GSX 750F
Dennis_B
PostPosted: 23:30 - 18 Jun 2016    Post subject: GSX 750F Reply with quote
My brother has a GSX 750F 1991. Has anyone changed a starter motor on these? The issue is that sometimes it will start ok, others you press the starter and nothing. You then have to put it in first and rock the bike back and forth, then put it in neutral and hit the starter and then it'll turn over. Not a battery issue as charging ok.
Someone mentioned taking the carbs off, is that right?
jaffa90
PostPosted: 00:26 - 19 Jun 2016    Post subject: Reply with quote
When you press the starter and nothing happens check if the starter is getting power, it may be a simple safety switch like the neutral one preventing start up.
Who ever mentioned carbs off is not your friend.
Dennis_B
PostPosted: 00:55 - 19 Jun 2016    Post subject: Reply with quote
He's tried bypassing the neutral switch by pulling in the clutch, still no joy. Also there is a 'click' sound. I had a similar thing on an old Vauxhall Cavalier, I had to tap the starter motor with the crook-lock on occasions as it stuck.
jaffa90
PostPosted: 01:06 - 19 Jun 2016    Post subject: Reply with quote
Cars and bikes have different starter systems, has he tried bypassing the starter relay switch as well as my last post.
Dennis_B
PostPosted: 01:09 - 19 Jun 2016    Post subject: Reply with quote
No not yet. Will give it ago tomorrow. Thanks.
jaffa90
PostPosted: 01:17 - 19 Jun 2016    Post subject: Reply with quote
Also try jump leads from a car just to make sure you have the voltage (amps really).
redeem ouzzer
PostPosted: 09:50 - 19 Jun 2016    Post subject: Reply with quote
You have to take the carbs off to get at the starter motor bolts if you need to change it.
Be a REAL MAN!
Dennis_B
PostPosted: 09:55 - 19 Jun 2016    Post subject: Reply with quote
Ok, thanks. That is what I was told.
jaffa90
PostPosted: 10:08 - 19 Jun 2016    Post subject: Reply with quote
Simple checks first.
kev2b4
PostPosted: 10:42 - 19 Jun 2016    Post subject: Reply with quote
have got a starter motor for GASX750E old Y reg , at present is attached to gearbox casing ( head and barrels missing) - free to good home !
previous C50,CD175,GT500,GSX250,CB750KZ,GSX750E,GSX1300R
Dennis_B
PostPosted: 18:22 - 19 Jun 2016    Post subject: Reply with quote
Thanks but he has a replacement. It has not played up much today, if you stop the engine via the kill switch all appears good next time you start it. If you stop the engine with the key it's 50/50 if it'll need the rocking motion to start, sounds electrical. That's my best guess.
jaffa90
PostPosted: 21:21 - 19 Jun 2016    Post subject: Reply with quote
As said simple things first.
The last post was made 10 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 68.44 Kb
