| Hefty |
 Hefty Could Be A Chat Bot
 Posted: 23:52 - 12 Jun 2016 Post subject: 50 miles from a full tank?! |
Only getting 50 or so miles from a full tank on my '98 Hornet.
I'd read the tank range was low but never actually looked up what I should be getting.. Apparently I should expect at least 90 miles before flipping the reserve switch. Up until now i'd just made a habit of filling up periodically so it didnt matter, but the other day on my way to work I ran out of fuel at 47 miles & used the reserve to get to the nearest station.
Only had the bike just under a month
Am I leaking fuel? I'm noticing or smelling anything. Could it be a carb problem? How would I check either? I'd like to avoid going to a garage as moneys bloody tight right now. Any help would be appreciated  ____________________ '13 Honda CBF125 // '99 Suzuki SV650s // '98 Honda CB600F Hornet |
| CaNsA |
 CaNsA Super Spammer
| Itchy |
 Itchy Super Spammer
 Posted: 00:05 - 13 Jun 2016 Post subject: |
Simple things to check:
You're not being heavy handed on the throttle.
Check your brakes aren't dragging/seized. A quick way to test is if you can roll it around freely. If it needs leaning into to push it around then you may have seized brakes.
Another way is after a ride spit on your discs. Seized discs will be much hotter than normal brakes.
On the Hornet it takes 2 or so hours to de-seize them. Or 30 mins on the back.
Air filter, undo the tank bolts lift it up and open the airbox. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| jaffa90 |
 jaffa90 World Chat Champion
| Fin |
 Fin World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 07:35 - 13 Jun 2016 Post subject: |
Get someone to ride behind you for a bit. Seems to be a thing with Hornets that when you follow behind them you're breathing in neat petrol vapour. There's one I sometimes see on the A2 that I have to get past ASAP coz it makes me want to puke. ____________________ a.k.a 'Geri'
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:26 - 13 Jun 2016 Post subject: |
The Hornet is notorious for having a tank with a deep filler neck that's a sod to get properly full, plus a good 4 litres of it remains inaccessible on the RHS away from the petcock. Even so, 50 miles is ludicrous and sounds like you've got a fuelling problem. Is racebike? ____________________ Biking is 1/20th as dangerous as horse riding.
| BTTD |
 BTTD World Chat Champion
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| Holdawayt |
 Holdawayt Trackday Trickster
| Hefty |
 Posted: 10:27 - 13 Jun 2016 Post subject: |
Annoyingly im stuck at work today & possibly tonight so I can't give it the once over.
| jnw010 wrote: |
Do you park in a garage and is there a strong smell of petrol every time you get the bike out? |
It's not garaged, its outside but I do have a rain cover on it. Do you think i'd get a smell straight after taking the cover off?
| Rogerborg wrote: |
The Hornet is notorious for having a tank with a deep filler neck that's a sod to get properly full, plus a good 4 litres of it remains inaccessible on the RHS away from the petcock. Even so, 50 miles is ludicrous and sounds like you've got a fuelling problem. Is racebike? |
I'd read that elsewhere too, so the last time I filled up I sat on the bike keeping it level, filled to the very top then waited a bit.. as you said after a short wait the fuel level dropped a little, and I could squeeze more in. However not enough extra to make up 40-odd miles though?
| jaffa90 wrote: | Your tank is full of chippings or your engine oil level is getting higher |
No other way to check for crap other than dumping the fuel I guess? Oil level has remained pretty constant so far. What would cause the oil level to rise and how would that affect my mpg?
| Itchy wrote: | Check your brakes aren't dragging/seized. A quick way to test is if you can roll it around freely. If it needs leaning into to push it around then you may have seized brakes.
Another way is after a ride spit on your discs. Seized discs will be much hotter than normal brakes. |
The first time I ran out of fuel I had to push it to the side of the road as I couldn't find the petcock immediately by hand, and my first thought was fuck me this weighs a bit You might be right there. Is that a caliper or disc issue though? I'll see if I can grab some brake cleaner and a brush on the way home from work and give the calipers a good clean & see if that helps.
| Pete. wrote: | Get someone to ride behind you for a bit. |
Annoyingly I don't have any biking mates that I could call up to help out.
edit: after a quick search on the calipers found this:
| chris-red back in 2011 wrote: |
You need to buy somethings,
I can of brake cleaner (£5)
a 2 pack of toothbrushes (Tesco value 10p)
Silicon Grease (£??)
Copperslip (£??)
Take them off (one at a time) take the pads and clips out, pull the brake lever and watch the pistons in the caliper move. Make sure none of them come out too far. If not all your pistons are moving it is seized. The best way to free the seized one is hold the moving pistons in with you hand a squeeze the brake lever a fer times this should free it off.
The pistons will likely be covered in Shit, using the brake lever squeeze out all the pistons evenly until you can see clean metal.
*If you squeeze too much you will pop a piston out and have to bleed the brakes*
Once there are all out use the brake cleaner to blast off all the shit any stubborn muck will have to be shifted with the tooth brake. Use liberal amounts of brake cleaner.
Once all the pistons are clean apply the silicon grease to all the pistons then squeeze them back in so they are flush with the caliper This can be tricky with 4 piston calipers. Then put the pads etc back in using copperslip on the backs of the pads and on the retaining pin/any parts you need to remove the pads.
Then do the other one a nice easy satisfying job.  |
Is that pretty much bang-on? Anyone have anything else to add. ____________________ '13 Honda CBF125 // '99 Suzuki SV650s // '98 Honda CB600F Hornet
| Pete. |
 Pete. Super Spammer
| Shinigami |
 Shinigami World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 14:09 - 13 Jun 2016 Post subject: |
| Hefty wrote: |
Copperslip (£??)
Is that pretty much bang-on? Anyone have anything else to add. |
Personally I recommend popping the brake pistons. IIRC (which I don't) the Honda Hornet has twin sliding callipers rather than twin opposed callipers.
What you want is four pieces of wood that you can put between the brake pistons. You can use the bits of wood to 'lock off' the other pistons so only one gets pushed out. Push it out using the brake lever carefully then push it back in.
If you go to far it goes pop and lets air into the system. You're not narfed on how to get the other 3 pistons out as there will be no pressure in the system.
Using blocks of wood you can extend them all to a maximum amount and not pop the pistons or you can extend them individually. If you put them out about 1.5cm-1.75cm you can usually grab them and pull them out anyway.
On my NTV with single sliding calliper it took 35 minutes. I did it at the side of the road with my underseat tool kit.
Top tip!
You can check the seizing or not by pushing it around. Still not sure? Then stick a hammer or something under the swing arm which will raise the rear. Then try spin the wheel. The back should spin ok but has to drag the chain so will stop quickly. It should however spin with a slight push. If you need to give it some oomph it's seized. Back brakes are easy to clean.
The front is the same but the hammer goes under your footpegs turned upside down. It lifts the front wheel which should spin freely with a small push. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Skudd |
 Skudd Super Spammer
| BTTD |
| Polarbear |
 Polarbear Super Spammer
| myvision |
 myvision Scooby Slapper
| Hefty |
| Polarbear |
The last post was made 10 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
