BT50QT-9H
mogridge
PostPosted: 12:37 - 15 Jun 2016    Post subject: BT50QT-9H Reply with quote
I bought this Baotian running well and then went on holiday for a week. When I got back it would not start. Pushing the start button has no effect but there is power to the dash. I replace the ignition barrel and the CDI.
When I shorted direct from the battery + terminal to the solenoid it would turn over so it is not starter motor or solenoid.
I cleaned the contacts under the starter button again no joy.
Help please
SrM
andyscooter
PostPosted: 16:09 - 15 Jun 2016    Post subject: Reply with quote
How's the battery
This would be first thing Iwould be checking
Multi meter and 12.5 to be good
Evil Hans
PostPosted: 16:25 - 15 Jun 2016    Post subject: Reply with quote
Also, does it have a sidestand/gear/clutch safety switch that could be preventing the starter from firing?
mogridge
PostPosted: 17:01 - 15 Jun 2016    Post subject: Baotian Reply with quote
Thank you both for your suggestions. In reply the battery has a full charge and the side stand does cut everything but it is in the up position and the bike is in the back stand.
Could the side stand be causing the problem despite being up? Is there some short happening? Can I disconnect the side stand or render it inoperative in some way? I sprayed WD40 on it to ease the joint, would that be the cause?
Sorry to be such an idiot but bikes weren't this complicated when I stopped riding all those years ago.
SrM
charlie74
PostPosted: 18:03 - 15 Jun 2016    Post subject: Reply with quote
side stand switches are notorious for being crap, lack of sealing means water gets in causing a short/corrosion..
its worth looking on the net/youtube for a quick guide on how to disconnect it, you can just unplug it, and I think you just connect the ends of the loom, but not 100% as ive not done it myself
mogridge
PostPosted: 20:53 - 15 Jun 2016    Post subject: Reply with quote
There are 3 wires that seem to come directly from the ignition. 2 greens and the black and white. The actual plug is non removable. So my question is which do I join together to bypass the side stand please.
Please let it be either the 2 greens or all three.
SrM
Islander
PostPosted: 21:49 - 15 Jun 2016    Post subject: Reply with quote
Does it have a kill switch? If so is it in the run position?
mogridge
PostPosted: 17:48 - 16 Jun 2016    Post subject: Baotian Reply with quote
No kill switch. Turns off at key or put side stand down.
SrM
andyscooter
PostPosted: 17:56 - 16 Jun 2016    Post subject: Reply with quote
battery has a full charge but what is it reading at
a) off
B) being started
if it drops too far it could be a duff battery
my old qt11 had a problem with leaving the electrics live even if key was out
it would kill batteries
mogridge
PostPosted: 19:09 - 16 Jun 2016    Post subject: Reply with quote
The battery checks out on my multi meter and holds its charge. It is the switch which is the issue. The side stand could be an issue. Shorting across from battery +ve to solenoid starts it.
Can I bypass the side stand and how. It is connected to the ignition by 2 green wires and 1 black and white.
SrM
iooi
PostPosted: 20:28 - 16 Jun 2016    Post subject: Re: BT50QT-9H Reply with quote
Help please
Kill Switch.......
WD Forte
PostPosted: 20:32 - 16 Jun 2016    Post subject: Reply with quote
I see no reference to pulling the brake/s on before starting.
You do know the brake levers have micro switches that are part of the safety/starting system on most, if not all, of those scooty things?
Instead of fart assing around with the CDI, ignition barrels and such
check the micro switches
Maybe just put the brake/s on as you try and start it.
bikers smell of wee
mogridge
PostPosted: 21:00 - 16 Jun 2016    Post subject: Reply with quote
We never have before. But I have just gone and tried your suggestion and it worked so I tender my most grateful thanks to you. Microswitches are new ones on me for obvious reasons see above.
SrM
WD Forte
PostPosted: 00:08 - 17 Jun 2016    Post subject: Reply with quote
There ya go see?
Summat learnt Smile
bikers smell of wee
Evil Hans
PostPosted: 10:10 - 17 Jun 2016    Post subject: Reply with quote
Maybe I should have just said "a safety switch" .... didn't think I'd have to list every possibility Very Happy
The last post was made 10 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 81.77 Kb
