Slight clicking from front spocket + other Qs - YBR
JoeDaStudd
PostPosted: 09:50 - 10 Jun 2016    Post subject: Slight clicking from front spocket + other Qs - YBR Reply with quote
Hi,
After getting the tyres changed on my ybr there has been a slight click when pushing it in neutral or manually spinning the back wheel.
Originally I thought it was just the feelers from the new tyre catching on something, but upon inspection I noticed it was coming from the front sprocket.
I've cleaned the chained and relubed the chain, checked for tight spots, damage, etc and adjusted the chain (was just within tolerance ~30mm out of the 20mm to 30mm, now ~22mm).
No luck.
Any ideas?
Second question while trying to troubleshoot the clicking noise I did two very stupid things.
First I managed to forget I put the disc lock on the front and pushed it a bit, the lock knocked into the brake.
With shame (the disc lock had the reminder string, but I didn't put it on the handlebar...) after checking for damage I put my bike away only drop (wasn't fast, the bike has engine protectors and it was onto grass) it while wheeling it out the next time I came to use it.
After the usual checks and nothing visible I took it for a short ride and it felt a little off (the front felt like it was forcing down), but wasn't sure if that's because I was carting around my 2m Almax III chain and lock (heavy bugger).
The issue was much less noticeable after a mile or so
At which point I got a little paranoid and started checking everything.
The front wheel will only spin about 2 revolutions when on the centre stand, but I genuinely can't remember if it did this before.
How freely should the front wheel spin?
Anything to check or simple I'm missing before I continue non my paranoid state and remove the front brake and check it all over?
jaffa90
PostPosted: 11:23 - 10 Jun 2016    Post subject: Reply with quote
Are you checking the chain slack with somebody sat on the bike both feet up and side stand down on a block of wood?
The wheel sounds free enough but check the disc after a run for HEAT.
Evil Hans
PostPosted: 11:48 - 10 Jun 2016    Post subject: Re: Slight clicking from front spocket + other Qs - YBR Reply with quote
Check all the rollers on the chain ... mine did this when one of the rollers had disintegrated just leaving the pin.
whitedevil
PostPosted: 11:57 - 10 Jun 2016    Post subject: Reply with quote
check your wheel alignment. youtube string method
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
JoeDaStudd
PostPosted: 12:40 - 10 Jun 2016    Post subject: Reply with quote
I've been checking chain slack on centre stand at the mid point on the chain, no extra weight on the bike itself.
Didn't think to check for heat I'll give it a shot.
Evil Hans
PostPosted: 15:44 - 10 Jun 2016    Post subject: Reply with quote
This could be your problem! You'd be amazed how much it tightens up with some weight on it.
JoeDaStudd
PostPosted: 16:43 - 10 Jun 2016    Post subject: Reply with quote
Are you being serious as the Haynes manual, owners/service manual and every guide/video I've seen mention nothing about adjusting the chain with extra weight on the bike Neutral .
I'll go over the chain one roller at a time and check the wheel alignment, hopefully this rain stops and I can get it sorted tonight.
Snod Blatter
PostPosted: 20:27 - 10 Jun 2016    Post subject: Reply with quote
Yes he's serious. When you sit on it the suspension will sag and the distance between sprockets will lengthen - you will probably find that the chain is drum tight when you are sat on it. This is really Not Good™ as it will not only promote quick wear of the chain and sprockets but also puts a lot of load on the bearing that holds the output shaft in place (the one with the front sprocket on it) and if you knacker that you're in serious trouble.
I would like about 3cm of uppy downy when sat on the bike and poking the chain with a spanner/stick/whatever. A slightly loose chain is much happier than a tight one. Get a helper to poke the chain if you are a moron/dyspraxic and can't manage it yourself.
Also two spins of the front wheel is fine. It's not super, but it's okay.
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
jaffa90
PostPosted: 21:13 - 10 Jun 2016    Post subject: Reply with quote
We are serious.
herulach
PostPosted: 23:19 - 10 Jun 2016    Post subject: Reply with quote
Checking slack on centre stand is fine, provided that the measurements you're using are for that. If its out of the manual (3cm on the centre stand) its fine. If its clicking from the front sprovket, probably wants clutch adjusting - does it go away when you pull the clutch in?
YBR 125>FZS600
Commuter_Tim
PostPosted: 20:04 - 11 Jun 2016    Post subject: Reply with quote
Haynes for my CG, CB500 and Bandit all say measure slack on centre stand, There are bikes that should be measured under weight though.
Who are you going to trust, Haynes/Manufacturers or some randoms on BCF? Neutral
Of course the bike does sag down and the chain tightens under weight, I'm willing to assume the men in white coats with pocket protectors took that into account.
I ride a Bandit 600... badly.
jaffa90
PostPosted: 20:16 - 11 Jun 2016    Post subject: Reply with quote
Haynes state that for safety reasons. Every bike I've had and I've had plenty in 45 years I've always simulated riding conditions (not bumps) when checking chain slack. Then you can put it back on the centre stand if fitted and see/feel the difference and note it.
Watch Moto GP and see them chains wagging up and down at 150mph.
Commuter_Tim
PostPosted: 20:39 - 11 Jun 2016    Post subject: Reply with quote
I'm not so arrogant to say that you are wrong, but where are you getting the measurement specs from if not manuals? and how would you know the method in which those people decided on said spec? (stand or No) Thinking
I just feel if we are taking the measurement directly from the manual, but disregarding the "on the centrestand" bit, then it throws it all out of whack.
Not that a slightly loose chain is all that bad compared to overtightened ofc.
jaffa90
PostPosted: 01:24 - 12 Jun 2016    Post subject: Reply with quote
I don`t need a manual to set any chain tension, it`s common sense that you need chain slack when the swing arm is on max movement.
Trail type bikes need more slack so your talking 50mm min without a rider sat on it. It`s not rocket science when the front of the chain pivots on the gearbox sprocket and the back of the chain pivots on the swing arm.
PostPosted: 02:19 - 12 Jun 2016    Post subject: Reply with quote
https://www.youtube.com/watch?v=u6ZsWwQ072E
redeem ouzzer
PostPosted: 09:49 - 12 Jun 2016    Post subject: Reply with quote
Most of the above is bollocks. The chain slack figures in the factory manuals are virtually always given without load. You wouldnt want 30mm of slack under load, the chain would flap around like a shithouse door.
Be a REAL MAN!
JoeDaStudd
PostPosted: 23:27 - 12 Jun 2016    Post subject: Reply with quote
Forgot to update this thread.
So I checked over all the chain link by link and nothing.
The alignment was pretty off which reduced the clicking a lot.
Still making the noise, I'll check the clutch play.
jaffa90
PostPosted: 23:49 - 12 Jun 2016    Post subject: Reply with quote
How did you find that out?
Are the sprockets running in the middle of the chain?
Hong Kong Phooey
PostPosted: 23:54 - 12 Jun 2016    Post subject: Reply with quote
What's the condition of the front sprocket? If it's hooked you should change.
Because it's hidden it tends to go unnoticed.
The last post was made 10 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 100.96 Kb
