HELP!!!!!! Rs125
Dedge1
PostPosted: 16:24 - 16 Jun 2016    Post subject: HELP!!!!!! Rs125 Reply with quote
Hi my friend has an aprilia rs125 and just bought a full arrow exhaust. on taking the standard one off one of the Allen key bolts in the barrel was rounded off and it's in very tight would like any info on best way to get it out or easiest way 😄😄😄. Thank you for any help👍👍👍👍
mudcow007
PostPosted: 17:15 - 16 Jun 2016    Post subject: Reply with quote
Heat?
Cutting a slot into the head of the bolt an option?
wacking a slightly bigger allen key socket in has worked on stuck bolts in the past for me - bodgetastic though
PostPosted: 17:32 - 16 Jun 2016    Post subject: Reply with quote
Hammer a torx bit into it, I've never failed to remove one with this method.
PostPosted: 17:35 - 16 Jun 2016    Post subject: Reply with quote
Where exactly is the Allen bolt.
redeem ouzzer
PostPosted: 18:59 - 16 Jun 2016    Post subject: Re: HELP!!!!!! Rs125 Reply with quote
Kill yourself.
Be a REAL MAN!
PostPosted: 19:15 - 16 Jun 2016    Post subject: Reply with quote
I don't think it should be an allen key bolt on the exhaust flange...? It should be a stud and hex nut affair. If someone has put an allen key bolt in replacing the stud and nut, then they are a bodger of the first order and should be shot.
Remove it and replace it with a stud, and use threadlock to hold it in place.
Dedge1
PostPosted: 19:16 - 16 Jun 2016    Post subject: Reply with quote
The bolt is where the exhaust slots onto the barrel it's the right side thanks for the replies👍👍👍
Dedge1
PostPosted: 19:21 - 16 Jun 2016    Post subject: Reply with quote
That's the plan if I finally get the bolt out to replace it with a hex bolt it defo shouldn't be an Allen key one someone must of messed with it in the past the bikes 10 years only so that's probably the case 😕
mudcow007
PostPosted: 20:08 - 16 Jun 2016    Post subject: Reply with quote
im almost certain mine are allen key bolts on my Bandit Shocked
andy_uk
PostPosted: 20:13 - 16 Jun 2016    Post subject: Reply with quote
Seems to be pretty standard on the Rotax 122/123 engine.
+1 for the "replace with stud" idea though Smile
PostPosted: 21:04 - 16 Jun 2016    Post subject: Reply with quote
Should be allen key bolts, and as standard hold on the exhaust stub and a small L shaped piece for the exhaust springs to hook on to.
Doubt you could do up a coventional hex bolt or a nut on a stud with the L shaped piece in place.
Allen key bolt makes life easy. Stud and nut would be the total bodge.
Katy
The last post was made 10 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 68.45 Kb
