The constantly compressed forks quiz.
NJD
PostPosted: 22:26 - 08 Jun 2016    Post subject: The constantly compressed forks quiz. Reply with quote
So before we go any further I should say I post this thread as a request from the Borg and also that I have phoned the shop that serviced the bike and will be taking it back tomorrow. Place your bets on (a) if I will or won't survive a 10-12 mile ride with the below issue and (b) what the cause is and or was by the time I post something tomorrow.. if I'm alive. <dramatic music>.
So the long and short of it is that last Friday I collected the bike from being serviced and rode home / to and from work with no issues. After a long weekend of work I used the bike to get to work yesterday with no issues.. this is where it gets funky. So I come to my bike after leaving work and found that my bar end / clutch lever was resting against the top long bar of one of these, basically somehow the front end had moved somewhat and it looked like the bike had slipped as the bar end / clutch lever are usually hovering over or they're more to the left than what they where. I've no idea what happened but it didn't look anything like an attempted theft because nothing was scratched or damaged and the locks hadn't been touched, in the "what grinds your gears today" thread I said it could have been someone attempted to move the front end or the side stand had slipped a little, well.. until this morning when there's a new possibility.
So I'm happy when I get on my bike to discover that the clutch lever isn't bent or damaged and everything works as it should and nothing has been touched until.. and this is where the actual issue starts.. I pull away and instantly the front end feels unstable. I'm talking it feels like the front tyre is flat and there's juddering from the front end. Anyway I make it home and do some checks and come to the conclusion that there's noting wrong. Load the bike up this morning and find that the forks, once compressed by pressing the front brake lever and pushing down, are not bouncing back.. at one point I think they didn't even want to compress.
So either something's happened that I can't figure out while I've been in work or while parked the forks have decompressed (assuming the issue had already started and I hadn't noticed) hence the slip or moved bars slightly and no signs of anything else.
In regards to the service last Friday the guy on the phone basically said that he couldn't think immediately how the service could of caused it as there's no work done on the forks during that service but was more than understanding (since I've only used them and new who I was by voice / bike) in requesting to see me as soon and wanting to get to the bottom of it.
When I was pumping the forks this morning to start out with they basically sounded solid and made a noise, I can't recall, and then I noticed that I had to grab the underside of the grips and pull them upwards to get the forks to fully bounce back <uh oh, phone shop leave bike at home moment>. The fork oil, not that I know how often it needs changing of the top of my head, has to my knowledge never been changed.. and I've owned the bike from new. 7000km and about a year and a half old? Forks show no signs of leaking oil when compressed. Fork seals, to my limited knowledge of what I'm looking at, are all firmly in place and show no signs of leakage or tears. Fork gaiters are without tears or signs of damage. Only signs of rust on the fork legs are a small amount in the very small gap between the fork gaiter and fork seal on the right leg, other than that I've noticed nothing. Issue has occurred without any pre-warning signs and as above after limited use after a service.
Over to you.. (again this thread is for entertainment purposes and not a diagnosis).
PostPosted: 23:29 - 08 Jun 2016    Post subject: Reply with quote
Normally it is the fork spring and the compressed air gap that extend the forks again. Springs alone should do it easily, and the chances of the fork springs snapping are slim.
Dampers in the forks couple have become blocked, hence slow return. But would probably need to be quite a blockage.
My guess would be the forks are jamming. Possibly a fork bush has managed to come out of position and is jamming the forks, or the forks are twisted in the yokes badly and binding (but the most likely way that would happen would be being knocked over, and I would expect other visible damage)
Katy
Hong Kong Phooey
PostPosted: 00:03 - 09 Jun 2016    Post subject: Reply with quote
If it has adjustables, has rebound been dialled all the way to 11?
Seems odd for both forks to fail same time.
Not likely to be fork oil degradation at that mileage imho, and they say they not touched it anyhow.
Edit after rereading. Possibly fork tubes bent, maybe hit by car reversing - pushing forks into kerb. Look down the tubes from top and inspect from the side at distance (remove gaiters), more than a couple of degrees would be visible, straight edge probably not required if that bad to cause binding.
NJD
PostPosted: 00:07 - 09 Jun 2016    Post subject: Reply with quote
Suspension, adjustable, re what.. oh I'm confused.
Should of said sorry it's a Lexmoto Arrow. Not that this means anything to me (do you even like bikes bro?) but specs say Telescopic forks, if that helps with your guessing.
jaffa90
PostPosted: 00:11 - 09 Jun 2016    Post subject: Reply with quote
Something sounds a bit bent to me.
PostPosted: 00:13 - 09 Jun 2016    Post subject: Reply with quote
Suspect nothing adjustable on that.
Tbh, I would say the first thing to do is to strip the forks and check them over. Springs possibly but I suspect most likely a bush is very badly worn and is jamming the fork
Katy
NJD
Well whatever leg it is at least it's not the third one. Wheeeeeeeey. Dance!
I try. Laughing
Hong Kong Phooey
PostPosted: 00:16 - 09 Jun 2016    Post subject: Reply with quote
Edited post, you don't have adjustable forks so may be bent Sad
PostPosted: 08:33 - 09 Jun 2016    Post subject: Reply with quote
I'm struggling to picture how that would happen suddenly.
Even if the bike was dropped and picked up and the forks are twisted in the yoke, I'm not clear in my head on how that would actually stop them rebounding.
A car reversing into it and freakishly banana-ing the forks while not knocking it over is just barely conceivable. Do they look straight?
Suntan Sid
PostPosted: 12:29 - 09 Jun 2016    Post subject: Reply with quote
Some has stolen the springs from one or both of the forks!
PostPosted: 12:39 - 09 Jun 2016    Post subject: Reply with quote
Put the bike back, maybe they'll return it.
https://www.arrse.co.uk/community/attachments/scannedimage-1-jpg.193928/
mysterious_rider
PostPosted: 13:05 - 09 Jun 2016    Post subject: Reply with quote
Hello has the front wheel been off at all? If the spacers are wrong or missing it will lock the forks tight. Sounds silly but iveseen it happen.
Loosen the axle and bounce.
KAWASAKIIIII
NJD
PostPosted: 14:42 - 09 Jun 2016    Post subject: Reply with quote
To me, yes. The steering moves as it should (from full lock left to right without any noises or resistance) and on the centre stand, as to my understand the steering should do, it naturally falls under its on weight to one side full lock and moves the other with no resistance.
I'll keep it short, rather than attempt to fully explain where the bike is left, and say that there's no chance that a car could even get close to where it is left. However I'd say that there is a chance that it could have been knocked into by a passer by with a trolley while I've been away.
The bit that stumps me is that the forks are randomly sticking. No pre-warning signs, no signs of leaking oil or damage on forks, nothing looks out of place or bent.. I'm clueless.
Anyway, I survived (as you might have been able to tell) the ride and managed to come to an agreement on what the cheapest way to fix the issue would be.
To start with, after they had a look at the bike, it was straight away diagnosed as both the forks would need taking out, stripping, replacing seals and oil and then there's still a chance that the issue would be there. The mechanic did say that he'd be keen to strip the forks further to save me having to come back and pay twice (if the oil and seal change didn't solve the issue) but would push the labour costs up and wasn't really a cheap job on the whole.
I can't recall an accurate figure, since multiple of them where thrown around, for the above work but the figure £170 sticks in my head. Needless to say that when I eventually do sell the bike I'm only expecting £400-500 if not £550 at max so the above price was practically a good sum of the bikes value at this point and didn't even seem worthwhile having the work done.
Anyway, after I, the shop owner and the mechanic talk for a little while we come to the conclusion that its cheaper to order and fit two new forks than it would be to attempt to strip and repair the current ones. Then the other shop owner throws in a nice gesture and we shake hands on a set rate of 1/2 n hours labour.
So, that's the end of that one, hopefully. All that's left it to await the text and empty my wallet <Insert Borg's money drain down a hole.gif>. I made clear that I want the current fork legs putting to one side and I'll be back to pick them up at a latter date. They're not buggered they're just sticking so I can either 1) sell them on ebay 2) sell them with the bike as spare parts or 3) attempt to repair them myself.
I got it right for once?
PostPosted: 15:27 - 09 Jun 2016    Post subject: Reply with quote
£113 (retail, with gaiters) price on two new forks, plus delivery, plus half an hour independent labour? That's not actually too daft and I agree that it's better than paying for hours of labour to diagnose, strip, re-assemble and then find there's still something wrong.
It might even make sense to just replace the forks rather than even replacing the seals, which speaks volumes about today's disposable culture. <crying-indian.jpg>
Top prize would have gone to whipping them off yourself and repairing or replacing whichever one is hooky (and it's likely to be one). Mudguard off, caliper off, axle out, slacken the yoke clamps and the forks drop right out.
Ideally remember to put the bike on the centre stand first. Whistle
It is a weird problem though, I'm interested to know what's going on there.
NJD
PostPosted: 16:01 - 09 Jun 2016    Post subject: Reply with quote
£56.55 x 2 = £113 + £27 (labour cost) = £140.
That's assuming I don't get charged for fork oil and seals. Do new forks come shipped with oil in them and seals already in place included in that £56.55?
I'll see if they can shed any light on the issue when I get to go ahead to pick it up. If not then I could have a crack at attempting to work on them myself (probably at a very slow pace) following the manual. Can't do any harm since they're not going back on the bike and are potato'd (slightly) anyway.
The only other thing that I haven't mentioned thus far is that I secure the bike with a chain looped around the fork leg through the frame and then around an unmovable object, like this, could that have any impact on the issue? Or turning the bars to check the steering lock is on when secured like the above? Personally I'd say not since I've been securing the bike the same way since forever and have never had an issue.
Having a go at the forks myself might provide a better insight though.
bamt
PostPosted: 18:53 - 09 Jun 2016    Post subject: Reply with quote
It's possible that the bike has been knocked sideways and therefore the chain has put a sideways strain on that fork, bending it outwards. Unlikely, but I guess it depends upon the weight of your bike and strength of the fork.
Chaining it up like that, I'd be tempted to loop the chain through the front wheel rather than the fork. That stops somebody nicking that wheel, whereas a single chain looped through the frame and forks is redundant through the forks (your not stopping any parts being stolen, and the loop through the frame stops the main part of the bike going - obviously subject to a decent chain).
NJD
PostPosted: 19:31 - 09 Jun 2016    Post subject: Reply with quote
Couldn't comment until I get the forks back.
All I can say is that both forks have failed at the same time and in the same way, they're both failing to rebound out of the blue without any warning. The more I think about it, and not that I've suddenly become an expert in a day or two, is that it's got to be something internal. Only way anyone will ever know I suppose is if I do have an attempt at looking at the inside of at least one of them.
That being said one thing the co shop owner did say to the mechanic when he was trying it in front of me was "What do you think, brushes?"
If anything I'll have two forks to mount on my bedroom wall with some brackets and possibly play with at a future date, always a good keep sake. Life, am I doing it right? Laughing
PostPosted: 22:41 - 09 Jun 2016    Post subject: Reply with quote
Seems more likely that one is sticking and preventing the other rebounding, but you won't know until they're off the bike.
NJD
PostPosted: 23:16 - 09 Jun 2016    Post subject: Reply with quote
Just glad there's the escape route of fitting brand new forks and it works out (or will in this case) cheaper than an attempted repair would (hopefully).
The gift that keeps on giving.
NJD
PostPosted: 20:18 - 14 Jun 2016    Post subject: Reply with quote
Collected today, £140.
Non the wiser as to what the issue was, can either fix in my own time (or at least attempt to) or just sell them on.. undecided as of yet.
Ride back was fine (so it was the forks) but managed to find the worlds biggest pot hole, sods law. Got back to base and since I was so tired I started compressing the forks and convinced myself I'd buggered another pair.. locked it up and left it alone, been a long week. Sleeping
Only annoying thing was that by the time I'd got home (not that I checked if this was the case before setting off from the shop) the fork gaiter on the left leg was a fair way down (as in held in place by the clamp) so took the locking clip out and pushed it all the way up and then put the clip back on. Only thing is you can pull down and push up the gaiter by hand with the locking clip in place.. probably just playing too much attention to nothing. Think I've still got to move the right one up a little also. Other than that I've got to apply some ACF-50 to the bottom of the leg when I get time and jobs a gooden.
As to the old fork legs can only think internal since the entire leg (beside some small amounts of surface rust) looks fine (ie; no dents). Can only think internal.. either way was cheaper to get new legs and solve the issue than attempt to find the problem with the old ones.
Hopefully it's the end of this tale.
PostPosted: 22:25 - 14 Jun 2016    Post subject: Reply with quote
You're going to have Phantom Fault Syndrome for a while. Please do pick up those old forks and figure out what's going on, I'm genuinely puzzled.
NJD
PostPosted: 22:52 - 14 Jun 2016    Post subject: Reply with quote
Rogerborg wrote:
Phantom Fault Syndrome... Please do pick up those old forks
Funny you should write this. I compressed the legs by simply pushing down on them and then letting go and they rebound without any trouble, I'm starting to think I imagine half of the issues this bike has.. just loves to wind me up. That being said I defiantly didn't image the ride I had from work and to the shop, riding with suspension that's constantly compressed and wont allow you to corner properly isn't something you forget in a hurry.
On the plus side I got an indicated 50 after giving it some beans on an open road, first time in a while I think I've overtaken someone and they've remained in the mirrors.. somethings working right then.
Simple case of loosening the hex bolt at the bottom and then the.. oh whatever its called.. at the top and then the hole thing should come out in one piece, right?
The last post was made 10 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 128.04 Kb
