Combating the heat - What do you wear?
Jayy
Mr. Ponzi
PostPosted: 15:06 - 09 Jun 2016    Post subject: Combating the heat - What do you wear? Reply with quote
It's catch 22, you want to go out on the bike but on a really hot day, the temptation is to wear less gear because it's like riding a sauna.
What's the coolest way to keep safe?
For example, last night I just had the one piece on and a pair of boxers underneath because it was horribly hot and after 30 mins you're sweating your bollocks off anyway.
Draggin jeans and some kind of kevlar hoody? Doesn't help on the Ducati having that fuck off exhaust pipe loop right under the seat either.
TheArchitect
PostPosted: 15:12 - 09 Jun 2016    Post subject: Reply with quote
My Richa textiles are pretty well vented. With the lining out it's actually very comfortable with lots of air rushing through. Plus it has full armour in all the right places.
GSXR 600 K6 - Stolen
MT09 - Almost stolen
recman
PostPosted: 15:16 - 09 Jun 2016    Post subject: Reply with quote
My leathers work best in the heat due to the stretchy fabric inserts in the arms and around the testiculars.
Snowdonia Rider
PostPosted: 15:20 - 09 Jun 2016    Post subject: Reply with quote
I wear my Mankini if I'm in the mood for it, tinted visor of course.
I wear kevlar jeans and just open all the vents on my RST textile jacket, it has a non removable liner so I'm a bit buggered. I have leather gloves with no padding. My boots are Alpinestars with their own version of Goretex (Drystar). I don't get over hot in those, they're pretty good in all fairness. I think it's the kevlar jeans that rescue me though in the hot weather.
MarkJ
PostPosted: 15:31 - 09 Jun 2016    Post subject: Re: Combating the heat - What do you wear? Reply with quote
My RST two piece is perforated pretty well so I'm OK as long as I'm not sat at lights all the time. Kevlar jeans and perforated jacket is my other option.
Ceramic coat the loop?
Itchy
PostPosted: 15:35 - 09 Jun 2016    Post subject: Reply with quote
Ride faster.
See my Spain tour thread. I wore full leathers all the way to the South of Spain it got to mid 40s temp.
With your riding gear you can soak your gear (not leather though as it will damage it) in water and create an ghetto swamp cooler which will suck the heat of the air before it hits you.
NJD
PostPosted: 15:37 - 09 Jun 2016    Post subject: Reply with quote
Commute: I don't really see a need to sacrifice safety by removing layers here because I'm always on the move and I'm only going from point A to B. The most important thing is that I drink loads of water and try not to stop in traffic as much. The moment I stop in traffic is when I notice a dry mouth and get very warm and start to toast.
Main point is that I wear all the gear all the time and nothing less regardless of weather. I'll open all the vents on my jacket, naturally, but beside that there's not a whole load of change. Sometimes I'll wear ankle boots, summer gloves and a leather jacket instead of my WP / textile stuff but beyond that nothing.
Casual: T-shirt / textile or leather jacket, summer gloves and ankle boots.
There's room for debate on the bottom half depending on how I feel when I awake because after I recently became acustom to zipping my jacket and trousers together so the jacket doesn't slide up my back in the event of an off I don't really feel all that confident in kevlar jeans given that they don't have the connection zip to the jacket, I've looked at RST ones and even they don't. Sometimes I'll wear the jeans regardless because walking around town in textiles would be suicidal but try to avoid doing it as much as possible. If I do go for the textiles then I'll wear nothing but boxers underneath.
Jayy
Mr. Ponzi
Not just riding though, when you stop somewhere and just milling about, leathers are horribly un-comfortable especially when the sun is booming down on you.
Saw some guys absolutely nailing around in shorts and t-shirt last night and it made me cringe. I'm not one of those, "omg he's not working gear" nazis, I believe people know the risks and if they want to do it then that's fine, not hurting me.
As much as kevlar jeans / tops are supposed to stop your skin taking a grating, it aint going to be as soft as a sliding down the road in leathers.
I'm due a new set of leathers anyway soon, been a couple of years since buying any and I wonder if there are any more specifically made for the hotter weather with more vents / perforation than usual.
When it's winter, bang the textiles on so not a problem.
Jayy
Mr. Ponzi
PostPosted: 15:41 - 09 Jun 2016    Post subject: Re: Combating the heat - What do you wear? Reply with quote
https://i.imgur.com/zG3sfpw.jpg
It already has some heat shielding in there, I have seen people remove the plastic cover and wrap the pipe in exhaust wrapping. What is the wrapping for?
Evil Hans
PostPosted: 15:45 - 09 Jun 2016    Post subject: Reply with quote
Currently wearing Kevlar jeans and a vented textile jacket. Bit sweaty if you're walking around in it but fine once you're on the bike.
It's my feet that get too hot in leather touring boots. Might swap them for crocs Wink
MarkJ
PostPosted: 16:06 - 09 Jun 2016    Post subject: Re: Combating the heat - What do you wear? Reply with quote
Keeps the heat in then sends it further down the pipe, wrap and ceramic coating do more or less the same thing I think.
https://www.ducati.ms/forums/56-superbikes/321449-1199-s-thinking-about-ceramic-coating-exhaust.html
https://ugc.ducati.kontain.com/photo/20120714/prod_99f4f8f2-028f-4e99-9ccd-ea7424527202/tb_1920x1080.jpg
Apparently you can coat the inside too which might be 'better'. I've never done this, so don't know.
Albigularis
PostPosted: 16:14 - 09 Jun 2016    Post subject: Reply with quote
I'm usually wearing jeans/tshirt in this weather. If it's a short ride to the shops I'll keep shorts on. Wearing a jacket in this weather makes me feel like I'm going to pass out. If im heading up some country roads I'll chuck leather bottoms/boots on with a tshirt. I made the mistake of dragging a knee in jeans once before, definitely won't do that again...
I accidentally put my textile commuting gear on when it looked rainy a few mornings ago, 23 degrees on the way home, I was soaking underneath.
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
rhys99
PostPosted: 16:22 - 09 Jun 2016    Post subject: Reply with quote
Commuting i wear kevlar jeans and leather jacket but when im just out riding i wear full leathers. Only gets sweaty if you're in traffic. Doubt you got that hot hooning around Pimbo though Very Happy
Jayy
Mr. Ponzi
PostPosted: 16:32 - 09 Jun 2016    Post subject: Reply with quote
Hmmmm! You were there yesterday? I was nailing on a fair bit like Very Happy
Why didn't come say alright?
rhys99
PostPosted: 16:47 - 09 Jun 2016    Post subject: Reply with quote
I was, on the Aprilia 125 with the lad on the WR Smile
Matt B
PostPosted: 16:48 - 09 Jun 2016    Post subject: Reply with quote
My Red Route ones have a short zip that attaches to both my jackets. Just find a local alterations/tailoring place and get them to sew a short zip onto your jeans.
Jayy
Mr. Ponzi
PostPosted: 16:50 - 09 Jun 2016    Post subject: Reply with quote
I think I went past you on the back wheel at about 130 (closed private road) Laughing
Val
Oxford Cool Dry base layers, John Doe Kamikaze kevlar jeans, white helmet X-Lite 702 it has plenty of vents too many if you ask me, and leather Furygan Speed 3D mesh front jacket it lets all the air in:
https://www.motolegends.com/jackets/furygan-speed-mesh-3d-jacket-black-white.html
When I bought the jacket few months ago my friends were mocking me about no proper summer here, who is laughing now Laughing
Finally ride faster - not good for average speed cameras on my commute though Crying or Very sad
rhys99
PostPosted: 16:56 - 09 Jun 2016    Post subject: Reply with quote
haha, you did on my way in. I did park up too but didnt stay too long.
M.C
PostPosted: 17:01 - 09 Jun 2016    Post subject: Reply with quote
I wear kevlar jeans all year round, don't really get too sweaty, and the jacket's partially open with a t-shirt underneath. Oddly today my head got really hot, haven't been that uncomfortable since I stopped wearing a black helmet.
Only recently got some Furygan TD21 summer gloves (recommended by someone on here), no more sweaty hands, knuckle protection and I can keep them on when fiddling with zip pockets etc. Also impressed they're warm enough when it's 10-12 degrees in the early morning, and they appear to be waterproof based on the thunderstorm I got caught in the other day.
ScaredyCat
PostPosted: 17:07 - 09 Jun 2016    Post subject: Reply with quote
Wear Becka Coolware underneath ... then just chillin'...
Wear a belt? https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/209250
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Jayy
Mr. Ponzi
PostPosted: 17:08 - 09 Jun 2016    Post subject: Reply with quote
Can't beat pimbo on a wednesday night, wheelies and laps, it's like a race track... just with arctic lorries Laughing
andyscooter
PostPosted: 17:22 - 09 Jun 2016    Post subject: Reply with quote
Jeans and jacket same as when it'sdry
Steve McQueen This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 18:25 - 09 Jun 2016    Post subject: Reply with quote
I wear my textile jacket 90% of the time, year round, just sold my leather as I never really got on with the shape and lining. I also wear a non-biking leather jacket I have (blouson style) occasionally if I know it's not going to rain. Legs are plain jeans, or chinos if commuting, and my waterproof leggings live rolled up on the rack all year round. I always wear gloves, but this year I've finally replaced my old worn leather summer pair with a vented textile pair found in the bargain bin at J&S.
I'd rather be comfortable in non biking gear and paying attention, than have all the gear, uncomfortable and making mistakes.
The last post was made 9 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 133.59 Kb
