settle an argument
dombaird
PostPosted: 14:41 - 15 Jun 2016    Post subject: settle an argument Reply with quote
GSXR 600 running BT016s Hypersports
what should the tyre pressures be?
currently 38psi front and 41psi rear
debating if that is too much and should be 36psi front and rear or 40psi front and 42psi rear
mostly rural roads, twisties, not alot of city riding or motorway riding
DGB
Evil Hans
PostPosted: 15:27 - 15 Jun 2016    Post subject: Reply with quote
From the Bridgestone website - https://www.bridgestone.co.uk/moto/search-results-bike/?bike=SUZUKI&model=GSX-R+600
36 front, 42 rear
supZ
PostPosted: 15:42 - 15 Jun 2016    Post subject: Reply with quote
Evil Hans wrote:
that's pretty much the standard for most tyres.
that said its a little down to personal preference. i like bridgestones, but they're quite hard sidewalled so i run them a couple of psi lower for a little more flex, but that's just me.
iirc Michelin are quite soft walled so you'd most likely run them at spec but again.. depends on your preference.
CBR954RR - Daily toy
CBR600RR - Trackbike
jaffa90
PostPosted: 16:06 - 15 Jun 2016    Post subject: Reply with quote
Tyre pressures are only recommended, as said it`s up to you.
I set mine at 34psi front & 36psi rear. solo use.
PostPosted: 16:59 - 15 Jun 2016    Post subject: Reply with quote
They are the recommended pressures for my Street Triple, but I run 38/34 as the bike feels better like this. I'm only just over ten stone, so that might make a difference too.
Hahadumball
PostPosted: 18:47 - 15 Jun 2016    Post subject: Reply with quote
recommended and what you use are different.
i run my tyres quite hard because i prefer it that way, others dont.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Kawasaki Jimbo
PostPosted: 23:03 - 15 Jun 2016    Post subject: Reply with quote
I stick with the standard for modern tyres (with some exceptions) of 36psi front and 42psi rear. If your bike is a few years old they probably don't make the original tyres anymore so ignore the recommended pressures in the bike's manual and refer to the tyre manufacturer's website instead. Thereafter I adjust the suspension if I'm unhappy with the ride, leaving the tyre pressures alone. I'd say there's not much flex in a motorcycle tyre wall anyway, and the contact patch and profile are fine tuned for a combination of grip, water expulsion and turn rate so I don't mess with that.
dombaird
PostPosted: 09:20 - 16 Jun 2016    Post subject: Reply with quote
thanks for the help!
much appreciated
DGB
The last post was made 10 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 56.46 Kb
