best garage floor options
pompousporcup...
PostPosted: 19:45 - 14 Jun 2016    Post subject: best garage floor options Reply with quote
cut a long story short i've finally bought a house with a garage on the property rather than one in a separate block, several meters from the house. yaay for me.
Looking forward to having Power, lighting and heating too for those cold winter nights tinkering. Last year i was working on a Honda Cr-x in the god damn snow
Now, Has anybody put "garage flooring" down over a concrete floor? IE the duramat stuff? Is it easy to clean and definitely non-slip?
Is there a better alternative that i'm missing perhaps?..
Also, what lighting is best from your personal experiences? I've never had the benefit of a garage with light Laughing No idea if a certain light config will create dark zones/shadows
All help/advise appreciated.
Garage size is approx 10 x 20 ft(possibly a few ft bigger) with sockets on the back and house side wall so plenty of place to get power from.
sickpup
Old Timer
PostPosted: 21:02 - 14 Jun 2016    Post subject: Reply with quote
I haven't used the Duromat product but that type of tile has been used for years and dependent on the density of the rubber can be extremely long lived. It won't be totally non-slip, nothing is and it won't stand up to side stands, centre stands or heavy weights on small legs etc as it isn't designed for this. It also has the problem of water underneath not being able to run out and possibly causing the tile to rise. If any part is exposed to sunlight on a hot day you may also find it expands but it will contract again once cooled.
A good altenative is a resin type floor although this also won't stand up to heavy use.
Another alternative is a porcelain tile floor. This is quite possibly the most durable floor if laid correctly BUT if not is fragile. Unlike the other options it doesn't provide good insulation against a cold floor but you could add underfloor heating to take off the chill or use rubber tiles on top where you are working.
If it was me I think I would fit underfloor heating and go with the porcelain as it would last for decades and raise the value of the house if/when you came to sell or at worst it would become a selling point helping any sale happen quickly.
sickpup
Old Timer
PostPosted: 21:14 - 14 Jun 2016    Post subject: Reply with quote
A lot of people swear by T8 battens but I prefer LED's at the moment. LED's cost more but should be considerably cheaper to run and last longer. In a garage the size of yours I would fit at least 4 6 foot doubles possibly 6 of them.
sickpup
Old Timer
PostPosted: 21:26 - 14 Jun 2016    Post subject: Reply with quote
As an aside you may want to consider these wall cabinets.
Hilka wall cabinets.
They come flat packed but are easy to build and once assembled and mounted with large bolts they are incredibly strong.
spikenipple
PostPosted: 21:35 - 14 Jun 2016    Post subject: Reply with quote
If you get the right stuff put down, it most certainly will.
If you have the concrete floor prepped and epoxied, you'll have to repeatedly subject it to blunt impacts to damage it.
We had an entire machine shop floored with this stuff, and it has all sorts of things dragged through it, dropped on it, moved through it and it's not got a scratch on it.
The downside is it'll cost you about £70/m².
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
arry
PostPosted: 21:38 - 14 Jun 2016    Post subject: Reply with quote
One thing is certain don't use Ronseal Diamond Hard floor paint cos it most definitely ain't.
sickpup
Old Timer
PostPosted: 21:46 - 14 Jun 2016    Post subject: Reply with quote
I always thought this but found out that even hot tyres can damage resin floors as well as side stands and centre stands.
As you say the more expensive types may be better but at £70m2 thats a very high cost.
BTTD
PostPosted: 21:48 - 14 Jun 2016    Post subject: Reply with quote
I bought a couple m2 of plasfloor tiles to see what they were like three years ago. I think they're pretty decent for the price and I would have done the whole floor in them, but it's one of those things I just haven't gotten around to. I blame my two year old son and a wife who thinks finishing the house is more important. Rolling Eyes
In the meantime the bikes been parked on them. Order a m2 and see what you think for yourself.
charlie74
PostPosted: 22:51 - 14 Jun 2016    Post subject: Reply with quote
personally I would split it into 2 halves..
first 10 ft near the door id use industrial poly type floor paint, do a coat, scatter a bit of sand lightly while its drying, then paint over again to seal the sand in bit pikey but it works and you wont slip over in wet boots etc and get a bike mat if you want somewhere to let the daily drip dry
back half is probably where your going to do the "projects" so thick plyboard/osb painted in a lightish colour ( helps you find that bloody washer/spring) and is cheap and can take a whack, and dead easy to repaint as needed, also works well as an insulator
I'd be surprised if that cost you more than £200 tbh and that's having the sheets deliverd
whitedevil
PostPosted: 00:03 - 15 Jun 2016    Post subject: Reply with quote
I put down reclaimed office floor tiles. Cost me 40 quid to do the whole garage. 100 tiles. Can't fault it tbh.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
mudcow007
PostPosted: 00:07 - 15 Jun 2016    Post subject: Reply with quote
not really helpful this but we have a resin floor in our warehouse, it has lasted less than a year an is now breaking up - was applied by the company that supplied it too..
iooi
PostPosted: 06:07 - 15 Jun 2016    Post subject: Reply with quote
Cheap option.
Take the carpet out of the house and lay that on the garage floor Thumbs Up
J4mes
PostPosted: 06:48 - 15 Jun 2016    Post subject: Reply with quote
iooi wrote:
Cheap option.
I've got 70's shagpile in mine. beautiful.
BTTD
PostPosted: 08:35 - 15 Jun 2016    Post subject: Reply with quote
If you really want to see a lot of garages (with a whole sub forum purely for flooring) have a look at The Garage Journal.
It's a US site so some of those domestic garages are bigger than UK industrial units, but there's a fair few smaller spaces and even a few UK posters.
pompousporcup...
PostPosted: 08:44 - 15 Jun 2016    Post subject: Reply with quote
cheers folks, some good ideas there Thumbs Up
fwiw i've used an old rug from the house in the current garage and its worked well. A new "thick" carpet would probably work well enough
Heated floors are probably a bit extravagant for the garage (as much as i'd love to do it). the cost of the heating bits for that size room appears to be way more than doing the actual flooring. I guess a couple of external heaters either end of the garage will suffice Laughing There's also the issue of the other half wanting the kitchen and bathroom floors heated. Those rooms are apparently more important than the man space.. don't want to set precedent
Found these
https://www.screwfix.com/p/heuga-ribbed-heavy-contract-carpet-tiles-graphite-20-pack/57304?kpid=57304&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20tracking%20url&cm_mmc=Google-_-Shopping%20-%20Building%20and%20Joinery-_-Shopping%20-%20Building%20and%20Joinery-_-all\building%20&%20joinery\carpet%20tiles\heuga_22930416-ab6b-415c-b174-5167a4018d18&gclid=Cj0KEQjw-YO7BRDwi6Stp7T296ABEiQAD6iWMUMTsL-mKrOXDab45xBryKU-izThVHpFHUKEIevy0qkaAgdm8P8HAQ#product_additional_details_container
which is similar to the carpet the office i work in has and seems a decent option.
Like the idea of having a wooden garage floor* Cool i think it would be fairly hard wearing and much easier to replace than tiling and easier to lay (i've not tiled a floor before) and would have an "old skool" vibe to it
*fire extinguishers at the ready
BTTD
PostPosted: 09:05 - 15 Jun 2016    Post subject: Reply with quote
Heated floors: If you're putting electric elements in to heat the floor, don't you need insulation underneath? Otherwise you're just heating the ground , which is very big heat sink. Modern houses will most likely have under-slab insulation (or insulation between the floor joists), but I'm not so sure about a garage, or indeed the age of the OP's property.
I've seen wood/ osb flooring in some woodworker sheds / garages as it makes the floor more comfortable to walk on, you can insulate under, and you're less likely to damage a tool if you drop it. I think you'd want to coat it if you parked a wet bike on it regularly, I'm not sure if it would like the moisture that much.
Baffler186
PostPosted: 09:12 - 15 Jun 2016    Post subject: Reply with quote
I covered mine with the old lounge carpet (very short and worn pile). There are pro's and cons though. Pro's: it's cheap or free, it absorbs spills very well and can be dried out if you have a heater/dehumidifier on it for a day. It's comfy to kneel on when working on the bike.
Cons: it can absorb and retain moisture if you don't dry it out. It can hide little nasties like off cuts of wire etc (but you can also hoover it).
For me, anything you lay will have to be glued or secured down properly, that's about my only advice. I've tried mats but unless fully covered and secured to the floor I found it annoying because they slipped about and were a trip hazard.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
B5234FT
PostPosted: 09:49 - 15 Jun 2016    Post subject: Reply with quote
In my last couple of garages, I've gone for expoxy based floor paint in a light grey colour on the floor as it makes it easy to mop up spills and reduces dust when sweeping up and then I normally keep bits of old carpet as mats for crawling under cars. I wouldnt carpet the whole floor, too easy to dump 5l of coolant, or worse still, fuel into it.
For the walls, plain white emulsion onto the breeze block, cheap and helps with light no end!
For lights, cheap external (i.e. with a cover to save you smashing the bulbs) high frequency 5' flourescent tubes. I have 6 in a double garage and thats ample.
After that, a ceiling helps if your design suits it, get everything you can off the floor (my compressor is in the rafters for instance) and go for cupboards and drawers rather than shelves as it helps to keep things tidy if you're creating dust.
A dehumidifier is a huge asset too, especially in winter.
Aky208
PostPosted: 10:19 - 15 Jun 2016    Post subject: Reply with quote
This Thumbs Up
I covered my whole garage for next to nothing plus have spares for when one gets too damaged to use. so easy to just replace one tile.
mudcow007
PostPosted: 12:53 - 15 Jun 2016    Post subject: Reply with quote
I put lino on my shed (10 x 10) floor, it was a roll end so cost me £30 from local carpet shop
makes wiping oil up easier, bit of cushioning for your knees if you bend down etc an its warmer
side stand leaves dents though - i use a jam jar lid to spread the load
and its slate effect for that rustic look
PostPosted: 21:31 - 15 Jun 2016    Post subject: Reply with quote
I used T5 link electronic strip lights and they are the mutts nuts without breaking the bank. They are normally used in display stands but the beauty of them is you can daisy-chain them together and add more to the system with simple plug-in cables. All looks a tad ghetto with the cables clipped to the ceiling but it's a garage, not a designer kitchen. You can even unclip one and use it like a droplight if you want (but try not to drop it, the tube is still glass).
Being electronic, there is no lag time at switch-on and they don't flicker on cold days. They are individually switched so it would also be possible to have some of them off some of the time.
I have a couple of the LED equivalents elsewhere in the house (I use them for cupboard lights). The fluos have the edge on light output though. The LEDs are roughly double the price. If you were putting any at low level, I'd expect the LED ones to be much less prone to damage.
I arranged mine in a rectangle round the garage instead of centrally so there is always some light hitting whatever you're working on. In a bigger garage, I'd sling a couple in the middle too for extra brightness.
EDIT: Pics... Yes, there IS artex on my garage ceiling and no, I have no idea why.
https://i48.photobucket.com/albums/f216/stinkwheel/CIMG0961.jpg
EDIT2: You could also fit one of these on the wall above your workbench. I have one over our large animal operating table at work and it works well. I even fitted it with a plug because it's a long way from the lighting ring. The lamp itself has a switch on top so it doesn't need to be on all the time even if hooked into the room lighting, just click it on as needed.
doggone
PostPosted: 22:10 - 15 Jun 2016    Post subject: Reply with quote
I have some of these - quite good to kneel on and price seems reasonable for a couple of packs.
https://www.halfords.com/workshop-tools/garage-equipment/garage-essentials/rolson-6-piece-floor-mat-set-120-x-180cm
You need a bit of ply for the stand.
Any kind of matting soon gets disgusting if you are putting the bike in wet/muddy/salty most days in winter.
331X2
PostPosted: 22:15 - 15 Jun 2016    Post subject: Reply with quote
Regarding lighting, look at the 600x600 modular LED fittings as fitted into suspended ceilings, they throw a lot of light out and can be picked up for around 25 quid each if you look around.
I've currently got 7 5' twin T8's in mine and it id ridiculous how much power it uses, I'll be going over to LED when I rebuild it later this year.
sickpup
Old Timer
PostPosted: 09:14 - 16 Jun 2016    Post subject: Reply with quote
Using underfloor heating under tiles yes you would need an insulation barrier but you are not trying to heat the garage you are just stopping the floor being cold. One of the highest causes of fatigue in a workshop is the worker getting cold and a lot of that is caused by loss of heat throught the feet into a freezing floor.
BTTD
PostPosted: 09:40 - 16 Jun 2016    Post subject: Reply with quote
Interesting, I never would have thought of doing it like that.
The last post was made 10 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 132.79 Kb
