| rubyhorse2 |
 rubyhorse2 Traffic Copper
| brains_t |
 brains_t Nitrous Nuisance
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| stinkwheel |
 Posted: 19:04 - 06 Jun 2016 Post subject: |
Depends on a few things.
Are the lights on all the time? Lights use lots of power. Ignition systems don't (as a rule) fuel injectors probably use a bit more.
Every bit of electronic fuckwittery fitted will use more power. Does it have ABS?
Using the starter will devour power it. Can you bump start it instead?
I'd imagine a more modern bike with an ECU and suchlike would have a tantrum at a much higher voltage than an old points ignition bike. I've ridden a Jawa 350 nearly 450 miles on a single battery charge (and they take a small battery).
I'd imagine you could probably pull a few fuses to maximise range. Things like the lighting circuit and such. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 19:14 - 06 Jun 2016 Post subject: |
It does depend on the battery and the draw of the system. I did, with no charging (full battery, 1 start of the engine) about 25 miles, with the lights on, on a CB-1 (small battery + the lights were always on, no switch) Then, I swapped the battery for my mate's battery and push started him with my drained battery in his motorcycle. Got home, changed the burned stator. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| Kickstart |
 Kickstart The Oracle
| Polarbear |
 Polarbear Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 21:39 - 06 Jun 2016 Post subject: |
Yes you can disconnect the regulator. If you have a fully charged battery I would expect to get at least 30mins riding from it with the lights off. I rode my xj1100 from Beaconsfield to Kent around the M25 though that was a carbed bike with no pump, and it used to manage it on a single charge with the lights on. If the motorway was backed up it would start popping a bit toward the end if I used the indicators and brakes. ____________________ a.k.a 'Geri'
| Itchy |
 Itchy Super Spammer
 Posted: 21:54 - 06 Jun 2016 Post subject: |
Near about 10 years ago my reg rec on the NTV died at Babyam's New Years barbie. I left at 2am.
It lasted just under 30 minutes before dying about 200metres away from my home at the time.
I did however turn off the lights and the bike had carbs and it had been bump started. Though it was a twin spark. IIRC it did have a fuel pump that I'd by passed ages ago. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| G |
 G The Voice of Reason
| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 22:38 - 06 Jun 2016 Post subject: |
my reg-rec went on the ZZR, I lasted a month before replacing it, had to bump start it a couple of times towards the end and it would sometimes struggle to start - was running with the lights on and, it seems, was still charging when running at high revs just not at tick over and stop start riding - not great for commuting!
Mechanic said it was a good advert for motobat. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| rubyhorse2 |
| G |
| rubyhorse2 |
The last post was made 10 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
