into diagnosing. As Paddy says, it should run fine as stock and it won't cost much to put it back there.
Commuter_Tim
PostPosted: 14:35 - 06 Jun 2016    Post subject: Reply with quote
As above the red thing is a carb bowl heater to prevent icing, shouldnt make a difference unless its VERY cold outside, and even then it has no immediate effect.
It is a sign that your carb isnt an exact model for your CG though, or someone ripped the wiring out.
The CG carb models only seem to vary in wether they have an accellerator pump or carb heater, that one has both.
Everyone is right, replace the bits back to what you know as standard, new filter about £30, carb off Ebay, about another £30-50, learn to take it apart yourself and double check the carb jets inside have the right numbers for your bike, learn to adjust cabling, job jobbed.
They're simple devices on these bikes, I recommend buying a Haynes manual too.
I ride a Bandit 600... badly.
sosborne
PostPosted: 14:39 - 06 Jun 2016    Post subject: Reply with quote
Thanks for all the replies.
The bike recently starts straight away after stalling every time.
I'll try check the float bowl and choke later on.
Commuter_Tim
PostPosted: 14:45 - 06 Jun 2016    Post subject: Reply with quote
I am genuinely curious about the open air filter being wrapped in tape though, is this some sort of "performance" mod? Thinking
sosborne
PostPosted: 14:56 - 06 Jun 2016    Post subject: Reply with quote
I'm as curious as you are, it came back from the garage with it so I just assumed it was there for a reason, I doubt I'll be taking it back there in the future.
Commuter_Tim
PostPosted: 15:09 - 06 Jun 2016    Post subject: Reply with quote
I'm sure there is some ridiculously bodgerific "reason" for it, but my thinking is with the direction of wind flowing at you, at best all it will do is trap dirt in behind the tape.
BTW standard CG's have enclosed air boxes, again can be had on ebay.
Anybody with half a brain and some hand eye co-ordination can pickup mechanics.
The mechanic I used before I did stuff myself didn't even know the name for the accelerator pump let alone how to set it up. (this is unlikely your issue however as that is mostly kicking in when you turn the throttle)
Oh yeah, with that crank case breather being open to the environment, drop your engine oil and put in fresh stuff (any 10w40)
As above it is supposed to have a rubber hose attached to drain down under the bike, who knows what crap has been getting in there.
WD Forte
PostPosted: 16:37 - 06 Jun 2016    Post subject: Reply with quote
I'm astounded by this
"my CG has been in a garage for the best part of 4 months and they have still not been able to get it started"
Whaaaat?
What sort of mechanic cant get a simple CG sorted out or at least identify the problem?
I mean, if it were multi cylinder computerised EFI lump festooned with sensors you'd maybe cut them some slack, but a CG?
bikers smell of wee
The last post was made 10 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 83.77 Kb
